Home » Modeling » UML2 » Load a XMI file with xmlns:uml tag < 3.0.0
Load a XMI file with xmlns:uml tag < 3.0.0 [message #628026] Wed, 04 November 2009 15:50 Go to next message
can somebody explain how we can load a XMI file with an old xmlns:uml Tag (for example: xmlns:uml="http://www.eclipse.org/uml2/2.2.0/UML) without the gui in an own java application?
Re: Load a XMI file with xmlns:uml tag < 3.0.0 [message #628027 is a reply to message #628026] Thu, 05 November 2009 04:23 Go to previous messageGo to next message
I don't understand the question :blush:
Do you mean that you have a xml coming from an UML model and you would like to create java code or would you like to create graphical views ?
Re: Load a XMI file with xmlns:uml tag < 3.0.0 [message #628028 is a reply to message #628026] Thu, 05 November 2009 06:39 Go to previous messageGo to next message
--------------090801040907010208040102
Maybe the details for "Programmatic Migration" here are similar:
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
HTWTeam wrote:
> Hello,
> Thanks
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Maybe the details for "<span style=""></span>Programmatic
Migration" here are similar:  <br>
<blockquote><a
href=" http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html"> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html</a><br>
</blockquote>
<br>
<br>
HTWTeam wrote:
<blockquote cite="mid:hcspds$hn8$1@build.eclipse.org" type="cite">Hello,
<br>
<br>
Tag (for example: xmlns:uml="<a class="moz-txt-link-freetext" href="http://www.eclipse.org/uml2/2.2.0/UML">http://www.eclipse.org/uml2/2.2.0/UML</a>)
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------090801040907010208040102--
Re: Load a XMI file with xmlns:uml tag < 3.0.0 [message #628030 is a reply to message #628027] Fri, 06 November 2009 05:06 Go to previous messageGo to next message
Vlad Varnica wrote on Thu, 05 November 2009 04:23
Yes, I have a XMI that coming from an UML model. But I don't want to create java code or graphical views rather simple load the XMI model for count all classes in it.
With an new xmi file (3.0.1 uml Tag) it works but older models could not be load.
Ed Merks wrote on Thu, 05 November 2009 06:39
> http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2 0_Migration_Guide/guide.html
I have read it but don't find the methods for programmatic migration.
Re: Load a XMI file with xmlns:uml tag < 3.0.0 [message #628031 is a reply to message #628030] Fri, 06 November 2009 08:45 Go to previous message
--------------060002060803030107000608
When you say you don't find it, are you saying you didn't find the
section like this or it didn't work?
In order to migrate models programmatically, some setup is required
in order to register mappings (already defined by UML). These
mappings will be used by the resource set during the loading stage
and will perform the necessary in-memory migration.
The example below demonstrates how one can migrate models with a
stand-alone application.
>> I don't understand the question :blush: Do you mean that you have a
> not be load.
<html>
<head>
</head>
section like this or it didn't work?<o:p> </o:p>
<blockquote>
<h2><!--[if gte vml 1]><v:shape id="_x0000_i1045" type="#_x0000_t75" alt=""
style='width:9.75pt;height:9.75pt'>
<v:imagedata src="" o:href="http://www.eclipse.org/modeling/mdt/images/new.gif"/>
</v:shape><![endif]--><span
style=""> </span>Programmatic
Migration</h2>
<p class="MsoNormal"><o:p> </o:p><br>
required in order to register mappings (already defined by UML).<span
style="">  </span>These mappings will be used by the resource
set during the loading stage and will perform the necessary in-memory
migration.</p>
<p class="MsoNormal"><o:p> </o:p>The example below demonstrates how
one can <span class="GramE">migrate</span> models with a stand-alone
application.<br>
</p>
</blockquote>
<p class="MsoNormal"><br>
</p>
<br>
<br>
HTWTeam wrote:
<blockquote cite="mid:hd0sf0$tac$1@build.eclipse.org" type="cite">Vlad
<br>
<blockquote type="cite">I don't understand the question  :blush: Do
<br>
</blockquote>
<br>
<br>
<br>
<br>
not be load.
<br>
<br>
<br>
<blockquote type="cite">Maybe the details for "Programmatic
  <a class="moz-txt-link-freetext" href="http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2">http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2</a>.
<br>
</blockquote>
<br>
<br>
</blockquote>
</body>
</html>
--------------060002060803030107000608--
Previous Topic:Load a XMI file with xmlns:uml tag < 3.0.0
Next Topic:[Announce] Eclipse/OMG Symposium 2010
Current Time: Sun Jul 27 09:24:05 EDT 2025
Powered by FUDForum. Page generated in 1.02878 seconds
