Home » Modeling » UML2 » Applying stereotypes
Applying stereotypes [message #478657] Sun, 02 August 2009 02:39 Go to next message
Hello, I am doing my first UML2 profile and have been following the
article below.
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html
It all seems to go well up until the 'Applying Stereotypes' section step 3:
1) Select an element (i.e. <Property> pendingOrders : PurchaseOrder [0..*]
in <Class> Supplier) in the UML editor.
2) Select the UML Editor > Element > Apply Stereotype… menu item.
3) Choose a stereotype (i.e. ecore::EReference), press the Add button,
then press the OK button.
When the dialogue appears with the available choices it is empty!? Hmm, I
have tried it several times and playd around with it and searched the
newsgroup but I can't work it out. I am sure it will be simple as all the
doco states that doing a lightweight extension is easy :)
For what reason could the choices dialogue be empty? I have applied the
profile as per the previous steps in the article.
Thanks in advance
Eban
Re: Applying stereotypes [message #478658 is a reply to message #478657] Mon, 03 August 2009 08:00 Go to previous messageGo to next message
Hi Eban,
Have you applied the profile to the model as described in the previous step?
Do you see a <Profile Application> under the model.
Tas
"Eban Escott" <eban.escott@uqconnect.edu.au> wrote in message
news:fd8d76f91955252da3593d39eb0c29d8$1@www.eclipse.org...
> article below.
> 3:
> Thanks in advance
> Eban
Re: Applying stereotypes [message #478665 is a reply to message #478658] Tue, 04 August 2009 19:19 Go to previous messageGo to next message
Hi Tas, fair question and the answer is yes, I can see the <Profile
Application> with my profile name. Here is a snippet out of my model that
I am trying to apply the profile to ...
<uml:Package xmi:version="2.1"
xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore"
xmlns:uml="http://www.eclipse.org/uml2/3.0.0/UML"
xmi:id="_0_66AHTmEd6IgYzPRYD2Nw" name="InputV">
<profileApplication xmi:id="_itRSgH8tEd6YbOsakxhBTg">
<eAnnotations xmi:id="_itRSgX8tEd6YbOsakxhBTg"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage"
href="../../Profile/model/My.profile.uml#_UKhawX8tEd6YbOsakxhBTg "/>
</eAnnotations>
<appliedProfile
href="../../Profile/model/My.profile.uml#_i9mfcH8rEd6YbOsakxhBTg "/>
</profileApplication>
So, does this look ok? Then I guess the other possible mistake I have made
is in the profile itself. I don't normally like posting masses like this
but here it is ...
<uml:Profile xmi:version="2.1"
xmi:id="_i9mfcH8rEd6YbOsakxhBTg" name="my"
metaclassReference="_Fu--QH8tEd6YbOsakxhBTg">
<eAnnotations xmi:id="_UKhawH8tEd6YbOsakxhBTg"
<contents xmi:type="ecore:EPackage" xmi:id="_UKhawX8tEd6YbOsakxhBTg"
name="my" nsURI="http:///schemas/my/_UKgzsH8tEd6YbOsakxhBTg/0"
nsPrefix="my">
<eClassifiers xmi:type="ecore:EClass"
xmi:id="_UKhawn8tEd6YbOsakxhBTg" name="EStructuralFeature" abstract="true">
<eAnnotations xmi:id="_UKhaw38tEd6YbOsakxhBTg"
references="_BeCi8H8sEd6YbOsakxhBTg"/>
<eStructuralFeatures xmi:type="ecore:EAttribute"
xmi:id="_UKhaxH8tEd6YbOsakxhBTg" name="isTransient" ordered="false"
defaultValueLiteral="true">
<eType xmi:type="ecore:EDataType"
href="http://www.eclipse.org/emf/2002/Ecore#//EBoolean"/>
</eStructuralFeatures>
</eClassifiers>
xmi:id="_UKhaxn8tEd6YbOsakxhBTg" name="EAttribute" abstract="true"
