Home » Modeling » UML2 » How can I generate code from my UML model using Eclipse?
How can I generate code from my UML model using Eclipse? [message #477746] Thu, 25 September 2008 05:00 Go to next message
Hello.
The UML2 FAQ states under "Can I generate code from my UML model?":
[...]Once you have an EMF representation of your model, you can, of
course, generate code from it using EMF.
Is that still the standard way to do it, exporting the whole thing to
ecore? I made an UML diagram using the UML tools and now want to generate
code from it.
I searched the internet for some time, but there seems to be no direct
answer to the simple beginner question:
"How can I generate code from my UML model using Eclipse?"
Re: How can I generate code from my UML model using Eclipse? [message #477747 is a reply to message #477746] Thu, 25 September 2008 07:19 Go to previous messageGo to next message
--------------050508070107000305020902
Jens,
This tutorial shows how to generate code from an XML Schema:
< http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html>
The same steps, but choosing early in the wizard that you want to load
from UML as opposed to XML Schema, should do the trick.
Jens wrote:
> Hello.
> generate code from it.
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Jens,<br>
<br>
This tutorial shows how to generate code from an XML Schema:<a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html"><br>
</a>
<blockquote><a
href=" http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html"> http://help.eclipse.org/ganymede/index.jsp?topic=/org.eclips e.emf.doc/tutorials/xlibmod/xlibmod.html</a><br>
</blockquote>
from UML as opposed to XML Schema, should do the trick.<br>
<br>
<br>
Jens wrote:
<blockquote
cite="mid:7c21c292d5e417ce4fbedca36abd59dd$1@www.eclipse.org"
type="cite">Hello.
<br>
<br>
<br>
course, generate code from it using EMF. <br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
--------------050508070107000305020902--
Re: How can I generate code from my UML model using Eclipse? [message #477748 is a reply to message #477747] Thu, 25 September 2008 09:08 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Ed, Jens,
Importing your genmodel from UML gives you the benefit of certain
codegen extensions provided by UML2 to handle metamodeling constructs of
CMOF that EMOF (hence Ecore) does not implement: subsetting and
redefinition. Also, a handy foreign-method pattern for implementing
operations.
Say, Ed, on that subject: UML2's operations pattern is not UML-specific
but is quite convenient for models that employ multiple inheritance.
Have you considered adopting that pattern into EMF's codegen?
Christian
Ed Merks wrote:
> Jens,
> Jens wrote:
>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #477749 is a reply to message #477748] Thu, 25 September 2008 09:56 Go to previous messageGo to next message
I just updated the FAQ with these destails - Thanks Christian and Ed!
-James.
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:gbg2h4$dks$1@build.eclipse.org...
> Hi, Ed, Jens,
> Importing your genmodel from UML gives you the benefit of certain codegen
> extensions provided by UML2 to handle metamodeling constructs of CMOF that
> EMOF (hence Ecore) does not implement: subsetting and redefinition.
> Also, a handy foreign-method pattern for implementing operations.
> but is quite convenient for models that employ multiple inheritance. Have
> Cheers,
> Christian
> Ed Merks wrote:
>> Jens,
>> Jens wrote:
>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #477750 is a reply to message #477748] Thu, 25 September 2008 09:55 Go to previous messageGo to next message
Christian,
I'm not sure what you mean by the operations pattern? Is this something
to do with defining static methods and delegating to them? (EMF
supports operations with bodies that handles multiple inheritance quite
reasonably...)
Christian W. Damus wrote:
> Hi, Ed, Jens,
> of CMOF that EMOF (hence Ecore) does not implement: subsetting and
> operations.
> UML-specific but is quite convenient for models that employ multiple
> inheritance. Have you considered adopting that pattern into EMF's
> codegen?
> Cheers,
> Christian
> Ed Merks wrote:
>> Jens,
>> load from UML as opposed to XML Schema, should do the trick.
>> Jens wrote:
>>> Hello.
>>> to ecore? I made an UML diagram using the UML tools and now want to
>>> direct answer to the simple beginner question:
Re: How can I generate code from my UML model using Eclipse? [message #477751 is a reply to message #477750] Thu, 25 September 2008 10:16 Go to previous messageGo to next message
Hi, Ed,
Yes, that's what I was referring to. It serves the need of localizing
changes to a single implementation and also helps "purists" to keep Java
code out of their models. :-P
cW
Ed Merks wrote:
> Christian,
> reasonably...)
>> Hi, Ed, Jens,
>> operations.
>> codegen?
>> Cheers,
>> Christian
>> Ed Merks wrote:
>>> Jens,
>>> Jens wrote:
>>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #477752 is a reply to message #477749] Thu, 25 September 2008 10:24 Go to previous messageGo to next message
Oo! Great.
