Home » Modeling » UML2 » Derived property getter in Static Profile
Derived property getter in Static Profile [message #477259] |
Wed, 16 April 2008 18:17  |
After code generation for a static profile, getters for derived
properties contains this comment :
// The list is expected to implement
org.eclipse.emf.ecore.util.InternalEList and
org.eclipse.emf.ecore.EStructuralFeature.Setting
// so it's likely that an appropriate subclass of
org.eclipse.emf.ecore.util.EcoreEList should be used.
How should I implement such EcoreEList ?
regards,
Yann
Re: Derived property getter in Static Profile [message #477264 is a reply to message #477263] |
Thu, 17 April 2008 12:05   |
The question concerns a UML profile for SysML.
In SysML the stereotype Requirement (extending Class) has two properties :
/ derived : Requirement [*] --> {public, isDerived = true}
/ derivedFrom : Requirement [*] --> {public, isDerived = true}
Requirements can be linked with DeriveReqt (a stereotype that inherits
from Standard::Trace).
The expected values for derived properties are defined in SysML spec:
• /derived:
Derived from all requirements that are the client of a «deriveReqt»
relationship for which this requirement is a supplier.
• /derivedFrom:
Derived from all requirements that are the supplier of a «deriveReqt»
relationship for which this requirement is a client.
The genmodel settings are default setting, except the fact that I
changed the "Base Package" namespace for model code generation.
The generated code is the following :
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @generated
public EList<Requirement> getDerived() {
// TODO: implement this method to return the 'Derived' reference list
// Ensure that you remove @generated or mark it @generated NOT
throw new UnsupportedOperationException();
* @generated
public EList<Requirement> getDerivedFrom() {
// TODO: implement this method to return the 'Derived From' reference list
I have implemented these getters, and the properties values are
correctly updated when I use the profile in my UML modeler.
The problem comes after saving/reopening the model, I get some
org.eclipse.emf.ecore.xmi.IllegalValueException.
In the getter implementation I return a BasicInternalEList<Requirement>,
which implements InternalEList but not EStructuralFeature.Setting.
That's why I am looking for a way to return some kind of EcoreEList
instead of BasicInternalEList.
James Bruck a écrit :
> Hi Yann,
> Can you provide a few more details please:
> 1. What are the property settings in the UML model.
> 2. What are the genmodel settings.
> 3. What is the exact function being produced.
> 4. How will the property in question derive its value?
> There might be something subtle that is being overlooked?
> Cheers,
> - James.
> "Yann Tanguy" <yann.tanguy@cea.fr> wrote in message
> news:fu5tts$ad5$1@build.eclipse.org...
>> After code generation for a static profile, getters for derived properties
>> regards,
>> Yann
Re: Derived property getter in Static Profile [message #477268 is a reply to message #477264] |
Fri, 18 April 2008 05:53   |
It appears that the exception I get during model opening is caused by a
null pointer in my getters.
The null pointer comes from "base_Class" or calls to
"base_Class_getClientDependencies()" returning null, maybe because the
getter is used while the model is not fully loaded ?
> • /derived:
> • /derivedFrom:
> * @generated
> * @generated
> reference list
>> Hi Yann,
>> Cheers,
>> - James.
>>> regards,
>>> Yann
Re: Derived property getter in Static Profile [message #477278 is a reply to message #477277] |
Mon, 21 April 2008 18:53   |
Thanks a lot Kenn.
You were right the "transient" property was set to false.
Switching it to true solved my problem.
Maybe this should be done systematically by UML to ECORE converter for
derived properties ?
Yann.
Kenn Hussey a écrit :
> Yann,
> Generally speaking, your derived features should not need to be computed
> while a resource is being loaded... is this what is happening? Have you
> ensure that your derived features are also transient (generally speaking,
> they should be)?
> Kenn
> news:fu9r23$k0i$1@build.eclipse.org...
>>> • /derived:
>>> • /derivedFrom:
>>> The genmodel settings are default setting, except the fact that I changed
>>> * @generated
>>> * @generated
>>> list
>>> I have implemented these getters, and the properties values are correctly
>>>> Hi Yann,
>>>> Cheers,
>>>> - James.
>>>>> regards,
>>>>> Yann
Re: Derived property getter in Static Profile [message #477279 is a reply to message #477278] |
Tue, 22 April 2008 08:37  |
Yann,
Not all derived properties are necessarily always transient, so the
converter doesn't make the assumption that they are...
Kenn
news:fuj5th$19m$1@build.eclipse.org...
> Thanks a lot Kenn.
> Yann.
> Kenn Hussey a
Re: Derived property getter in Static Profile [message #626420 is a reply to message #477259] |
Thu, 17 April 2008 09:17  |
Hi Yann,
- James.
> regards,
> Yann
Re: Derived property getter in Static Profile [message #626421 is a reply to message #477263] |
• /derived:
• /derivedFrom:
* @generated
* @generated
> Hi Yann,
> Cheers,
> - James.
>> regards,
>> Yann
Re: Derived property getter in Static Profile [message #626425 is a reply to message #477264] |
> • /derived:
> • /derivedFrom:
> * @generated
> * @generated
> reference list
>> Hi Yann,
>> Cheers,
>> - James.
>>> regards,
>>> Yann
Re: Derived property getter in Static Profile [message #626434 is a reply to message #477259] |
Mon, 21 April 2008 13:10  |
Yann,
The org.eclipse.uml2.common plug-in provides a number of list
implementations that are useful when implementing derived features, most
notably DerivedEObjectEList and DerivedUnionEObjectEList. If you take a look
at how these lists (and their subclasses) are using in the UML2 API
implementation, you should be able to get a feel for how they might be
applicable in your code.
Kenn
> regards,
> Yann
Re: Derived property getter in Static Profile [message #626435 is a reply to message #477268] |
Mon, 21 April 2008 13:14  |
Yann,
they should be)?
Kenn
> Yann Tanguy a
Re: Derived property getter in Static Profile [message #626436 is a reply to message #477277] |
Thanks a lot Kenn.
Yann.
> Yann,
> they should be)?
> Kenn
>>> • /derived:
>>> • /derivedFrom:
>>> * @generated
>>> * @generated
>>> list
>>>> Hi Yann,
>>>> Cheers,
>>>> - James.
>>>>> regards,
>>>>> Yann
Re: Derived property getter in Static Profile [message #626437 is a reply to message #477278] |
Yann,
Kenn
> Thanks a lot Kenn.
> Yann.
> Kenn Hussey a
Current Time: Sun Aug 31 16:22:47 EDT 2025
Powered by FUDForum. Page generated in 0.11490 seconds
