Home » Modeling » UML2 » Problems with profile "file:" URI in UML Model Editor
Problems with profile "file:" URI in UML Model Editor [message #477057] Tue, 11 March 2008 08:48 Go to next message
Originally posted by: ebadgley.mitre.org
Greetings,
I'm working on an Eclipse "translator" plugin project that will take a model
encapsulated in a custom Microsoft Access DB and translate it into a UML2
model in Eclipse. The plugin loads a custom profile programmatically,
creates the model and all the elements (applying stereotypes and setting
tagged values from the profile as appropriate), and finally saves the model
to the designated folder in the workspace. The final model can then be
viewed in Eclipse using the UML Model Editor or similar.
All of that is working perfectly well so far. The problem I am having is
occurring when I try to change the URI scheme by which I locate the profile.
By default, the plugin accesses the profile using a "platform:/" URI
(profiles for the translator are stored within their own plugin). I would
like to have an alternative option to use a "file:/" URI to locate the
profile, because the output model is sometimes loaded into an external UML
editor (VP-UML, to be specific) and of course the "platform:" URI doesn't
mean anything to that tool. (The model loads fine in the external editor,
but because the original profile file is not accessible, certain aspects of
the stereotype definition are not loaded. I have been working with Visual
Paradigm to clarify the requirements.)
I can get the "file:" URI for the profile's location, and when I pass it to
the translator, it works just fine-- the profile can be loaded from that URI
and applied to the model. The problem occurs when I then try to open the
model in the UML Model Editor in Eclipse: when the model is opened/expanded,
I get an "Error" message. The problem is that the "href" for the profile is
getting saved incorrectly, as evidenced by the following:
<profileApplication xmi:id="_rEJLLe9oEdyqitgWLuaR9g">
<eAnnotations xmi:id="_rEJLLu9oEdyqitgWLuaR9g"
source="http://www.eclipse.org/uml2/2.0.0/UML">
<references xmi:type="ecore:EPackage"
href=" ../../../../../../../../eclipseNew/eclipse/configuration/org .eclipse.osgi/bundles/614/1/.cp/profiles/NAS.profile.uml#_XD N8YbTEEdyfbZc0xZIVvQ "/>
</eAnnotations>
<appliedProfile
href=" ../../../../../../../../eclipseNew/eclipse/configuration/org .eclipse.osgi/bundles/614/1/.cp/profiles/NAS.profile.uml#_0 "/>
</profileApplication>
As you can see from the "../../../../../..", the URIs are getting garbled
when the profile URI is stored in the model.
Any thoughts or suggestions on what may be going wrong and how to avoid it
would be greatly appreciated. I am not that knowledgeable about URL/URI
handling in Eclipse and I may well be doing something wrong. I'll be happy
to provide further information or code snippets on request.
Re: Problems with profile "file:" URI in UML Model Editor [message #477060 is a reply to message #477057] Tue, 11 March 2008 13:52 Go to previous messageGo to next message
Hi Ellen,
Have you tried creating a uri mapping .. something like this:
<extension
point="org.eclipse.emf.ecore.uri_mapping">
<mapping
source="pathmap://MY_PROFILES/"
target="platform:/plugin/a.b.c.d/model/">
</mapping>
</extension>
When you next try to refer to your profile you can use something like :
pathmap://MY_PROFILES/MyProfile.profile.uml
This might help?
Cheers
- James
"Ellen Badgley" <ebadgley@mitre.org> wrote in message
news:fr5v2s$hf8$1@build.eclipse.org...
> Greetings,
> model encapsulated in a custom Microsoft Access DB and translate it into a
> UML2 model in Eclipse. The plugin loads a custom profile
> programmatically, creates the model and all the elements (applying
> stereotypes and setting tagged values from the profile as appropriate),
> and finally saves the model to the designated folder in the workspace.
> The final model can then be viewed in Eclipse using the UML Model Editor
> or similar.
> profile. By default, the plugin accesses the profile using a "platform:/"
> URI (profiles for the translator are stored within their own plugin). I
> would like to have an alternative option to use a "file:/" URI to locate
> the profile, because the output model is sometimes loaded into an external
> UML editor (VP-UML, to be specific) and of course the "platform:" URI
> doesn't mean anything to that tool. (The model loads fine in the external
> editor, but because the original profile file is not accessible, certain
> aspects of the stereotype definition are not loaded. I have been working
> with Visual Paradigm to clarify the requirements.)
> to the translator, it works just fine-- the profile can be loaded from
> that URI and applied to the model. The problem occurs when I then try to
> open the model in the UML Model Editor in Eclipse: when the model is
> opened/expanded, I get an "Error" message. The problem is that the "href"
> for the profile is getting saved incorrectly, as evidenced by the
> following:
> </eAnnotations>
> <appliedProfile
> happy to provide further information or code snippets on request.
Re: Problems with profile "file:" URI in UML Model Editor [message #477065 is a reply to message #477060] Tue, 11 March 2008 14:37 Go to previous messageGo to next message
I did some experimenting with pathmaps a while back and was not able to get
them to work successfully, but I will try again. Thanks for the advice.
