Ecore 2 Uml conversion question [message #628405] |
Mon, 26 April 2010 10:39  |
Hello there,
I have an ecore model, read from schema.
I have a question about this structure:
Model
package Core
class CmisPropertiesType
Package Messages
class CreatedocumentType
property properties of class CmisPropertiesType
In Ecore this all look well.
When I convert to UML the property shows up as :
<<eReference>> <property> properties
and the association is set to
Association <Association> A_properties_createDocumentType
In this assoc the member end is set to:
Member End <<eReference>> <Property> properties, <Property> createDocumentType : CreateDocumentType
It seems that I have somehow lost my reference to the CmisPropertiesType and end up with a loopback association to CreateDocumentType.
When i look at it in text it looks like:
<ownedAttribute xmi:id="_JNucdFEREd-RXfSJpGgrjw" name="properties" isOrdered="true" aggregation="composite" association="_JNuchVEREd-RXfSJpGgrjw">
<type xmi:type="uml:Class" href="CMIS_Core.uml#_JOBX_lEREd-RXfSJpGgrjw"/>
</ownedAttribute>
Where this id can't be found in file CMIS_Core.uml (in fact all reference-ids to this file begin with _JOB. which is not in the file. ( the equivalent reference in the exported ecore file can be found in the CMIS_Core.xmi file)
Is this expected behaviour?
Best Regards,
Mobius
Re: Ecore 2 Uml conversion question [message #628407 is a reply to message #628405] |
Mon, 26 April 2010 11:27  |
Hi, Mobius,
What is the type of the "<<eReference>> <property> properties" attribute
in your CreateDocumentType class? I'll bet it is CmisPropertiesType.
The association-owned end is just the non-navigable inverse end required
by a UML association (which must have at least two ends). It has no
correspondent in your Ecore model.
This is all just as it should be.
HTH,
Christian
On 26/04/10 10:39 AM, Mobius wrote:
> Hello there,
> Model
> package Core
> Package Messages
> and the association is set to Association <Association>
> </ownedAttribute>
> CMIS_Core.xmi file)
> Best Regards,
> Mobius
FUDForum. Page generated in 0.03048 seconds
