Home » Modeling » UML2 » Problem copy sterotype
Problem copy sterotype [message #628568] Mon, 09 August 2010 13:10 Go to next message
I'd like to copy a Port and all its stereotypes; i tried with EcoreUtil.Copier but it copies only the port and not its stereotypes.
How can I do this?
Thanks in advance, 123star
Re: Problem copy sterotype [message #628582 is a reply to message #628568] Sat, 14 August 2010 04:54 Go to previous messageGo to next message
This is an expected behavior. Stereotypes are lost during transformation stage.
a trick could be to add a glue at the end of the process in order to rewrite the needed stereotype.
Re: Problem copy sterotype [message #628620 is a reply to message #628568] Wed, 01 September 2010 12:28 Go to previous message
Hi, 123star,
The EcoreUtil::Copier can copy a collection of objects. Copy the Port
and its applied stereotypes (using Element::getStereotypeApplications()
API or some such; I forget the exact name) in one copy operation. The
copier will ensure that the stereotype copies correctly link to the port
copy.
HTH,
Christian
On 09/08/10 01:10 PM, 123star wrote:
> How can I do this?
Previous Topic:Problem copy sterotype
Next Topic:how to create object diagram using UML 2 eclipse tool
Current Time: Fri Jul 25 21:44:28 EDT 2025
Powered by FUDForum. Page generated in 0.03580 seconds
