Home » Modeling » OCL » Inconsisten Evaluation of OCL Constraint
Inconsisten Evaluation of OCL Constraint [message #62783] Fri, 10 October 2008 10:09 Go to next message
I stumbled across the following peculiar effect. In the following code
snippet two integer variables 'nl' and 'np' (both have value '1') are
compared with the expression 'nl <= np' which should be true obviously.
However, evaluating the expression with query.check() results in false while
ocl.check() returns true. Is this a bug?
Best Regards,
Stephan
Diagram diagram = (Diagram) inputModelResource.getContents().get(0);
OCL ocl = OCL.newInstance();
Helper helper = ocl.createOCLHelper();
helper.setContext(EcorePackage.eINSTANCE.getEObject());
org.eclipse.ocl.expressions.Variable<EClassifier, EParameter> v =
ocl.getEnvironment().getOCLFactory().createVariable();
v.setName("nl");
v.setType(ocl.getEnvironment().getOCLStandardLibrary().getIn teger());
ocl.getEnvironment().addElement(v.getName(), v, true);
ocl.getEvaluationEnvironment().add(v.getName(), 1);
v = ocl.getEnvironment().getOCLFactory().createVariable();
v.setName("np");
try
Constraint oclExpression = helper.createInvariant("nl <= np");
Query query = ocl.createQuery(oclExpression);
Boolean b = query.check(diagram); //Evaluates to false
System.out.println("Query successful.\nResult: " + b.toString());
b = ocl.check(diagram, oclExpression); //Evaluates to true
catch (ParserException e)
System.out.println("Query failed.");
e.printStackTrace();
Re: Inconsisten Evaluation of OCL Constraint [message #62802 is a reply to message #62783] Fri, 10 October 2008 12:58 Go to previous message
Originally posted by: cdamus.zeligsoft.com
Hi, Stephan,
The query.check() invocation is failing with an exception, which results
in an OclInvalid token, which is not equal to the Boolean "true" value,
so the Java method returns "false."
The problem is that the Query object creates its own evaluation
environment, in which you have not provided variable bindings. That's
one of the benefits of the queries: you can create several, assign them
different variable bindings, and evaluate them repeatedly.
HTH,
Christian
Stephan wrote:
> Best Regards,
> Stephan
> v.setName("nl");
> v.setName("np");
> try
Previous Topic:Is there a tutorial on OCL?
Next Topic:[Announce] MDT OCL 1.2.3 M200810101330 is available
Current Time: Wed Nov 05 04:13:29 EST 2025
Powered by FUDForum. Page generated in 0.04068 seconds
