Home » Modeling » UML2 » UML2 Context Menu
UML2 Context Menu [message #478592] Tue, 07 July 2009 09:04 Go to next message
I would like to add functionality to the UML2 editor context menu.
Can anyone tell me what the target ID is?
Samuel
Re: UML2 Context Menu [message #478593 is a reply to message #478592] Tue, 07 July 2009 09:47 Go to previous messageGo to next message
Hi Samuel,
Have a look at org.eclipse.uml2.uml.editor plugin for
"org.eclipse.uml2.umlMenuID".
Cheers
- James.
"Samuel " <samuel.esposito@gmail.com> wrote in message
news:fb06cd722f61ebd1ef4003c2b17827b3$1@www.eclipse.org...
> I would like to add functionality to the UML2 editor context menu. Can
> Cheers,
> Samuel
Re: UML2 Context Menu [message #478596 is a reply to message #478593] Wed, 08 July 2009 03:09 Go to previous messageGo to next message
Hi James,
I tried to create a ActionBarContributor (see attachment) and hook it
into the UML2 implementation. I initialize it in the 'selectionChanged'
method of my plugin. But it all didn't work. Do you have some more
concrete directions for me about how it should be done. Since I'm a
newbie to UML2, feel free to give a low level explanation.
Samuel
Re: UML2 Context Menu [message #478597 is a reply to message #478596] Wed, 08 July 2009 03:12 Go to previous message
--------------060204090103000100020506
And here is the attachment and the code I use to initialize:
ArchiMateActionBarContributor contributor = new
ArchiMateActionBarContributor();
contributor.init((EditorActionBars) ((PartSite) workbenchPart.getSite())
.getActionBars());
user@domain.invalid wrote:
> Hi James,
> Samuel
name="ArchiMateActionBarContributor.java"
Content-Disposition: inline;
filename="ArchiMateActionBarContributor.java"
package archimate.presentation;
import java.util.ArrayList;
import java.util.Collection;
import java.util.Collections;
import java.util.Iterator;
import java.util.List;
import java.util.Map;
import org.eclipse.core.runtime.IProgressMonitor;
import org.eclipse.emf.common.notify.AdapterFactory;
import org.eclipse.emf.common.ui.viewer.IViewerProvider;
import org.eclipse.emf.common.util.Diagnostic;
import org.eclipse.emf.common.util.DiagnosticChain;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.util.Diagnostician;
import org.eclipse.emf.edit.domain.AdapterFactoryEditingDomain;
import org.eclipse.emf.edit.domain.EditingDomain;
import org.eclipse.emf.edit.domain.IEditingDomainProvider;
import org.eclipse.emf.edit.provider.IItemLabelProvider;
import org.eclipse.emf.edit.ui.EMFEditUIPlugin;
import org.eclipse.emf.edit.ui.action.ControlAction;
import org.eclipse.emf.edit.ui.action.CreateChildAction;
import org.eclipse.emf.edit.ui.action.CreateSiblingAction;
import org.eclipse.emf.edit.ui.action.EditingDomainActionBarContrib utor;
import org.eclipse.emf.edit.ui.action.LoadResourceAction;
import org.eclipse.emf.edit.ui.action.ValidateAction;
import org.eclipse.jface.action.Action;
import org.eclipse.jface.action.ActionContributionItem;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.action.IContributionItem;
import org.eclipse.jface.action.IContributionManager;
import org.eclipse.jface.action.IMenuListener;
import org.eclipse.jface.action.IMenuManager;
import org.eclipse.jface.action.MenuManager;
import org.eclipse.jface.action.Separator;
import org.eclipse.jface.action.SubContributionItem;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.ISelectionChangedListener;
import org.eclipse.jface.viewers.ISelectionProvider;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.jface.viewers.SelectionChangedEvent;
import org.eclipse.jface.viewers.Viewer;
import org.eclipse.ui.IEditorPart;
import org.eclipse.ui.PartInitException;
import org.eclipse.uml2.uml.Element;
import org.eclipse.uml2.uml.editor.UMLEditorPlugin;
import archimate.actions.GenerateCode;
public class ArchiMateActionBarContributor extends
