Home » Modeling » UML2 » problems with pathmap
problems with pathmap [message #478291] Wed, 08 April 2009 11:49 Go to next message
Hello all,
I am stucked ...
I am trying to add a profile called MyProfile.profile.uml to the pathmap
by adding the following extension to plugin.xml
<extension point="org.eclipse.emf.ecore.uri_mapping">
<mapping source="pathmap://MY_PROFILES/"
target="platform:/plugin/designer.umlext.editor/my_profiles ">
</mapping>
</extension>
When I try to load the profile I do something like this:
Resource inputResource = resourceSet.createResource(
URI.createURI("pathmap://MY_PROFILES/MyProfile.profile.uml"));
try {
inputResource.load(null); ####
}catch (IOException exception) {
exception.printStackTrace();
,but I keep getting "java.net.MalformedURLException: unknown protocol:
pathmap" exception at ####
Can someone help me by explaining what could the sources of this error?
Thanks in advance!
Re: problems with pathmap [message #478293 is a reply to message #478291] Wed, 08 April 2009 15:56 Go to previous messageGo to next message
Check this:
http://www.eclipsezone.com/eclipse/forums/m92226705.html
Lucian
Sorin Fagateanu wrote:
> Hello all,
> I am stucked ...
> </mapping>
> </extension>
> try {
> Thanks in advance!
Re: problems with pathmap [message #478295 is a reply to message #478293] Thu, 09 April 2009 06:34 Go to previous messageGo to next message
Thank you Lucian,I have read that article ,but I have more questions.
Now I am updating the pathmap like this:
Map uriMap = resourceSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI("pathmap://MY_PROFILES/"),
uri.appendSegment("my_profiles").appendSegment(""));
My question is why do I have to add into the pathmap manualy and why the
extension "org.eclipse.emf.ecore.uri_mapping" isn't sufficient to
automaticaly add to pathmap.
At the moment in my plugin.xml I have only the extension
"org.eclipse.emf.ecore.uri_mapping".Are there necessar other extensions or
other code?
Sorin
Re: problems with pathmap [message #478296 is a reply to message #478295] Thu, 09 April 2009 11:01 Go to previous messageGo to next message
Sorin,
That is only required if your code runs in a standalone Java application.
If your code runs in an Eclipse application, that is not needed, the
markup in plugin.xml should be enough.
Which one is the case?
See:
EMF FAQ: http://tinyurl.com/d72o47
UML FAQ: http://tinyurl.com/ce4p4u
Rafael
http://abstratt.com/blog/
> or other code?
> Sorin
Re: problems with pathmap [message #478395 is a reply to message #478296] Fri, 15 May 2009 04:43 Go to previous message
The error was that
target="platform:/plugin/designer.umlext.editor/my_profiles "> needed an extra
"/" at the end.
Re: problems with pathmap [message #627483 is a reply to message #478291] Wed, 08 April 2009 15:56 Go to previous message
Check this:
Lucian
> Hello all,
> I am stucked ...
> </mapping>
> </extension>
> try {
> Thanks in advance!
Re: problems with pathmap [message #627485 is a reply to message #478293] Thu, 09 April 2009 06:34 Go to previous message
other code?
Sorin
Re: problems with pathmap [message #627486 is a reply to message #478295] Thu, 09 April 2009 11:01 Go to previous message
Sorin,
See:
Rafael
> or other code?
> Sorin
Re: problems with pathmap [message #627582 is a reply to message #478296] Fri, 15 May 2009 04:43 Go to previous message
The error was that
"/" at the end.
Previous Topic:Sequence Diagram
Next Topic:How to access the Property values of a Stereotype?
Current Time: Wed Jul 23 14:12:53 EDT 2025
Powered by FUDForum. Page generated in 0.04660 seconds
