Home » Modeling » UML2 » Validating an EMF model programatically
Validating an EMF model programatically [message #535591] Mon, 24 May 2010 14:42 Go to next message
I was going over the EMF Validation Framework example and I was able to set everything up and add a few extra constraints. Then I run the plugin as an eclipse application, I create the model and then in the editor menu I can select validate to check the constraints and everything works fine.
But I was wondering if it is possible to validate a model programmatically, without using the editor.
// For example, create a few objects:
Book myBook = EXTLibraryFactory.eINSTANCE.createBook();
myBook.setTitle("EMF Validation");
Writer writer = EXTLibraryFactory.eINSTANCE.createWriter();
writer.setName("Hector");
//And then do the validation
I've been searching the web with no luck. Can something like this be done? I would appreciate any hints.
Thanks.
Re: Validating an EMF model programatically [message #535602 is a reply to message #535591] Mon, 24 May 2010 15:40 Go to previous messageGo to next message
Diagnostician.INSTANCE can be used to check the core constraints.
> Thanks.
Re: Validating an EMF model programatically [message #535624 is a reply to message #535602] Mon, 24 May 2010 19:26 Go to previous messageGo to next message
I tried using Diagnostician.INSTACE before but it seems that it only checks the default core constraints, which is not useful in my case. I added a couple of custom constraints and those are ignored by the Diagnostician.
Hector
Re: Validating an EMF model programatically [message #535625 is a reply to message #535624] Mon, 24 May 2010 19:30 Go to previous messageGo to next message
Hector Chavez wrote on Mon, 24 May 2010 19:26
Hector
To be more specific, I added two ocl constraints on plugin.xml following the format given in the OCL validation tutorial on the eclipse documentation web site. Those constraints are correctly checked when I use the editor->validate, but are ignored by the Diagnostician.
Hector
Re: Validating an EMF model programatically [message #535732 is a reply to message #535625] Tue, 25 May 2010 08:52 Go to previous messageGo to next message
Hi, Hector,
I gather from this thread that you have used the example plug-in's
Validate context menu action to successfully test your constraints. It
serves as an example of how to perform validation using the API: just
look at the implementation of that action. :-)
Hopefully the Programmer's Guide documentation included in the SDK will
be helpful, also.
Finally, this subject is not quite in the scope of the MDT UML2
newsgroup. Any follow-up question that you may have about EMF
Validation should be directed to the EMF newsgroup; indeed, you will
probably find that many of your questions (including this one) have been
asked and answered, there.
HTH,
Christian
>> Diagnostician.
>> Hector
> Hector
Re: Validating an EMF model programatically [message #535736 is a reply to message #535732] Tue, 25 May 2010 09:03 Go to previous messageGo to next message
Thank you, I didn't think about that, I'll check the EMF newsgroup.
Hector
Christian W. Damus wrote on Tue, 25 May 2010 08:52
Hi, Hector,
look at the implementation of that action. Smile
be helpful, also.
HTH,
Christian
>> Diagnostician.
>> Hector
> Hector
Re: Validating an EMF model programatically [message #628461 is a reply to message #535591] Mon, 24 May 2010 15:40 Go to previous messageGo to next message
> Thanks.
Re: Validating an EMF model programatically [message #628462 is a reply to message #535602] Mon, 24 May 2010 19:26 Go to previous messageGo to next message
Hector
Re: Validating an EMF model programatically [message #628464 is a reply to message #535625] Tue, 25 May 2010 08:52 Go to previous messageGo to next message
Hi, Hector,
be helpful, also.
HTH,
Christian
>> Diagnostician.
>> Hector
> Hector
Re: Validating an EMF model programatically [message #628465 is a reply to message #535732] Tue, 25 May 2010 09:03 Go to previous message
Hector
> Hi, Hector,
> look at the implementation of that action. :)
> be helpful, also.
> HTH,
> Christian
> >> Diagnostician.
> >> Hector
> > Hector
Previous Topic:Re: Validating an EMF model programatically
Next Topic:loading serialized UML2 models standalone
Current Time: Fri Jul 25 22:42:10 EDT 2025
Powered by FUDForum. Page generated in 0.05530 seconds
