Home » Modeling » UML2 » how to setSource&setTarget for ControlFlow in Activity??
how to setSource&setTarget for ControlFlow in Activity?? [message #477072] |
Tue, 11 March 2008 23:23  |
Hi all,
I am creating a ControlFlow in Activity Diagram programmatically,
the codes are:
ActionModel am1=new ActionModel();
ActionModel am2=new ActionModel();
org.eclipse.uml2.uml.ControlFlow controlFlow=(ControlFlow)
activity.createEdge(name, UMLPackage.Literals.CONTROL_FLOW);
controlFlow.setSource(am1);
controlFlow.setTarget(am2);
But,the code can't run successfully.I am not very familiar with the UML2
API,so I want the correct code.
Thank you very much! I am appreciated your reply.
-xiaoqiang
Re: how to setSource&setTarget for ControlFlow in Activity?? [message #477086 is a reply to message #477084] |
Wed, 12 March 2008 21:22   |
James Bruck 写道:
> What's an 'ActionModel' ? is it an ActivityNode?
> If so then your code should work. What is the error you are running into?
> - James.
> "xiaoqiang" <jqzhao1985@gmail.com> wrote in message
> news:fr7ias$fns$1@build.eclipse.org...
>> Hi all,
>> the codes are:
>> -xiaoqiang
Hi James,
Thank you very much for caring for my question.
Now,'ActionModel' is not an ActivityNode.
I need to set both the ControlFlow's source and target be an action,so,I
want to know the relationship between 'org.eclipse.uml2.uml.Action'
and 'org.eclipse.uml2.uml.ActivityNode'.
Thanks.
-xiaoqiang
Re: how to setSource&setTarget for ControlFlow in Activity?? [message #477087 is a reply to message #477086] |
Wed, 12 March 2008 21:40  |
xiaoqiang 写道:
> James Bruck 写道:
>> - James.
>>> Hi all,
>>> the codes are:
>>> -xiaoqiang
> Hi James,
> Thanks.
> -xiaoqiang
Hi James,
I have solved this problem by getNode(String name).
I am extremely grateful to you.Thanks to eclipse newsgroup.
Cheers.
-xiaoqiang
Re: how to setSource&setTarget for ControlFlow in Activity?? [message #626211 is a reply to message #477072] |
Wed, 12 March 2008 15:04  |
- James.
> Hi all,
> the codes are:
> -xiaoqiang
Re: how to setSource&setTarget for ControlFlow in Activity?? [message #626214 is a reply to message #477084] |
James Bruck 写道:
> - James.
>> Hi all,
>> the codes are:
>> -xiaoqiang
Hi James,
Thanks.
-xiaoqiang
Re: how to setSource&setTarget for ControlFlow in Activity?? [message #626216 is a reply to message #477086] |
xiaoqiang 写道:
> James Bruck 写道:
>> - James.
>>> Hi all,
>>> the codes are:
>>> -xiaoqiang
> Hi James,
> Thanks.
> -xiaoqiang
Hi James,
Cheers.
-xiaoqiang
Current Time: Mon Jul 21 00:03:20 EDT 2025
Powered by FUDForum. Page generated in 0.04883 seconds
