[CDO/Net4j] how to use PostgreSQL driver support? [message #626135] |
Wed, 22 September 2010 08:11  |
I would like to use CDO together with PostgreSQL. I've found Victor Roldan Betancort provided initial implementation for the "postgresql" driver. However, this code seems to not be provided in helios repository. I've found it hosted on sf.net and tried to update from http://net4j.sourceforge.net/update -- which seems to install plugin sources but not plugin binaries. My first question is: is there anywhere plugin in binary form available ready for installation into Eclipse? If not, then is there any exact set of steps which need to be performed in order to get working plugin from the plugin sources (exactly postgresql db adapter sources, i.e. plugin: org.eclipse.net4j.db.postgresql.source_3.0.0.v20100614-1656. jar
Thanks!
Karel
FUDForum. Page generated in 0.08496 seconds