EditingDomainActionBarContributor implements ISelectionChangedListener {
protected GenerateCode generateAction;
* This keeps track of the active editor. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected IEditorPart activeEditorPart;
* This keeps track of the current selection provider. <!-- begin-user-doc
* --> <!-- end-user-doc -->
* @generated
protected ISelectionProvider selectionProvider;
* This action opens the Properties view. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected IAction showPropertiesViewAction = new Action(
UMLEditorPlugin.INSTANCE
.getString("_UI_ShowPropertiesView_menu_item")) //$NON-NLS-1$
public void run() {
try {
getPage().showView("org.eclipse.ui.views.PropertySheet"); //$NON-NLS-1$
} catch (PartInitException exception) {
UMLEditorPlugin.INSTANCE.log(exception);
* This action refreshes the viewer of the current editor if the editor
* implements {@link org.eclipse.emf.common.ui.viewer.IViewerProvider}. <!--
* begin-user-doc --> <!-- end-user-doc -->
* @generated
protected IAction refreshViewerAction = new Action(UMLEditorPlugin.INSTANCE
.getString("_UI_RefreshViewer_menu_item")) //$NON-NLS-1$
public boolean isEnabled() {
return activeEditorPart instanceof IViewerProvider;
public void run() {
if (activeEditorPart instanceof IViewerProvider) {
Viewer viewer = ((IViewerProvider) activeEditorPart)
.getViewer();
if (viewer != null) {
viewer.refresh();
* This will contain one
* {@link org.eclipse.emf.edit.ui.action.CreateChildAction} corresponding to
* each descriptor generated for the current selection by the item provider.
* <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> createChildActions;
* This will contain a map of
* {@link org.eclipse.emf.edit.ui.action.CreateChildAction}s, keyed by
* sub-menu text. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Map<String, Collection<IAction>> createChildSubmenuActions;
* This is the menu manager into which menu contribution items should be
* added for CreateChild actions. <!-- begin-user-doc --> <!-- end-user-doc
* @generated
protected IMenuManager createChildMenuManager;
* {@link org.eclipse.emf.edit.ui.action.CreateSiblingAction} corresponding
* to each descriptor generated for the current selection by the item
* provider. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> createSiblingActions;
* {@link org.eclipse.emf.edit.ui.action.CreateSiblingAction}s, keyed by
* submenu text. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Map<String, Collection<IAction>> createSiblingSubmenuActions;
* added for CreateSibling actions. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected IMenuManager createSiblingMenuManager;
* This creates an instance of the contributor. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated NOT
public ArchiMateActionBarContributor() {
super(ADDITIONS_LAST_STYLE);
loadResourceAction = new LoadResourceAction();
generateAction = new GenerateCode();
controlAction = new ControlAction();
* This adds to the menu bar a menu and some separators for editor additions,
* as well as the sub-menus for object creation items.
* <!-- end-user-doc -->
* @generated
public void contributeToMenu(IMenuManager menuManager) {
super.contributeToMenu(menuManager);
System.out.println(UMLEditorPlugin.INSTANCE
.getString("_UI_UMLEditor_menu"));
IMenuManager submenuManager = new MenuManager(UMLEditorPlugin.INSTANCE
.getString("_UI_UMLEditor_menu"), "org.eclipse.uml2.umlMenuID"); //$NON-NLS-1$ //$NON-NLS-2$
menuManager.insertAfter("additions", submenuManager); //$NON-NLS-1$
submenuManager.add(new Separator("settings")); //$NON-NLS-1$
submenuManager.add(new Separator("actions")); //$NON-NLS-1$
submenuManager.add(new Separator("additions")); //$NON-NLS-1$
submenuManager.add(new Separator("additions-end")); //$NON-NLS-1$
// Prepare for CreateChild item addition or removal.
