| Home » Modeling » OCL » Visibility of interface operations to implementing classifiers
 Goto Forum:|
| Visibility of interface operations to implementing classifiers [message #62619] | Wed, 08 October 2008 16:23  |  |
| Eclipse User  |  |  |  |  | Should interface operations be visible to their implementing classifiers in OCL?
 I'm using MDT OCL 1.2.0.  I have a UML model containing Interface I with
 a query operation <(param:I):Boolean, and a Class T that realizes I (but
 does not own a corresponding query operation <(param:I):Boolean).
 Another Class C has two attributes a1:T and a2:T.  Using the OCL
 Interpreter Example (evaluating for UML at the M1 modeling level), I
 find that the following expression:
 self.a1 < self.a2
 fails to parse with the error: Cannot find operation (<(T)) for the type (T)
 Is this the correct behaviour?  I've verified that this same expression
 parses without errors in MDT OCL 1.1.2.
 Linda
| Re: Visibility of interface operations to implementing classifiers [message #62643 is a reply to message #62619] | Wed, 08 October 2008 16:39   |  |
| Eclipse User  |  |  |  |  | Originally posted by: cdamus.zeligsoft.com
 Hi, Linda,
 Does the class T happen to define an operation like this?
 compareTo(T) : Integer
 Or, does T correspond to an EClass whose instanceClass is of some
 java.lang.Comparable type?  In either case, the 1.1.x release would
 infer the <(T):Boolean operation even if it wasn't defined.  This is a
 Java-ism that isn't applicable to OCL, so the 1.2 release corected that
 by no longer making this inference.  However, the 1.2 API does allow you
 to restore the 1.1 behaviour by setting the
 ParserOptions.USE_COMPARE_TO_OPERATION option.  Try using the
 ParserOption.setOption(...) method to set this option on your
 environment before you parse (the root environment of your
 org.eclipse.ocl.OCL façade is a good choice).
 In any case, the Interface thing is a red herring.  Classes don't
 inherit features from the interfaces that they implement, so OCL won't
 see a < operation in T unless T defines one or inherits it from another
 class.  Our UML binding has always respected that.
 HTH,
 Christian
 > in OCL?
 > self.a1 < self.a2
 > (T)
 > Linda
| Re: Visibility of interface operations to implementing classifiers [message #62668 is a reply to message #62643] | Thu, 09 October 2008 09:57   |  |
| Eclipse User  |  |  |  |  | This is a multi-part message in MIME format. --------------060200070408020004030700
 T does not have any operations, actually. Nor does it correspond to an
 EClass whose instanceClass is a java.lang.Comparable.  I'm not sure why
 the 1.1.2 release was able to see the < operation from the interface.
 Given that classes don't inherit features from interfaces, is it because
 of a defect that has subsequently been fixed in the 1.2.0 release?
 I've attached a project that contains my .uml model, in case it helps to
 clarify what I'm doing.
 Linda
 Christian W. Damus wrote:
 > Hi, Linda,
| Re: Visibility of interface operations to implementing classifiers [message #62740 is a reply to message #62668] | Thu, 09 October 2008 13:59   |  |
 Hi, Linda,
 Thanks for the attachment.  I debugged it and have surprised myself.
 The OCL 1.1 release has a bug, which evidently was fixed in 1.2 though I
 don't remember it.  In 1.1, the OclAny type from the OCL Standard
 Library has all of the comparison operations <, <=, >, >=.  This is at
 odds with the OCL 2.0 specification, which defines only = and <> in the
 OclAny context.
 So, in 1.1.x, *all* types in the user model to have the comparison
 operations imposed upon them.  Happily, the 1.2 release fixes that :-)
 Christian
 > Linda
 >> Hi, Linda,
 >> that by no longer making this inference.  However, the 1.2 API does
 >> allow you to restore the 1.1 behaviour by setting the
 >> another class.  Our UML binding has always respected that.
 >> HTH,
 >> Christian
 >>> classifiers in OCL?
 >>> with a query operation <(param:I):Boolean, and a Class T that
 >>> realizes I (but does not own a corresponding query operation
 >>> <(param:I):Boolean). Another Class C has two attributes a1:T and
 >>> a2:T.  Using the OCL Interpreter Example (evaluating for UML at the
 >>> M1 modeling level), I find that the following expression:
 >>> self.a1 < self.a2
 >>> type (T)
 >>> expression parses without errors in MDT OCL 1.1.2.
 >>> Thanks,
 >>> Linda
| Re: Visibility of interface operations to implementing classifiers [message #63113 is a reply to message #62740] | Tue, 14 October 2008 09:31   |  |
| Eclipse User  |  |  |  |  | In MDT OCL 1.2.0, I see that implementation of OCLStandardLibraryUtil#createAnyTypeOperations still seems to return <,
 >, <= and >=.  Is that correct?
 Linda
 > Hi, Linda,
 > OclAny context.
 > Cheers,
 > Christian
 >> why the 1.1.2 release was able to see the < operation from the
 >> interface. Given that classes don't inherit features from interfaces,
 >> is it because of a defect that has subsequently been fixed in the
 >> 1.2.0 release?
 >> to clarify what I'm doing.
 >> Thanks,
 >> Linda
 >>> Hi, Linda,
 >>> a Java-ism that isn't applicable to OCL, so the 1.2 release corected
 >>> won't see a < operation in T unless T defines one or inherits it from
 >>> HTH,
 >>> Christian
 >>>> classifiers in OCL?
 >>>> self.a1 < self.a2
 >>>> type (T)
 >>>> Thanks,
 >>>> Linda
| Re: Visibility of interface operations to implementing classifiers [message #63152 is a reply to message #63113] | Tue, 14 October 2008 09:57  |  |
 Hi, Linda,
 This is necessary in order to enable the compatibility option, which
 restores the former (incorrect) behaviour.  An OCL 2.0 release would
 remove them.
 The OCLStandardLibraryUtil class should not be used by clients.  The
 @noreference tag defined by the PDE API Tools should be used to indicate
 that (it isn't, currently).  The exception to this rule is implementers
 of metamodel bindings, but this API is only used in generating the OCL
 Standard Library package, which otherwise is loaded by de-serialization
 at run-time.
 Christian
 > Linda
 >> Hi, Linda,
 >> I don't remember it.  In 1.1, the OclAny type from the OCL Standard
 >> the OclAny context.
 >> Cheers,
 >> Christian
 >>> an EClass whose instanceClass is a java.lang.Comparable.  I'm not
 >>> sure why the 1.1.2 release was able to see the < operation from the
 >>> 1.2.0 release?
 >>> Thanks,
 >>> Linda
 >>>> Hi, Linda,
 >>>> from another class.  Our UML binding has always respected that.
 >>>> HTH,
 >>>> Christian
 >>>>> classifiers in OCL?
 >>>>> self.a1 < self.a2
 >>>>> type (T)
 >>>>> Thanks,
 >>>>> Linda
 Current Time: Thu Oct 30 22:56:25 EDT 2025
 Powered by FUDForum . Page generated in 0.03518 seconds |
