Home » Modeling » UML2 » New features of UML2 - Generics, ... (EclipseCon 2008)
New features of UML2 - Generics, ... (EclipseCon 2008) [message #477157] Fri, 28 March 2008 10:14 Go to next message
Originally posted by: ekkehard.gentz-software.de
at EclipseCon2008 I visited this session from James Bruck.
I didn't found the presentation as download -
is it anywhere to find ?
thanks
ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477166 is a reply to message #477157] Mon, 31 March 2008 14:18 Go to previous messageGo to next message
Hi Ekke,
I tried to reply with the presentation attached but it seems that I exceeded
the posting size limit.
I will post the long talk, tutorial and OMG presentation on the UML2 Wiki
shortly.
(The presentation was #170 and the tutorial was #172 at EclipseCon2008)
You can also get it from here:
https://eclipsecon.greenmeetingsystems.com/submissions/view/ 170
Thanks for coming out!
- James.
"ekke" <ekkehard@gentz-software.de> wrote in message
news:a81624f3bb3342e0b1be64c810fc16aa$1@www.eclipse.org...
> thanks
> ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477167 is a reply to message #477166] Mon, 31 March 2008 17:31 Go to previous messageGo to next message
Hi James,
thanks for the info - just downloaded.
(BTW: before I looked at the wrong place:
http://www.eclipsecon.org/2008/?page=sub/&id=170)
ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477168 is a reply to message #477166] Tue, 01 April 2008 16:57 Go to previous messageGo to next message
Originally posted by: comouraf-lixo.yahoo.fr
Hi, James,
Somehow I couldn't go to the end of the static profile definition example
from your presentation. After having generated the sources, I added the
....uml2.uml.generated_package extension to the plugin.xml (of the model
related plugin). But this extension point does not offer the options "uri"
and "location", as seen in the figure. All it permits is to add a new
"generic", which offers a text field called "body". What did I do wrong?
César
"James Bruck" <jbruck@ca.ibm.com> a écrit dans le message de
news:fsr9vt$n3t$3@build.eclipse.org...
> Hi Ekke,
> exceeded the posting size limit.
> shortly.
> - James.
>> thanks
>> ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477173 is a reply to message #477168] Wed, 02 April 2008 09:23 Go to previous messageGo to next message
Hi C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477178 is a reply to message #477173] Wed, 02 April 2008 17:36 Go to previous messageGo to next message
------=_NextPart_000_0017_01C8951A.700C6D10
Content-Type: text/plain;
format=flowed;
charset="iso-8859-1";
reply-type=response
Hi, James,
I think there must be something wrong but with my eclipse installation,
since the extension point generated_package from the uml2 plugin is not
being correctly accessed. I can see it in the list of extension points, but
its schema is not accessible (e.g. if I click on the link "open extension
point schema" or "show extension point description" for example, I get an
error message reporting that both schema and description cannot be found).
If I do the same to the generated_package extension point from the ecore, it
works fine.
So I'm sure there is a problem, but I don't know exactly what it is. :-(
Thank you anyway,
C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477180 is a reply to message #477178] Thu, 03 April 2008 10:20 Go to previous messageGo to next message
What version of UML are you using?
Try with the latest M6 version.
- James.
"kaiserlautern" <comouraf-lixo@yahoo.fr> wrote in message
news:ft0ua5$54f$1@build.eclipse.org...
> Hi, James,
> but
> it
> works fine.
> Thank you anyway,
> C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #477184 is a reply to message #477180] Thu, 03 April 2008 13:00 Go to previous message
That's it. Wrong version only. Thanks, James.
César
> - James.
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626308 is a reply to message #477157] Mon, 31 March 2008 14:18 Go to previous message
Hi Ekke,
shortly.
- James.
> thanks
> ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626309 is a reply to message #477166] Mon, 31 March 2008 17:31 Go to previous message
Hi James,
ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626310 is a reply to message #477166] Tue, 01 April 2008 16:57 Go to previous message
Hi, James,
César
> Hi Ekke,
> shortly.
> - James.
>> thanks
>> ekke
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626333 is a reply to message #477168] Wed, 02 April 2008 09:23 Go to previous message
Hi C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626338 is a reply to message #477173] Wed, 02 April 2008 17:36 Go to previous message
format=flowed;
reply-type=response
Hi, James,
works fine.
Thank you anyway,
C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626340 is a reply to message #477178] Thu, 03 April 2008 10:20 Go to previous message
- James.
> Hi, James,
> but
> it
> works fine.
> Thank you anyway,
> C
Re: New features of UML2 - Generics, ... (EclipseCon 2008) [message #626344 is a reply to message #477180] Thu, 03 April 2008 13:00 Go to previous message
César
> - James.
Previous Topic:How to represent dependency model with UML2
Next Topic:Use profile UML
Current Time: Sun Aug 31 10:23:09 EDT 2025
Powered by FUDForum. Page generated in 0.04713 seconds
