Home » Modeling » UML2 » Import and traverse UML2
Import and traverse UML2 [message #626599] Wed, 21 May 2008 06:12
Hi all,
i'm new to UML2 and EMF programming, but have to dive deeper into it. So
my first approach was to load an UML2 Use Case model (created with
Eclipse UML2.1 diagrams).
Resource.Factory.Registry reg = Resource.Factory.Registry.INSTANCE; Map
m = reg.getExtensionToFactoryMap();
m.put("uml", UMLResource.Factory.INSTANCE);
ResourceSet resSet=new ResourceSetImpl();
Resource res = resSet.getResource(URI.createURI("file:///F:/TFH
Flo/SE/workspace/JET_1/model/bibO.uml"),true);
Therefore, I registeres the UML2Factory and the file extension as
mentioned above. That works fine.
But how to get access to the Use Cases i have modeled inside. Alle the
contents of the Resource are AnyTypeImpl-Objects?
Thx
tm
Previous Topic:apply stereotype problem with static profile
Next Topic:Re: provide a model with a plugin
Current Time: Fri Aug 29 15:48:46 EDT 2025
Powered by FUDForum. Page generated in 0.03908 seconds