eSuperTypes="_UKhawn8tEd6YbOsakxhBTg">
<eAnnotations xmi:id="_UKhax38tEd6YbOsakxhBTg"
references="_HGeyIH8sEd6YbOsakxhBTg"/>
<eStructuralFeatures xmi:type="ecore:EReference"
xmi:id="_UKhayH8tEd6YbOsakxhBTg" name="base_Property" ordered="false"
lowerBound="1">
<eType xmi:type="ecore:EClass"
href="http://www.eclipse.org/uml2/3.0.0/UML#//Property"/>
</eClassifiers>
xmi:id="_UKhay38tEd6YbOsakxhBTg" name="EReference" abstract="true"
<eAnnotations xmi:id="_UKhazH8tEd6YbOsakxhBTg"
references="_Mk2fUH8sEd6YbOsakxhBTg"/>
xmi:id="_UKhazX8tEd6YbOsakxhBTg" name="base_Property" ordered="false"
lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
<elementImport xmi:id="_3qiBgH8rEd6YbOsakxhBTg">
<importedElement xmi:type="uml:PrimitiveType"
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#Boolea n"/>
</elementImport>
<elementImport xmi:id="_3qiBgX8rEd6YbOsakxhBTg">
href=" pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#String"/>
</elementImport>
<elementImport xmi:id="_Fu--QH8tEd6YbOsakxhBTg">
<importedElement xmi:type="uml:Class"
href="pathmap://UML_METAMODELS/UML.metamodel.uml#Property"/>
</elementImport>
<packagedElement xmi:type="uml:Stereotype"
xmi:id="_BeCi8H8sEd6YbOsakxhBTg" name="EStructuralFeature"
isAbstract="true">
<ownedAttribute xmi:id="_gOf_cH8sEd6YbOsakxhBTg" name="isTransient">
<type xmi:type="uml:PrimitiveType"
<lowerValue xmi:type="uml:LiteralInteger"
xmi:id="_n4PYAH8sEd6YbOsakxhBTg"/>
<defaultValue xmi:type="uml:LiteralBoolean"
xmi:id="_rdIbEH8sEd6YbOsakxhBTg" value="true"/>
</ownedAttribute>
</packagedElement>
xmi:id="_HGeyIH8sEd6YbOsakxhBTg" name="EAttribute" isAbstract="true">
<generalization xmi:id="_SF7iQH8sEd6YbOsakxhBTg"
general="_BeCi8H8sEd6YbOsakxhBTg"/>
<ownedAttribute xmi:id="_NXaIMn8tEd6YbOsakxhBTg" name="base_Property"
association="_NXaIMH8tEd6YbOsakxhBTg">
<type xmi:type="uml:Class"
</ownedAttribute>
</packagedElement>
xmi:id="_Mk2fUH8sEd6YbOsakxhBTg" name="EReference" isAbstract="true">
<generalization xmi:id="_Zz3eUH8sEd6YbOsakxhBTg"
<ownedAttribute xmi:id="_QVkicn8tEd6YbOsakxhBTg" name="base_Property"
association="_QVkicH8tEd6YbOsakxhBTg">
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension"
xmi:id="_NXaIMH8tEd6YbOsakxhBTg" name="Property_EAttribute"
memberEnd="_NXaIMX8tEd6YbOsakxhBTg _NXaIMn8tEd6YbOsakxhBTg">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_NXaIMX8tEd6YbOsakxhBTg"
name="extension_EAttribute" type="_HGeyIH8sEd6YbOsakxhBTg"
aggregation="composite" association="_NXaIMH8tEd6YbOsakxhBTg"/>
</packagedElement>
xmi:id="_QVkicH8tEd6YbOsakxhBTg" name="Property_EReference"
memberEnd="_QVkicX8tEd6YbOsakxhBTg _QVkicn8tEd6YbOsakxhBTg">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="_QVkicX8tEd6YbOsakxhBTg"
name="extension_EReference" type="_Mk2fUH8sEd6YbOsakxhBTg"
aggregation="composite" association="_QVkicH8tEd6YbOsakxhBTg"/>
</packagedElement>
</uml:Profile>
Thanks again Tas!!
Re: Applying stereotypes [message #478666 is a reply to message #478665] Tue, 04 August 2009 19:38 Go to previous messageGo to next message
Eban,
Is the profile in the same location relative to the model when you load
it as when you saved it (after applying the profile)?
Kenn
> that I am trying to apply the profile to ...
> </eAnnotations>
> <appliedProfile
> made is in the profile itself. I don't normally like posting masses like
> this but here it is ...