createChildMenuManager = new MenuManager(UMLEditorPlugin.INSTANCE
.getString("_UI_CreateChild_menu_item")); //$NON-NLS-1$
submenuManager.insertBefore("additions", createChildMenuManager); //$NON-NLS-1$
// Prepare for CreateSibling item addition or removal.
createSiblingMenuManager = new MenuManager(UMLEditorPlugin.INSTANCE
.getString("_UI_CreateSibling_menu_item")); //$NON-NLS-1$
submenuManager.insertBefore("additions", createSiblingMenuManager); //$NON-NLS-1$
// Force an update because Eclipse hides empty menus now.
submenuManager.addMenuListener(new IMenuListener() {
public void menuAboutToShow(IMenuManager menuManager) {
menuManager.updateAll(true);
addGlobalActions(submenuManager);
* When the active editor changes, this remembers the change and registers with it as a selection provider.
* @generated
public void setActiveEditor(IEditorPart part) {
super.setActiveEditor(part);
activeEditorPart = part;
// Switch to the new selection provider.
if (selectionProvider != null) {
selectionProvider.removeSelectionChangedListener(this);
if (part == null) {
selectionProvider = null;
} else {
selectionProvider = part.getSite().getSelectionProvider();
selectionProvider.addSelectionChangedListener(this);
// Fake a selection changed event to update the menus.
if (selectionProvider.getSelection() != null) {
selectionChanged(new SelectionChangedEvent(selectionProvider,
selectionProvider.getSelection()));
* This implements
* {@link org.eclipse.jface.viewers.ISelectionChangedListener}, handling
* {@link org.eclipse.jface.viewers.SelectionChangedEvent}s by querying for
* the children and siblings that can be added to the selected object and
* updating the menus accordingly. <!-- begin-user-doc --> <!-- end-user-doc
* @generated
public void selectionChanged(SelectionChangedEvent event) {
// Remove any menu items for old selection.
if (createChildMenuManager != null) {
depopulateManager(createChildMenuManager, createChildActions);
if (createSiblingMenuManager != null) {
depopulateManager(createSiblingMenuManager, createSiblingActions);
// Query the new selection for appropriate new child/sibling descriptors
Collection<?> newChildDescriptors = null;
Collection<?> newSiblingDescriptors = null;
ISelection selection = event.getSelection();
if (selection instanceof IStructuredSelection
&& ((IStructuredSelection) selection).size() == 1) {
Object object = ((IStructuredSelection) selection)
.getFirstElement();
EditingDomain domain = ((IEditingDomainProvider) activeEditorPart)
.getEditingDomain();
newChildDescriptors = domain.getNewChildDescriptors(object, null);
newSiblingDescriptors = domain.getNewChildDescriptors(null, object);
// Generate actions for selection; populate and redraw the menus.
createChildActions = generateCreateChildActions(newChildDescriptors,
selection);
createSiblingActions = generateCreateSiblingActions(
newSiblingDescriptors, selection);
populateManager(createChildMenuManager, createChildActions, null);
createChildMenuManager.update(true);
populateManager(createSiblingMenuManager, createSiblingActions,
null);
createSiblingMenuManager.update(true);
* This generates a {@link org.eclipse.emf.edit.ui.action.CreateChildAction}
* for each object in <code>descriptors</code>, and returns the collection
* of these actions. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> generateCreateChildActions(
Collection<?> descriptors, ISelection selection) {
Collection<IAction> actions = new ArrayList<IAction>();
if (descriptors != null) {
for (Object descriptor : descriptors) {
actions.add(new CreateChildAction(activeEditorPart, selection,
descriptor));
return actions;
* This generates a
* {@link org.eclipse.emf.edit.ui.action.CreateSiblingAction} for each
* object in <code>descriptors</code>, and returns the collection of these
* actions. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected Collection<IAction> generateCreateSiblingActions(
actions.add(new CreateSiblingAction(activeEditorPart,
selection, descriptor));
return actions;
* This populates the specified <code>manager</code> with
* {@link org.eclipse.jface.action.ActionContributionItem}s based on the
* {@link org.eclipse.jface.action.IAction}s contained in the
* <code>actions</code> collection, by inserting them before the specified
* contribution item <code>contributionID</code>. If
* <code>contributionID</code> is <code>null</code>, they are simply added.
