Home » Modeling » UML2 » Using a reference model in uml2
Using a reference model in uml2 [message #628276] Mon, 01 March 2010 04:50 Go to next message
Hi There,
I can't find the right way to use a reference model in UML2.
I wan't to extend an exising standard model (CIM) for local use (DSL?). I will create an profile for this, but that is on the metamodel level.
I wan't to be able to subclass a class from the reference model (with a localy defined stereotype) in order to alter the original class for local use. e.g. alter attributetypes, alter multiplicity, add local attributes etc ).
Any ideas?
Best Regards,
Mobius
Re: Using a reference model in uml2 [message #628277 is a reply to message #628276] Mon, 01 March 2010 06:28 Go to previous messageGo to next message
Mobius,
Generally you need to load the resource you want to reuse, or refer to,
into the editor, and then its contents will become available for use in
the properties view or for drag and drop from the outline.
Mobius wrote:
> Hi There,
> metamodel level.
> attributes etc ).
> Any ideas?
> Best Regards,
> Mobius
Re: Using a reference model in uml2 [message #628285 is a reply to message #628276] Tue, 02 March 2010 08:22 Go to previous messageGo to next message
Ed,
Figured as much, but there are some glitches.
I load a resource from the 'UML editor' menu. Goes well, and I can select from it in the properties window.
However :
- after loading the resource I don't get the oppurtunity to SAVE
- I don't get it in the outline
- After saving (create property for saving), closing and reloading the resource is gone. When loading it again I get
"AXParseException: Content is not allowed in prolog. (http://schema.omg.org/spec/XMI/2.1, 1, 1)".
Using latest Galileo. Resource is an XMI file that has no problems on its own.
I have some problems applying a profile too. The profile is just for adding Stereotypes to the standard UML profile in order to be able to extend and alter the reference model (which is a global standard information model).
After applying a stereotype it doesn't show up.
Are these small bugs?? Or am I doing this myself.
@vlad. Thanks, helpfull.
Best Regards,
Mobius
Re: Using a reference model in uml2 [message #628286 is a reply to message #628285] Tue, 02 March 2010 09:34 Go to previous messageGo to next message
Mobius,
Comments below.
Mobius wrote:
> Ed,
> However : - after loading the resource I don't get the oppurtunity to
> SAVE
Until you change the state of the model, there's nothing to save.
The basic editor doesn't have an outline view (the graphical one does)
but the resource should show up in the list of resources on the main
tab. It does for me.
> resource is gone. When loading it again I get "AXParseException:
> 1, 1)".
I couldn't reproduce that.
> its own.
> information model).
Maybe there are bugs, but you'll need to provide detailed steps to
reproduce them and report them as bugzillas.
> Best Regards,
> Mobius
Re: Using a reference model in uml2 [message #628287 is a reply to message #628276] Tue, 02 March 2010 11:16 Go to previous messageGo to next message
Ed,
In the graphical editor I can import the resource. It becomes selectable and persistant.
I can't open the model in the UML editor though, I still get the previous error.
Question: how do I make a generalization from a class to a class in the reference model?
Best Regards,
Mobius
Re: Using a reference model in uml2 [message #628288 is a reply to message #628287] Tue, 02 March 2010 11:25 Go to previous messageGo to next message
Mobius,
I'm not at all familiar with the graphical editor. Maybe that's a
question for the UML2Tools newsgroup.
Mobius wrote:
> Ed,
> previous error.
> Best Regards,
> Mobius
Re: Using a reference model in uml2 [message #628299 is a reply to message #628276] Thu, 04 March 2010 09:51 Go to previous messageGo to next message
Ed,
Disarmed the parsing error. I loaded a XMI resource exported from Enterprise architect.
This XMI file doesn't have any problems in the UML editor, but as a resource it will give the above mentioned error.
Rename to .uml, move the namespace definitions from the XMI:xmi tag to the uml:model tag and remove all thecustomprofile (from EA) namespace references.
There are some discrepancies between the text and graphical UML editors for which I have asked a question on the UMLtools list.
Best Regards,
Mobius
Re: Using a reference model in uml2 [message #628300 is a reply to message #628276] Thu, 04 March 2010 09:52 Go to previous message
ps. remove the XMI:xmi tags
Previous Topic:Using a reference model in uml2
Next Topic:Re: UML Action Language (UAL) in Eclipse?
Current Time: Wed Jul 23 08:45:46 EDT 2025
Powered by FUDForum. Page generated in 0.73466 seconds