> nsPrefix="my">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> </elementImport>
> </elementImport>
> </elementImport>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> xmi:id="_NXaIMX8tEd6YbOsakxhBTg" name="extension_EAttribute"
> type="_HGeyIH8sEd6YbOsakxhBTg" aggregation="composite"
> </packagedElement>
> xmi:id="_QVkicX8tEd6YbOsakxhBTg" name="extension_EReference"
> type="_Mk2fUH8sEd6YbOsakxhBTg" aggregation="composite"
> </packagedElement>
> </uml:Profile>
> Thanks again Tas!!
Re: Applying stereotypes [message #478668 is a reply to message #478665] Wed, 05 August 2009 06:05 Go to previous messageGo to next message
Hi Eban,
I think I see the problem. Your EAttribute and EReference stereotypes are
declared as abstract. You need to change isAbstract to false for both those
stereotypes. EStructuralFeature should remain abstract. I think you'll need
to define the profile again and reapply it.
Tas
news:9b04da2e9a22a36f8a66dba47d9ea645$1@www.eclipse.org...
> </eAnnotations>
> <appliedProfile
> but here it is ...
> nsPrefix="my">
> abstract="true">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> </elementImport>
> </elementImport>
> </elementImport>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> Thanks again Tas!!
Re: Applying stereotypes [message #478669 is a reply to message #478668] Wed, 05 August 2009 06:08 Go to previous messageGo to next message
Also, notice that in the UML editor abstract elements appear in italics.
"Tas Frangoullides" <tfrangoullides@model-driven.co.uk> wrote in message
news:h5blhe$29q$1@build.eclipse.org...
> Hi Eban,
> those stereotypes. EStructuralFeature should remain abstract. I think
> you'll need to define the profile again and reapply it.
> Tas
>> </eAnnotations>
>> <appliedProfile
>> <?xml version="1.0" encoding="UTF-8"?>
>> nsPrefix="my">
>> abstract="true">
>> </eClassifiers>
>> lowerBound="1">
>> </eClassifiers>
>> lowerBound="1">
>> </eClassifiers>
>> </contents>
>> </eAnnotations>
>> </elementImport>
>> </elementImport>
>> </elementImport>
>> isAbstract="true">
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </packagedElement>
>> </uml:Profile>
>> Thanks again Tas!!
Re: Applying stereotypes [message #478670 is a reply to message #478666] Wed, 05 August 2009 19:21 Go to previous messageGo to next message
Hey Kenn, I have not moved the profile after defining and saving it. I
have have 2 projects in my workspace, one with the .profile.uml and one
with the .uml.
Firstly, for the .profile.uml I do ...
1. Highlight the <profile> twirl-down
2. UML Editor -> Profile -> Define and it reports operation success
3. I then save it by File -> Save
From within the .uml I do ...
1. UML Editor -> Load Resource -> Choose Browse Workspace
2. Navigate to the other project and choose the .profile.uml (it appears
in the list below the package)
3. Highlight the <Package> twirl-down
4. UML Editor -> Package -> Apply Profile ... add the profile (<Profile
Application> appears)
Is this the correct procedure?
Thanks heaps Kenn for the help.
Eban
Re: Applying stereotypes [message #478671 is a reply to message #478669] Wed, 05 August 2009 19:30 Go to previous messageGo to next message
Hey Tas, I got excited as I thought this could be it ... but no :( I made
the changes and it is still the same. I also downloaded the source code
down the bottom of
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Getti ng_Started_with_UML2/article.html
Inside the zip file is a the profile example I am trying to create but
using a different profile name ... Ecore.profile.uml. I copied this into
my workspace, defined it, saved it, loaded it and still no luck.
I am starting to feel a little stupid as all the doco says applying
stereotypes is easy but I can't seem to get it. Could you maybe try with
the profile from the zip file?
Also, I am stretching here ... but are there any restrictions on what
packaged elements you can apply a stereotype? I am trying to apply a
stereotype to a class.
Thanks heaps!
Eban
Re: Applying stereotypes [message #478672 is a reply to message #478671] Wed, 05 August 2009 19:50 Go to previous messageGo to next message
Tas! I sort of worked it out from my last question to you? I quote from
the tutorial
"stereotypes defined in the profile can be applied to instances of the
appropriate metaclasses (as per the defined extensions)"
So, the stereotypes I created can only be applied to <Property> not
<Class> because of the extension points I use?
