Home » Modeling » UML2 » drawing sequence diagram
drawing sequence diagram [message #486009] Tue, 15 September 2009 17:23 Go to next message
This must be a silly question, but after I draw in a "message" between two
"lifelines", how to I change the visible text over the message arrow?
I tried changing the "name" property of the message, but it does not
display.
My message arrows all have text more or less like: 1: *
Re: drawing sequence diagram [message #486381 is a reply to message #486009] Thu, 17 September 2009 09:34 Go to previous messageGo to next message
... forwarding to UML2 Tools newsgroup.
Although I suspect this is a question specific to UML2 Tools, did you try:
- Select the message, then start typing.
- Select the message, then from the toolbar, select "All Connector Labels"
or "No Connector Labels" to hide or show all labels associated with
connectors.
- James.
"Bruce Frazer" <bfrazer@adobe.com> wrote in message
news:98293f1e4d477181f41f59e1d4cf3f13$1@www.eclipse.org...
> display.
Re: drawing sequence diagram [message #486474 is a reply to message #486381] Thu, 17 September 2009 14:42 Go to previous messageGo to next message
I tried those things - no luck. I'm pretty sure it's because my message is
between two lifelines. Looking at the OMG spec it looks like messages need
to go between actions.
But you can see from my other post that just drawing an action throws
exceptions.
Sequence diagrams - Message name not displayed [message #491953 is a reply to message #486009] Fri, 16 October 2009 13:29 Go to previous message
Hi Bruce,
I'm facing the same problem that you have related here. I filled a bug to get this fixed, bug 292560 - [SequenceDiagram] Message Labels does not display message names (https://bugs.eclipse.org/bugs/show_bug.cgi?id=292560)
This is to help someone that faces this problem and make it easy to follow the development of it.
[]'s
Bruno.
Re: drawing sequence diagram [message #627948 is a reply to message #486009] Thu, 17 September 2009 09:34 Go to previous message
connectors.
- James.
> display.
Re: drawing sequence diagram [message #627951 is a reply to message #486381] Thu, 17 September 2009 14:42 Go to previous message
exceptions.
Sequence diagrams - Message name not displayed [message #627992 is a reply to message #486009] Fri, 16 October 2009 13:29 Go to previous message
Hi Bruce,
[]'s
Bruno.
Previous Topic:UML2 Javadoc
Next Topic:test an integer property
Current Time: Fri Jul 25 06:22:18 EDT 2025
Powered by FUDForum. Page generated in 0.04891 seconds
