Home » Modeling » UML2 » Problem with Property Redefinition and Subsetting
Problem with Property Redefinition and Subsetting [message #477383] |
Wed, 14 May 2008 13:48  |
Originally posted by: cdamus.zeligsoft.com
I have redefined properties, thus:
class A
- property u1 [0..1] {derived union}
class B -> A
- property p1 [1] {subsets u1}
class C -> B
- property p2 [1] {redefines p1}
If, given an instance 'c' of C, I to
c.setP2(somevalue)
and subsequently do
c.getU1()
I get a null result. If, instead, I had first done
c.setP1(somevalue)
I would have got the expected result from the getU1() call.
The reason why this is happening is that the implementation of getU1()
is in the BImpl class; C does not override it. getU1() checks whether
p1 is set (eIsSet method), which does not consider the fact that it may
be implicitly set by p2 having been set.
Does this sound right?
I am using UML2 2.1.1 release.
Re: Problem with Property Redefinition and Subsetting [message #477385 is a reply to message #477383] |
Wed, 14 May 2008 14:13   |
Hi Christian,
At first glance, this does not seem to be a correct implementation.
Please raise a defect.
- James.
"Christian W. Damus" <cdamus@zeligsoft.com> wrote in message
news:g0f8kk$3gc$1@build.eclipse.org...
> class A
> class B -> A
> class C -> B
> c.setP2(somevalue)
> and subsequently do
> c.getU1()
> c.setP1(somevalue)
> The reason why this is happening is that the implementation of getU1() is
> in the BImpl class; C does not override it. getU1() checks whether p1 is
> set (eIsSet method), which does not consider the fact that it may be
Re: Problem with Property Redefinition and Subsetting [message #477391 is a reply to message #477384] |
Fri, 16 May 2008 20:11   |
Christian,
Redefinition in UML follows replacement semantics, so yes, you would have to
re-specify on p2 all of the characteristics you wish it to have (including
the fact that it subsets u1).
Kenn
news:g0f9al$bdl$1@build.eclipse.org...
>A little more detail:
> The BImpl::basicGetU1() method checks eIsSet(p1) and delegates to super if
> not.
> The p2 redefinition of p1 would be completed by generating a
> CImpl::basicGetU1() method that checks eIsSet(p2) and delegates to super
> (i.e., BImpl::basicGetU1() method) if not.
> It seems that the subset-ness of the redefined property needs to be
> re-specified on the redefining property in my source model?
> Cheers,
> Christian
>> class A
>> class B -> A
>> class C -> B
>> c.setP2(somevalue)
>> and subsequently do
>> c.getU1()
>> c.setP1(somevalue)
Re: Problem with Property Redefinition and Subsetting [message #477392 is a reply to message #477385] |
Fri, 16 May 2008 20:12   |
James,
I'm not convinced this is a defect, actually - see my reply to Christian.
Kenn
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:g0fa4e$kn4$1@build.eclipse.org...
> Hi Christian,
> Cheers,
> - James.
>> class A
>> class B -> A
>> class C -> B
>> c.setP2(somevalue)
>> and subsequently do
>> c.getU1()
>> c.setP1(somevalue)
Re: Problem with Property Redefinition and Subsetting [message #477396 is a reply to message #477391] |
Sun, 18 May 2008 14:09  |
Thanks, Kenn.
That is exactly how I "worked around" the problem in my model, by
re-specifying the subsetted property.
Glad to know it's not actually a work-around!
cW
On Friday 05-16-2008 (08:11), Kenn Hussey wrote:
> Christian,
> have to re-specify on p2 all of the characteristics you wish it to
> have (including the fact that it subsets u1).
> Kenn
>> super if not.
>> super (i.e., BImpl::basicGetU1() method) if not.
>> be re-specified on the redefining property in my source model?
>> Cheers,
>> Christian
>>> class A
>>> class B -> A
>>> class C -> B
>>> c.setP2(somevalue)
>>> and subsequently do
>>> c.getU1()
>>> c.setP1(somevalue)
>>> getU1() is in the BImpl class; C does not override it. getU1()
>>> checks whether p1 is set (eIsSet method), which does not consider
>>> the fact that it may be implicitly set by p2 having been set.
I'm trying a new usenet client for Mac, Nemo OS X.
You can download it at http://www.malcom-mac.com/nemo
Re: Problem with Property Redefinition and Subsetting [message #626563 is a reply to message #477383] |
Wed, 14 May 2008 13:59  |
if not.
Christian
> class A
> class B -> A
> class C -> B
> c.setP2(somevalue)
> and subsequently do
> c.getU1()
> c.setP1(somevalue)
Re: Problem with Property Redefinition and Subsetting [message #626564 is a reply to message #477383] |
Hi Christian,
- James.
> class A
> class B -> A
> class C -> B
> c.setP2(somevalue)
> and subsequently do
> c.getU1()
> c.setP1(somevalue)
Re: Problem with Property Redefinition and Subsetting [message #626570 is a reply to message #477384] |
Christian,
Kenn
> not.
> Cheers,
> Christian
>> class A
>> class B -> A
>> class C -> B
>> c.setP2(somevalue)
>> and subsequently do
>> c.getU1()
>> c.setP1(somevalue)
Re: Problem with Property Redefinition and Subsetting [message #626571 is a reply to message #477385] |
James,
Kenn
> Hi Christian,
> Cheers,
> - James.
>> class A
>> class B -> A
>> class C -> B
>> c.setP2(somevalue)
>> and subsequently do
>> c.getU1()
>> c.setP1(somevalue)
Re: Problem with Property Redefinition and Subsetting [message #626578 is a reply to message #477391] |
Thanks, Kenn.
cW
> Christian,
> Kenn
>> super if not.
>> Cheers,
>> Christian
>>> class A
>>> class B -> A
>>> class C -> B
>>> c.setP2(somevalue)
>>> and subsequently do
>>> c.getU1()
>>> c.setP1(somevalue)
Current Time: Wed Jul 23 02:04:06 EDT 2025
Powered by FUDForum. Page generated in 0.06317 seconds
