Home » Modeling » UML2 » Problems with static profiles in fragment bundle
Problems with static profiles in fragment bundle [message #501650] Thu, 03 December 2009 04:21 Go to next message
Hi all,
i tried to separate the profile.uml model from the static implementation
via Eclipse's fragment bundle mechanism. So i declared the plugin with
the profile.uml as host for the static implementation bundle. The idea
by separating them is to be flexible enough to use one physical
profile.uml file as the foundation for several profile implementations.
For example, if you want to implement a profile for RSA, you have to use
RSA-specific extension points. But they are only available in RSAm not
in a free eclipse distribution for example. That offers me (if it works)
the possibility to modify the profile.uml isolated to a spefific tool.
(Papyrus has also an dedicated extension point for profiles).
But, it seems that it doesn't work with fragments. Currently, i'm not
able to select the generated profile in the UML editor. When i add it
manually in the XMI it is correctly applied, but by trying to add an
stereotype, an exception is thrown:
java.lang.ClassCastException:
org.eclipse.uml2.uml.internal.impl.ProfileImpl cannot be cast to
org.eclipse.emf.ecore.EPackage
at
org.eclipse.uml2.uml.internal.operations.ProfileApplicationO perations.getAppliedDefinition(ProfileApplicationOperations. java:69)
at
org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl.ge tAppliedDefinition(ProfileApplicationImpl.java:311)
at
org.eclipse.uml2.uml.internal.operations.ProfileApplicationO perations.getAppliedDefinition(ProfileApplicationOperations. java:90)
at
org.eclipse.uml2.uml.internal.impl.ProfileApplicationImpl.ge tAppliedDefinition(ProfileApplicationImpl.java:320)
at
org.eclipse.uml2.uml.internal.operations.ElementOperations.g etApplicableStereotypes(ElementOperations.java:1521)
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.getApplicable Stereotypes(ElementImpl.java:525)
at
org.eclipse.uml2.uml.editor.actions.ApplyStereotypeAction.ru n(ApplyStereotypeAction.java:60)
at
org.eclipse.emf.edit.ui.action.CommandAction.runWithEvent(Co mmandAction.java:200)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
It seems as that the implementation is not recognized, or something similar.
Does anyone know what'S going wrong here?
Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #502036 is a reply to message #501650] Fri, 04 December 2009 15:38 Go to previous messageGo to next message
There is an expectation that if there is an EAnnotation under the profile,
then the first reference element under the EAnnotation is the "defined"
profile. If you are using static profile definition, then there shouldn't
be an EAnnotation under your profile. If not, then you should see the
Ecore representation under the EAnnotation.
If possible, please post a small snippet of the "top" part of your profile.
Try removing the EAnnotation under your profile if you are using static
profile defn.
Ensure that the profile is defined if you are not using static profiles.
- James.
"Timothy Marc" <timothymarc@freenet.de> wrote in message
news:hf7vug$1tu$1@build.eclipse.org...
> Hi all,
> via Eclipse's fragment bundle mechanism. So i declared the plugin with the
> profile.uml as host for the static implementation bundle. The idea by
> separating them is to be flexible enough to use one physical profile.uml
> RSA-specific extension points. But they are only available in RSAm not in
> a free eclipse distribution for example. That offers me (if it works) the
> But, it seems that it doesn't work with fragments. Currently, i'm not able
> to select the generated profile in the UML editor. When i add it manually
> in the XMI it is correctly applied, but by trying to add an stereotype, an
> at
> at
> at
> at
> at
> at
> at
> at
> at
> similar.
> Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #502162 is a reply to message #502036] Sun, 06 December 2009 14:29 Go to previous messageGo to next message
Hi James,
no, there is no "defined" annotation, since i use static profile. The
exceptional thing i tried was to separate the host plugin with the
profile model (*.uml) and the plugin with the generated profile code as
fragment.
As mentioned before, when i load the profile manually via "Load
Ressource" it is found, but adding the profile manually as profile
causes this ClassCastException. May this depend on different class
loaders? Do a fragment and host plugin have different class loaders?
Timothy
> profile defn.
> Cheers,
> - James.
>> Hi all,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> similar.
>> Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #502283 is a reply to message #502162] Mon, 07 December 2009 10:23 Go to previous messageGo to next message
If there is no "defined" annotation, then you should not be getting to the
point in the code producing the error.
There is a check for the nsURI not being null before the cast to EPackage.
- James.
news:hfh0n7$pn7$1@build.eclipse.org...
> Hi James,
> exceptional thing i tried was to separate the host plugin with the profile
> model (*.uml) and the plugin with the generated profile code as fragment.
> As mentioned before, when i load the profile manually via "Load Ressource"
> it is found, but adding the profile manually as profile causes this
> ClassCastException. May this depend on different class loaders? Do a
> Timothy
>> profile, then the first reference element under the EAnnotation is the
>> "defined" profile. If you are using static profile definition, then
>> there shouldn't be an EAnnotation under your profile. If not, then you
>> should see the Ecore representation under the EAnnotation.
>> profile.
>> profile defn.
>> Cheers,
>> - James.
>>> Hi all,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> similar.
>>> Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #628106 is a reply to message #501650] Fri, 04 December 2009 15:38 Go to previous messageGo to next message
profile defn.
- James.
> Hi all,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> similar.
> Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #628108 is a reply to message #502036] Sun, 06 December 2009 14:29 Go to previous messageGo to next message
Hi James,
fragment.
Timothy
> profile defn.
> Cheers,
> - James.
>> Hi all,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> similar.
>> Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #628110 is a reply to message #502162] Mon, 07 December 2009 10:23 Go to previous messageGo to next message
- James.
> Hi James,
> Timothy
>> profile.
>> profile defn.
>> Cheers,
>> - James.
>>> Hi all,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> similar.
>>> Thanks Timothy
Re: Problems with static profiles in fragment bundle [message #684273 is a reply to message #501650] Wed, 15 June 2011 06:21 Go to previous message
for all who search desesperately a way to solve the exception:
org.eclipse.uml2.uml.internal.impl.ProfileImpl cannot be cast to org.eclipse.emf.ecore.EPackage
I had this problem using eclipse topcased and acceleo. I found that this exception was due to multiple metamodel references in my model. Effectively, I was importing both profile Standard(UML) and ECore wich both define EPackage element. Thus we have to make a choice. After having removed profile Standard, everything goes fine for my model and the exception is gone (I had this error message each time I click on 'sterotypes' property pane in eclipse-top cased)
maybe this could be usefull for you.
Br,
franck gaspoz
Previous Topic:Applying stereotype on another stereotype?
Next Topic:Would you like to model both the domain layer and UML Objects at the same time ?
Current Time: Sat Jul 26 18:51:46 EDT 2025
Powered by FUDForum. Page generated in 0.05629 seconds
