Home » Modeling » UML2 » Subsets and redefines code generation problem
Subsets and redefines code generation problem [message #549580] Tue, 27 July 2010 05:18 Go to next message
I am specifying a hierachical static profile containing subsetted and
redefined properties. The transformation to ecore runs well and takes into
account subsets and redefines. However, the generated code does not compile.
The top level profile package is not generated but is used in subprofiles
containing subsetted or redefined properties.
Please find enclosed a small example illustrating the problem.
Chokri
Re: Subsets and redefines code generation problem [message #553045 is a reply to message #549580] Mon, 16 August 2010 04:27 Go to previous messageGo to next message
Any workaround to deal with subsetted properties?
Thanks in advance.
Chokri
"Chokri Mraidha" <Chokri.Mraidha@cea.fr> a
Re: Subsets and redefines code generation problem [message #553335 is a reply to message #553045] Tue, 17 August 2010 04:11 Go to previous messageGo to next message
If I remenber well we had faced the same nested package problem with EMF few years ago. The trick was to add a test after each transformation. No easy and painful but it worked well Confused
Re: Subsets and redefines code generation problem [message #553450 is a reply to message #549580] Tue, 17 August 2010 10:48 Go to previous message
Chokri,
Packages without classifiers aren't generated and normally aren't
needed. You could try to add a dummy classifier to any package that's
not generated...
Chokri Mraidha wrote:
> Hello,
> Chokri
Re: Subsets and redefines code generation problem [message #628592 is a reply to message #549580] Mon, 16 August 2010 04:27 Go to previous message
Thanks in advance.
Chokri
Re: Subsets and redefines code generation problem [message #628594 is a reply to message #553045] Tue, 17 August 2010 04:11 Go to previous message
If I remenber well we had faced the same nested package problem with EMF few years ago. The trick was to add a test after each transformation. No easy and painful but it worked well :?
Re: Subsets and redefines code generation problem [message #628595 is a reply to message #549580] Tue, 17 August 2010 10:48 Go to previous message
Chokri,
not generated...
> Hello,
> Chokri
Previous Topic:Profile OCL validation
Next Topic:Retrieving applied stereotypes
Current Time: Wed Jul 23 14:55:44 EDT 2025
Powered by FUDForum. Page generated in 0.05984 seconds
