Home » Modeling » UML2 » Re: The definitive truth about multiple inheritance
Re: The definitive truth about multiple inheritance [message #478583] |
Thu, 02 July 2009 17:53  |
Guillaume,
The UML project has an extended GenModel and has specialized some of the
templates for generating the code. Perhaps that's part of what's going
on...
I do have UML installed, so if you export to a zip the project with your
model, I should be able to reproduce what you're seeing and determine if
there's a bug in how EOperations are handled in a multiple inheritance
scenario...
I suspect that you need to use UML's extended GenModel if you extend the
UML model. I've added the UML2 newsgroup to the "to"list of the reply
for their comments about how one should extend UML2...
Guillaume Vauvert wrote:
> Ed,
> Ed Merks a écrit :
>>> So :
>>> - A inherits from Action
>>> - C inherits from Class
>> Class is a bit of a confusing name.
>>> - D inherits from both A and C
>>> So simple when it is clear !
>>> The generated code :
>>> - the class DImpl extends the class AImpl : it is OK.
>>> - the class DImpl implements the interface D ; the interface D
>>> extends the interface A and the interface C.
>>> - the class DImpl inherits methods from AImpl : so it implements
>>> the interface A;
>>> - the class DImpl contains methods that are declared in the
>>> interface C ;
>>> - BUT DImpl does not contain methods that are inherited by the
>>> interface C from the interface Class.
>> Did you declare all these methods in Ecore's version of Class? I'm
>> suspicious about that name...
> I am building a Modeling Language that extends UML.
> I am using platform:/plugin/org.eclipse.uml2.uml/model/UML.core as
> model of UML.
> The metaclass Class (using ECore) declares the EOperation
> "ownedOperation".
> In the generated class DImpl, I obtain a class that should contains
> the implementation of getOwnedReception() (from the interface C).
> Instead, I have a class DImpl that lacks this method ; so, Eclipse
> Java IDE saids :
> "The type DImpl must implement the inherited abstract method
> Class.getOwnedReception(String, EList<String>, EList<Type>)"
>>> And do you see a solution ... ?
>> I'd suggest you provide an example model that I can use to reproduce
>> the problem. Then I can tell you if the problem is your model or in
>> the framework.
> Even if my example is exactly what I descrived before, I can provide
> it, but how (future generations of newsgroups users must be able to
> see the model !) ?
> I feel the light closer ...
> Thanks !
> Guillaume Vauvert
> http://www.ixmas.org
Re: The definitive truth about multiple inheritance [message #478588 is a reply to message #478583] |
Sat, 04 July 2009 05:10   |
--------------040407050404070808060007
Guillaume,
This definitely sounds UML specific. Try using the text editor to
replace this
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel"
with this
xmlns:genmodel="http://www.eclipse.org/uml2/2.2.0/GenModel"
I.e., trying changing it to be the UML project's derived GenModel. That
should ensure that UML's generator specializations kick in.
Also, try avoid doing reply-all on newsgroup postings so they don't also
end up in my personal in-box. :-P
Try to avoid doing reply-all
> Hello MDT/UML2 users,
> I had a question on model code generation, but, thanks to Ed, I now
> believe that the question is more MDT/UML2 specific.
> The model contains a class TempleteableActivityNode that inherits from
> both the class Templeteable and the class ActivityNode. The class
> ActivityNode contains the attribute "incoming" with multiplicty 0..* .
> This attribute "incoming" is implemented in ActivityNodeImpl as :
> public EList<ActivityEdge> getIncomings()
> and as :
> public ActivityEdge getIncoming(String name)
> In the generated model code class TempleteableActivityNode, the method
> "public EList<ActivityEdge> getIncomings()" is implemented, but not
> the method "public ActivityEdge getIncoming(String name)", what leads
> to an error :
> "The type TempleteableActivityNodeImpl must implement the inherited
> abstract method ActivityNode.getIncoming(String)"
> Have you an idea of where I am wrong ?
> Thank you ...
> Guillaume Vauvert
> Thanks you Ed for your help : you guide me to investigate more deeply
> my problem.
> Ed Merks a
Re: The definitive truth about multiple inheritance [message #478589 is a reply to message #478583] |
Sat, 04 July 2009 06:38  |
and as :
"public EList<ActivityEdge> getIncomings()" is implemented, but not the
method "public ActivityEdge getIncoming(String name)", what leads to an
error :
Thank you ...
Guillaume Vauvert
my problem.
Ed Merks a écrit :
> Guillaume,
the templates for generating the code. Perhaps that's part of what's
going on...
your model, I should be able to reproduce what you're seeing and
determine if there's a bug in how EOperations are handled in a multiple
inheritance scenario...
the UML model. I've added the UML2 newsgroup to the "to"list of the
reply for their comments about how one should extend UML2...
>> Ed,
>> Ed Merks a écrit :
>>>> So :
implements the interface A;
interface C ;
model of UML.
"ownedOperation".
Instead, I have a class DImpl that lacks this method ; so, Eclipse Java
IDE saids :
reproduce the problem. Then I can tell you if the problem is your model
or in the framework.
it, but how (future generations of newsgroups users must be able to see
the model !) ?
>> Thanks !
>> Guillaume Vauvert
Re: The definitive truth about multiple inheritance [message #627769 is a reply to message #478583] |
Guillaume,
replace this
with this
> and as :
> to an error :
> Thank you ...
> Guillaume Vauvert
> my problem.
> Ed Merks a
Re: The definitive truth about multiple inheritance [message #627770 is a reply to message #478583] |
and as :
error :
Thank you ...
Guillaume Vauvert
my problem.
Ed Merks a écrit :
> Guillaume,
going on...
>> Ed,
>> Ed Merks a écrit :
>>>> So :
interface C ;
model of UML.
"ownedOperation".
IDE saids :
the model !) ?
>> Thanks !
>> Guillaume Vauvert
Current Time: Tue Jul 22 22:58:38 EDT 2025
Powered by FUDForum. Page generated in 0.03615 seconds
