assigning a default value to an inherited property [message #478439] |
Wed, 20 May 2009 10:43  |
I am using uml2 and I have a problem with assigning a default value to an
inherited property.
In my uml model I have a class A with a property a. In a class B, which is
a child of A I would like to assign a default value for the property a. In
class B I use the same name for the property a.
When I try to generate the EMF model I get a warning "Discarded feature
'B::a' because it is a duplicate of inherited feature 'A::a'".
If I set the "Redefined Property" of B::a to point to A::a it is even
worse because I get an additional warning: "Feature 'B::a' should be
annotated as redefintion of feature 'A::a'".
Obviously when I generate a java code on the basis of my model the default
value is not assigned to the property a of class B.
Any idea how I could assign a default value to the property a of the class
B?
regards,
Szymon
Re: assigning a default value to an inherited property [message #478507 is a reply to message #478491] |
Tue, 09 June 2009 11:47  |
Szymon,
I can't recall off-hand whether the templates support re-initializing the
field to a different default, but if they don't, I don't see why they
couldn't. If you open a Bugzilla request, we'll look into it.
Kenn
"Szymon " <szymekf@hotmail.com> wrote in message
news:e2791546c2863097b8d15421e58dea6c$1@www.eclipse.org...
> Hi Kenn,
> Thank you for the answer. I tried this and Eclipse generated java code.
> However, the default value is not assigned in the inherited property. Is
> this correct?
> regards,
> Szymon
Re: assigning a default value to an inherited property [message #627648 is a reply to message #478439] |
Thu, 28 May 2009 15:20  |
Szymon,
If you set the option for redefined properties to "Process" instead of
"Report", you won't encounter those warnings, and you'll get the (limited)
support that the UML2 code generator provides for redefined properties.
Kenn
news:607f76dabb58577be18551411e1d55a0$1@www.eclipse.org...
> inherited property.
> 'B::a' because it is a duplicate of inherited feature 'A::a'". If I set
> the "Redefined Property" of B::a to point to A::a it is even worse
> because I get an additional warning: "Feature 'B::a' should be annotated
> B?
> regards,
> Szymon
Re: assigning a default value to an inherited property [message #627684 is a reply to message #478491] |
Szymon,
Kenn
> Hi Kenn,
> this correct?
> regards,
> Szymon
FUDForum. Page generated in 0.04124 seconds
