Home » Eclipse Projects » Remote Application Platform (RAP) » List listener problem
List listener problem [message #62723] Sat, 24 November 2007 15:45 Go to next message
i've added a Selection listener to a List; if i select some components
on the List, and invoking the method List.getSelection in the
implemented listener, it returns no items selected. Can be a bug?
here the code
list = new List(sectionClient2, SWT.MULTI | SWT.V_SCROLL | SWT.H_SCROLL
| SWT.BORDER);
list.add("item");
list.add("item2");
list.addListener(SWT.Selection,listener);
public final class MyListener implements Listener {
public void handleEvent(Event arg0) {
System.out.println(arg0);
String[] ele = list.getSelection();
for (int i = 0; i < ele.length; i++) {
System.out.println(ele[i]);
thx
Christian
Re: List listener problem [message #62746 is a reply to message #62723] Sun, 25 November 2007 05:10 Go to previous messageGo to next message
I have ran your example and indeed it did not work, but that on the
1.0.1 integration build.
If u use release version 1.0 it works just fine.
Also the demo application does not work fine regarding list selection,
when using version 1.0.1
Val
Christian wrote:
> here the code
> | SWT.BORDER);
> list.add("item");
> list.add("item2");
> thx
> Christian
Re: List listener problem [message #62821 is a reply to message #62746] Sun, 25 November 2007 08:18 Go to previous messageGo to next message
Val,
Thanks for your answer. Do you think I should open a bug for this
version?Or realese version 1.1 will contain this bug fixed anyway?
Christian
Val ha scritto:
> Hi
> Cheers,
> Val
> Christian wrote:
>> Hi,
>> here the code
>> | SWT.BORDER);
>> list.add("item");
>> list.add("item2");
>> thx
>> Christian
Re: List listener problem [message #62853 is a reply to message #62821] Sun, 25 November 2007 09:32 Go to previous message
yes I think u should open a bug report for that version. Also mention
that in the demo application the list selection does not work properly.
ciao,
Val
Christian wrote:
> Val,
> Christian
> Val ha scritto:
>> Hi
>> Cheers,
>> Val
>> Christian wrote:
>>> Hi,
>>> here the code
>>> | SWT.BORDER);
>>> list.add("item");
>>> list.add("item2");
>>> thx
>>> Christian
Previous Topic:Contextual menu on a custom widget
Next Topic:Generate RAP from RCP application
Current Time: Fri Nov 07 05:19:26 EST 2025
Powered by FUDForum. Page generated in 0.03670 seconds
