Home » Archived » Buckminster » is cvs :local method supported?
is cvs :local method supported? [message #628269] Thu, 23 September 2010 06:57 Go to next message
For my texo/teneo build I need to use the local cvs access mode but it seems that this is not supported by buckminster.
I get the error below. Is this indeed correct, or should I use a different reader type?
[java] ERROR [0001] : Rejecting provider
cvs({1},org.eclipse.emf/org.eclipse.emf.texo/features/{0}-fe ature[:local:/cvsroot/modeling,org.eclipse.emf/org.eclipse.e mf.texo/features/org.eclipse.emf.texo.site-feature]):
No component match was found
[java] ERROR Invalid CVS repository location format: :local:/cvsroot/modeling
[java] ERROR Location must have form ':methodname:[user[:password]@]host:[port]/path
[java] ERROR Only the following methods are supported: ext, extssh, pserver, pserverssh2
here is the snippet from the rmap:
<provider componentTypes="eclipse.feature" readerType="cvs" source="true" mutable="false">
<uri format=" {1},org.eclipse.emf/org.eclipse.emf.texo/features/{0}-featur e ">
<bc:propertyRef key="buckminster.component"/>
<bc:propertyRef key="cvs.repository"/>
</uri>
</provider>
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: is cvs :local method supported? [message #628402 is a reply to message #628269] Thu, 23 September 2010 08:06 Go to previous messageGo to next message
Am 23.09.2010 12:57, schrieb Martin Taal:
> seems that this is not supported by buckminster. I get the error below.
Hi Martin,
Buckminster uses the eclipse CVS client and that client does AFAIK not
support the 'local' method to access a CVS repository.
Johannes
Re: is cvs :local method supported? [message #628739 is a reply to message #628402] Thu, 23 September 2010 17:03 Go to previous message
thanks Johannes for your quick help, this clarified things.
gr. Martin
>> Hi,
> Hi Martin,
> Best regards,
> Johannes
The Netherlands
Previous Topic:[Director] unable to install categories that has an comma
Next Topic:Buckminster headless build problems with resolving components
Current Time: Fri Jul 25 19:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.05173 seconds