I forgot to mention, also, the support for caching derived properties
using the CacheAdapter. I used to complain about the CacheAdapter a
lot, but I've really warmed to it of late. I'm a convert. :-)
cW
> -James.
>> Hi, Ed, Jens,
>> Cheers,
>> Christian
>> Ed Merks wrote:
>>> Jens,
>>> Jens wrote:
>>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #477753 is a reply to message #477751] Thu, 25 September 2008 10:31 Go to previous messageGo to next message
Christian,
If it were an option, and someone else did all the work to
enable/support it, I'd consider that.
> Hi, Ed,
> Java code out of their models. :-P
> cW
> Ed Merks wrote:
>> Christian,
>> something to do with defining static methods and delegating to them?
>> (EMF supports operations with bodies that handles multiple
>> inheritance quite reasonably...)
>>> Hi, Ed, Jens,
>>> constructs of CMOF that EMOF (hence Ecore) does not implement:
>>> subsetting and redefinition. Also, a handy foreign-method pattern
>>> codegen?
>>> Cheers,
>>> Christian
>>> Ed Merks wrote:
>>>> Jens,
>>>> Jens wrote:
>>>>> Hello.
>>>>> of course, generate code from it using EMF.
>>>>> to generate code from it.
Re: How can I generate code from my UML model using Eclipse? [message #477754 is a reply to message #477753] Thu, 25 September 2008 10:41 Go to previous messageGo to next message
Hi, Ed,
That's cool. Maybe James is interested in promoting some code out of
UML2? Otherwise, I can take a look at refactoring the templates. I
think I may be sufficiently motivated ta make the effort. :-) I will
probably come back to the newsgroup with questions.
cW
Ed Merks wrote:
> Christian,
>> Hi, Ed,
>> cW
-----8<-----
Re: How can I generate code from my UML model using Eclipse? [message #477756 is a reply to message #477747] Thu, 25 September 2008 15:35 Go to previous message
Thanks a lot. Now I can generate java code from my UML diagram.
Re: How can I generate code from my UML model using Eclipse? [message #626946 is a reply to message #477746] Thu, 25 September 2008 07:19 Go to previous message
Jens,
Jens wrote:
> Hello.
<html>
<head>
<title></title>
</head>
Jens,<br>
<br>
</a>
<blockquote><a
</blockquote>
<br>
<br>
Jens wrote:
<blockquote
type="cite">Hello.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
</body>
</html>
Re: How can I generate code from my UML model using Eclipse? [message #626947 is a reply to message #477747] Thu, 25 September 2008 09:08 Go to previous message
Hi, Ed, Jens,
operations.
Christian
Ed Merks wrote:
> Jens,
> Jens wrote:
>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #626948 is a reply to message #477748] Thu, 25 September 2008 09:56 Go to previous message
-James.
> Hi, Ed, Jens,
> Cheers,
> Christian
> Ed Merks wrote:
>> Jens,
>> Jens wrote:
>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #626949 is a reply to message #477748] Thu, 25 September 2008 09:55 Go to previous message
Christian,
reasonably...)
> Hi, Ed, Jens,
> operations.
> codegen?
> Cheers,
> Christian
> Ed Merks wrote:
>> Jens,
>> Jens wrote:
>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #626950 is a reply to message #477750] Thu, 25 September 2008 10:16 Go to previous message
Hi, Ed,
cW
Ed Merks wrote:
> Christian,
> reasonably...)
>> Hi, Ed, Jens,
>> operations.
>> codegen?
>> Cheers,
>> Christian
>> Ed Merks wrote:
>>> Jens,
>>> Jens wrote:
>>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #626951 is a reply to message #477749] Thu, 25 September 2008 10:24 Go to previous message
Oo! Great.
cW
> -James.
>> Hi, Ed, Jens,
>> Cheers,
>> Christian
>> Ed Merks wrote:
>>> Jens,
>>> Jens wrote:
>>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #626952 is a reply to message #477751] Thu, 25 September 2008 10:31 Go to previous message
Christian,
> Hi, Ed,
> cW
> Ed Merks wrote:
>> Christian,
>>> Hi, Ed, Jens,
>>> codegen?
>>> Cheers,
>>> Christian
>>> Ed Merks wrote:
>>>> Jens,
>>>> Jens wrote:
>>>>> Hello.
Re: How can I generate code from my UML model using Eclipse? [message #626953 is a reply to message #477753] Thu, 25 September 2008 10:41 Go to previous message
Hi, Ed,
cW
Ed Merks wrote:
> Christian,
>> Hi, Ed,
>> cW
-----8<-----
Re: How can I generate code from my UML model using Eclipse? [message #626955 is a reply to message #477747] Thu, 25 September 2008 15:35 Go to previous message
Previous Topic:How can I generate code from my UML model using Eclipse?
Next Topic:Missing serialized package: uml.ecore
Current Time: Sun Jul 27 04:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.11800 seconds