* @generated
protected void populateManager(IContributionManager manager,
Collection<? extends IAction> actions, String contributionID) {
if (actions != null) {
for (IAction action : actions) {
if (contributionID != null) {
manager.insertBefore(contributionID, action);
} else {
manager.add(action);
* This removes from the specified <code>manager</code> all
* <code>actions</code> collection. <!-- begin-user-doc --> <!--
* end-user-doc -->
* @generated
protected void depopulateManager(IContributionManager manager,
Collection<? extends IAction> actions) {
IContributionItem[] items = manager.getItems();
for (int i = 0; i < items.length; i++) {
// Look into SubContributionItems
IContributionItem contributionItem = items[i];
while (contributionItem instanceof SubContributionItem) {
contributionItem = ((SubContributionItem) contributionItem)
.getInnerItem();
// Delete the ActionContributionItems with matching action.
if (contributionItem instanceof ActionContributionItem) {
IAction action = ((ActionContributionItem) contributionItem)
.getAction();
if (actions.contains(action)) {
manager.remove(contributionItem);
* This populates the pop-up menu before it appears. <!-- begin-user-doc -->
* @generated
super.menuAboutToShow(menuManager);
MenuManager submenuManager = null;
populateManager(submenuManager, createChildActions, null);
menuManager.insertBefore("edit", submenuManager); //$NON-NLS-1$
populateManager(submenuManager, createSiblingActions, null);
* This inserts global actions before the "additions-end" separator. <!--
* @generated
protected void addGlobalActions(IMenuManager menuManager) {
String key = (style & ADDITIONS_LAST_STYLE) == 0 ? "additions-end" : "additions";
if (controlAction != null)
menuManager.insertBefore(key, new ActionContributionItem(controlAction));
* This ensures that a delete action will clean up all references to deleted
* objects. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
protected boolean removeAllReferencesOnDelete() {
return true;
--------------060204090103000100020506--
Re: UML2 Context Menu [message #627774 is a reply to message #478592] Tue, 07 July 2009 09:47 Go to previous message
Hi Samuel,
Cheers
- James.
> Cheers,
> Samuel
Re: UML2 Context Menu [message #627777 is a reply to message #478593] Wed, 08 July 2009 03:09 Go to previous message
Hi James,
Samuel
Re: UML2 Context Menu [message #627778 is a reply to message #478596] Wed, 08 July 2009 03:12 Go to previous message
.getActionBars());
> Hi James,
> Samuel
* end-user-doc -->
* @generated
* @generated
* end-user-doc -->
* @generated
public void run() {
try {
* @generated
public void run() {
.getViewer();
viewer.refresh();
* @generated
* @generated
* @generated
* @generated
* @generated
* end-user-doc -->
* @generated
* end-user-doc -->
* @generated NOT
* @generated
* @generated
if (part == null) {
} else {
* This implements
* @generated
.getFirstElement();
selection);
null);
* @generated
descriptor));
return actions;
* This generates a
* @generated
return actions;
* @generated
} else {
* end-user-doc -->
* @generated
.getInnerItem();
.getAction();
* @generated
* @generated
* @generated
return true;
Previous Topic:Class templates and associations
Next Topic:Stereotype and Properties
Current Time: Wed Jul 23 11:24:16 EDT 2025
Powered by FUDForum. Page generated in 0.07598 seconds
