Home » Modeling » UML2 » UML Profile(How to create a UML profile step by step with sample)
UML Profile [message #526920] Tue, 13 April 2010 09:52 Go to next message
I'm looking for the UML profile tutoriel (or/and docs) with sample.
Thanks in advance,
Ayoub
Re: UML Profile [message #526991 is a reply to message #526920] Tue, 13 April 2010 11:48 Go to previous messageGo to next message
Not sure if this is what you are looking for?
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
The wiki contains other documents.
http://wiki.eclipse.org/MDT-UML2
"ayoub" <sabraoui@gmail.com> wrote in message
news:hq1svs$c68$1@build.eclipse.org...
> Hello,
> Thanks in advance, Ayoub
Re: UML Profile [message #526999 is a reply to message #526991] Tue, 13 April 2010 12:21 Go to previous messageGo to next message
James,
This article describes how to work with profiles using the UML2 plug-ins for Eclipse, But I need a tutorials or documents to more understand the UML Profil and how to create it independently to a tool (with sample if possible).
Ayoub
Re: UML Profile [message #527326 is a reply to message #526920] Wed, 14 April 2010 16:29 Go to previous messageGo to next message
ayoub wrote on Tue, 13 April 2010 09:52
Thanks in advance,
Ayoub
Hi all,
Actually I was gana put similar question and hope this thread covers what all we need
I am in my star to make UML profile and many of us do the same task.
Actually I did not reach final results or valid ones but I could Explain the path to create valid UML Profile
1-you have to understand fully two domains <one for UML metamodel via UML super/infra-structure and the other for the domain you will create your profile>
In this step you get out with an accurate mapping between conceps in both UML metaclasses and there extension via profile
2- he second step is to use a tool that allow creating profiling UML like Eclipse
3- define your profile
4- impor it in any project to use it
hope this help and if any one has modification please inform
The articles that help in defining profilesa are as mentioned above:
http://www.viper.sc/index.php/HowTo_-_Create_a_UML-Profile
that is all till now and I hope u all open discussion so we get benifit from each other
Re: UML Profile [message #527330 is a reply to message #527326] Wed, 14 April 2010 16:43 Go to previous messageGo to next message
http://wiki.eclipse.org/MDT-UML2Tools_How_To_Use_UML_Profile s
Re: UML Profile [message #527332 is a reply to message #526920] Wed, 14 April 2010 16:46 Go to previous messageGo to next message
and these are the UML2.0 specification
http://www.omg.org/spec/UML/2.0/
Re: UML Profile [message #527372 is a reply to message #526999] Thu, 15 April 2010 01:44 Go to previous messageGo to next message
Ayoub,
what about the UML specifications at the OMG http://www.omg.org They
cover all knowledge of how to constrcut profiles indepedently from any
particular technologie platform.
Cheers Timothy
ayoub schrieb:
> James,
> possible).
> Ayoub
Re: UML Profile [message #527584 is a reply to message #527372] Thu, 15 April 2010 12:54 Go to previous messageGo to next message
Timothy Marc wrote on Thu, 15 April 2010 01:44
Ayoub,
Cheers Timothy
Yes but thos who have problems with the many details can read a useful book called "Real-Time Object Uniform Design Methodology with UML"
chapter 3 investigate the UML infrastructure with simple diagrams and chapter 4 explain the superstructure, i advise u get it and read it, i have a soft copy if some one needs it
wafaa
[Updated on: Thu, 15 April 2010 12:55] by Moderator
Re: UML Profile [message #527617 is a reply to message #527584] Thu, 15 April 2010 14:36 Go to previous messageGo to next message
yes there are many details in the OMG's specification, but if it's possible I need this book "Real-Time Object Uniform Design Methodology with UML"
thank's wafaa and Timothy.
Re: UML Profile [message #527847 is a reply to message #526920] Fri, 16 April 2010 12:13 Go to previous messageGo to next message
that is the link, hope u download before its expiration
Real-Time Object Uniform Design Methodology with UML.rar
Re: UML Profile [message #527861 is a reply to message #527847] Fri, 16 April 2010 13:15 Go to previous messageGo to next message
thank you waffaa I dowload it and I hope that help me to create a UML Profile for sequence diagram.
Re: UML Profile [message #528354 is a reply to message #527847] Tue, 20 April 2010 05:01 Go to previous messageGo to next message
wafaa wrote on Fri, 16 April 2010 12:13
Thinks Wafaa for the book Smile
Amine
Re: UML Profile [message #628362 is a reply to message #526920] Tue, 13 April 2010 11:48 Go to previous messageGo to next message
> Hello,
Re: UML Profile [message #628363 is a reply to message #526991] Tue, 13 April 2010 12:22 Go to previous messageGo to next message
James,
Ayoub
Re: UML Profile [message #628364 is a reply to message #526920] Wed, 14 April 2010 16:29 Go to previous messageGo to next message
> Hello,
> Thanks in advance,
> Ayoub
Hi all,
Re: UML Profile [message #628365 is a reply to message #527326] Wed, 14 April 2010 16:43 Go to previous messageGo to next message
Re: UML Profile [message #628366 is a reply to message #526920] Wed, 14 April 2010 16:46 Go to previous messageGo to next message
Re: UML Profile [message #628367 is a reply to message #628363] Thu, 15 April 2010 01:44 Go to previous messageGo to next message
Ayoub,
Cheers Timothy
ayoub schrieb:
> James,
> possible).
> Ayoub
Re: UML Profile [message #628369 is a reply to message #527372] Thu, 15 April 2010 12:54 Go to previous messageGo to next message
> Ayoub,
> Cheers Timothy
chapter 3 investigate the UML infrastructure with simple diagrams and chapter 4 explain the superstructure, i advise u get it and read ir, i have a soft copy if some one needs it
wafaa
Re: UML Profile [message #628370 is a reply to message #628369] Thu, 15 April 2010 14:36 Go to previous messageGo to next message
Re: UML Profile [message #628371 is a reply to message #526920] Fri, 16 April 2010 12:13 Go to previous messageGo to next message
http://www.transferbigfiles.com/ec59a54c-5f27-42ec-979a-ced6 96dedf02?rid=HojwOrlEYo7ZXa5sUNUVHQ%3d%3d#download
Re: UML Profile [message #628372 is a reply to message #628371] Fri, 16 April 2010 13:15 Go to previous messageGo to next message
Re: UML Profile [message #628375 is a reply to message #628371] Tue, 20 April 2010 05:01 Go to previous message
Thinks Wafaa for the book :)
Amine
Previous Topic:Can't apply stereotype either with UML Editor or with UMLTools diagram editor
Next Topic:Re: EMF Compare
Current Time: Wed Jul 23 07:29:33 EDT 2025
Powered by FUDForum. Page generated in 0.10325 seconds