I don't fully understand it yet but I can now apply a stereotype from a
profile to a property!!! Sweet.
Thanks for your patience.
Eban
Re: Applying stereotypes [message #479202 is a reply to message #478672] Mon, 10 August 2009 04:44 Go to previous message
Hi Eban,
Sorry for the late reply. I was away on a short vacation.
I'm glad you have it working now. That's right, Profiles are considered a
"Lightweight" extension of the meta-model and you have to decide which parts
of the meta-model to extend. It is possible to have a stereotype extend more
than one metaclass so that the stereotype can be applied on multiple types.
Also, the stereotype can be applied to all sub-classes of the extended
metaclass.
Tas
news:18672070559dba8e9a6e94aa41e3e28a$1@www.eclipse.org...
> the tutorial
> Eban
Re: Applying stereotypes [message #627836 is a reply to message #478657] Mon, 03 August 2009 08:00 Go to previous message
Hi Eban,
Tas
> article below.
> 3:
> Thanks in advance
> Eban
Re: Applying stereotypes [message #627845 is a reply to message #478658] Tue, 04 August 2009 19:19 Go to previous message
</eAnnotations>
<appliedProfile
but here it is ...
nsPrefix="my">
</eClassifiers>
lowerBound="1">
</eClassifiers>
lowerBound="1">
</eClassifiers>
</contents>
</eAnnotations>
</elementImport>
</elementImport>
</elementImport>
isAbstract="true">
</ownedAttribute>
</packagedElement>
</ownedAttribute>
</packagedElement>
</ownedAttribute>
</packagedElement>
</packagedElement>
</packagedElement>
</uml:Profile>
Thanks again Tas!!
Re: Applying stereotypes [message #627846 is a reply to message #478665] Tue, 04 August 2009 19:38 Go to previous message
Eban,
Kenn
> </eAnnotations>
> <appliedProfile
> nsPrefix="my">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> </elementImport>
> </elementImport>
> </elementImport>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> Thanks again Tas!!
Re: Applying stereotypes [message #627848 is a reply to message #478665] Wed, 05 August 2009 06:05 Go to previous message
Hi Eban,
Tas
> </eAnnotations>
> <appliedProfile
> but here it is ...
> nsPrefix="my">
> abstract="true">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> lowerBound="1">
> </eClassifiers>
> </contents>
> </eAnnotations>
> </elementImport>
> </elementImport>
> </elementImport>
> isAbstract="true">
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> Thanks again Tas!!
Re: Applying stereotypes [message #627849 is a reply to message #478668] Wed, 05 August 2009 06:08 Go to previous message
> Hi Eban,
> Tas
>> </eAnnotations>
>> <appliedProfile
>> nsPrefix="my">
>> abstract="true">
>> </eClassifiers>
>> lowerBound="1">
>> </eClassifiers>
>> lowerBound="1">
>> </eClassifiers>
>> </contents>
>> </eAnnotations>
>> </elementImport>
>> </elementImport>
>> </elementImport>
>> isAbstract="true">
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </ownedAttribute>
>> </packagedElement>
>> </packagedElement>
>> </packagedElement>
>> </uml:Profile>
>> Thanks again Tas!!
Re: Applying stereotypes [message #627850 is a reply to message #478666] Wed, 05 August 2009 19:21 Go to previous message
with the .uml.
Eban
Re: Applying stereotypes [message #627851 is a reply to message #478669] Wed, 05 August 2009 19:30 Go to previous message
down the bottom of
Thanks heaps!
Eban
Re: Applying stereotypes [message #627852 is a reply to message #478671] Wed, 05 August 2009 19:50 Go to previous message
the tutorial
Eban
Re: Applying stereotypes [message #627857 is a reply to message #478672] Mon, 10 August 2009 04:44 Go to previous message
Hi Eban,
metaclass.
Tas
> the tutorial
> Eban
Previous Topic:RedefinableTemplateSignature on Operation does not validate
Next Topic:Problems with DerivedUnion during deserialization
Current Time: Wed Oct 29 14:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.50634 seconds
