Home » Modeling » UML2 » static profiles with model libraries
static profiles with model libraries [message #477429] Fri, 23 May 2008 10:54 Go to next message
Originally posted by: huascar.espinoza.cea.com
Hi all,
I'm building a static profile that imports a model library. The model
library has been implemented in a separated file/model. I was wondering
about the best way to organize the static profile taking into account that
the imported model library has some packages that apply the profile itself!
There is not a circular reference at package level, but the files (profile
and model library) are mutually dependent.
More concretely, I'd like to know from experienced people on static profiles
the best organization to avoid conflicts. Separated
projects/plugins/packages for the profile and the library?
Thank you in advance,
Huascar ESPINOZA, Ph.D.
CEA LIST
Model-Driven Engineering for Real-Time Embedded Systems
91191 GIF/YVETTE CEDEX
Phone/Fax: +33 1 69 08 45 87 / 20 82
FRANCE
Re: static profiles with model libraries [message #477457 is a reply to message #477429] Wed, 28 May 2008 10:08 Go to previous message
Hi Huascar,
I think you will be on the cutting edge in terms of using static profile
definition so you may not receive many replies to your posting.
If I understand the configuration of your project, you have some profile
(for which you are generating code), then you have a library which uses the
profile (that library would be reused elsewhere). You also mention that
the profile and model library are mutually dependent.
It's difficult to speculate on how best to arrange such a project. You
might consider splitting the dependency if it is causing you issues and
separating out sections of the profile (although I'm not sure if creating 2
profiles would make sense in your case ).
I'm eager to hear how this is working out for you and your experiences.
Please let us know if you discover any pitfalls or errors that you cannot
get around.
- James.
"Huascar Espinoza" <huascar.espinoza@cea.com> wrote in message
news:g16lqt$d8p$1@build.eclipse.org...
> Hi all,
> itself! There is not a circular reference at package level, but the files
> (profile and model library) are mutually dependent.
> profiles the best organization to avoid conflicts. Separated
> CEA LIST
> FRANCE
Re: static profiles with model libraries [message #626639 is a reply to message #477429] Wed, 28 May 2008 10:08 Go to previous message
Hi Huascar,
get around.
- James.
> Hi all,
> CEA LIST
> FRANCE
Previous Topic:Re: Amalgamate Models
Next Topic:Creating an AssociationClass
Current Time: Wed Jul 23 16:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.04000 seconds