- Ellen
"James Bruck" <jbruck@ca.ibm.com> wrote in message
news:fr6gsn$i4e$2@build.eclipse.org...
> Hi Ellen,
> <extension
> <mapping
> </mapping>
> </extension>
> This might help?
> Cheers
> - James
>> Greetings,
>> a UML2 model in Eclipse. The plugin loads a custom profile
>> or similar.
>> external UML editor (VP-UML, to be specific) and of course the
>> "platform:" URI doesn't mean anything to that tool. (The model loads
>> fine in the external editor, but because the original profile file is not
>> accessible, certain aspects of the stereotype definition are not loaded.
>> I have been working with Visual Paradigm to clarify the requirements.)
>> "href" for the profile is getting saved incorrectly, as evidenced by the
>> following:
>> </eAnnotations>
>> <appliedProfile
>> it would be greatly appreciated. I am not that knowledgeable about
>> URL/URI handling in Eclipse and I may well be doing something wrong.
>> I'll be happy to provide further information or code snippets on request.
Re: Problems with profile "file:" URI in UML Model Editor [message #477073 is a reply to message #477060] Wed, 12 March 2008 02:43 Go to previous messageGo to next message
The pathmap approach is working-- but I don't see how it helps in my
situation. When viewing the model in an external tool, that tool still has
no understanding of what the "pathmap://" URI points to, because that's
Eclipse-specific...
(Thanks for the pointers for getting the pathmap approach working-- when I
tried it previously, I had switched the source and target entries by
mistake. Oops!)
- Ellen
> Hi Ellen,
> <extension
> <mapping
> </mapping>
> </extension>
> This might help?
> Cheers
> - James
>> Greetings,
>> or similar.
>> following:
>> </eAnnotations>
>> <appliedProfile
Re: Problems with profile "file:" URI in UML Model Editor [message #477079 is a reply to message #477073] Wed, 12 March 2008 10:05 Go to previous messageGo to next message
Hi Ellen,
Something else that might be of some use is the following:
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html
Go to the section "Programmatic Migration" (toward the bottom) to see how
to programatically set up pathmaps.
- James
news:fr7u3e$dfs$1@build.eclipse.org...
> has no understanding of what the "pathmap://" URI points to, because
> that's Eclipse-specific...
> mistake. Oops!)
> - Ellen
>> Hi Ellen,
>> <extension
>> <mapping
>> </mapping>
>> </extension>
>> This might help?
>> Cheers
>> - James
>>> Greetings,
>>> or similar.
>>> is occurring when I try to change the URI scheme by which I locate the
>>> "platform:/" URI (profiles for the translator are stored within their
>>> own plugin). I would like to have an alternative option to use a
>>> "file:/" URI to locate the profile, because the output model is
>>> sometimes loaded into an external UML editor (VP-UML, to be specific)
>>> and of course the "platform:" URI doesn't mean anything to that tool.
>>> (The model loads fine in the external editor, but because the original
>>> profile file is not accessible, certain aspects of the stereotype
>>> definition are not loaded. I have been working with Visual Paradigm to
>>> to open the model in the UML Model Editor in Eclipse: when the model is
>>> following:
>>> </eAnnotations>
>>> <appliedProfile
>>> garbled when the profile URI is stored in the model.
>>> request.
Re: Problems with profile "file:" URI in UML Model Editor [message #477089 is a reply to message #477079] Thu, 13 March 2008 03:22 Go to previous messageGo to next message
James,
Thanks for the info, but I'm still not seeing how pathmaps are going to be
of assistance in my situation.
I need the profile file to be accessible via a file: URI in my model, since
that is what the external tool requires. Having it as a pathmap won't help,
will it? The pathmap URI is only meaningful within Eclipse.
The problem I'm running into is that even when I use a file URI for the
profile location, somehow it is getting garbled after I save the model, such
that the model produces error messages when opened in the UML Model Editor.
Hence, the profile URI passed in is something like this:
file:C:/Documents and Settings/ebadgley/My Documents/Projects/Geospatial
Registries/Eclipse
Modeling/javaEEWorkspace/org.mitre.nas2uml2.profiles/profile s/NAS.profile.uml
(Characters should actually be escaped, and they are in the processing, I
just didn't type that here.)
My translator is able to load the profile from this URI and create the
output model-- but when I look at the appliedProfile tag, the href looks
.../../../../..(etc.)/org.mitre.nas2uml2.profiles/profiles/N AS.profile.uml
This is what is causing the UML Model Editor to choke.
When I can I'll access the profile using a pathmap URI, but that's not an
option for the flow I'm trying to support...
Ellen
news:fr8o02$kjq$2@build.eclipse.org...
> Hi Ellen,
> how to programatically set up pathmaps.
> Cheers,
> - James
>> I tried it previously, I had switched the source and target entries by
>> mistake. Oops!)
>> - Ellen
>>> Hi Ellen,
>>> <extension
>>> <mapping
>>> </mapping>
>>> </extension>
>>> This might help?
>>> Cheers
>>> - James
>>>> Greetings,
>>>> into a UML2 model in Eclipse. The plugin loads a custom profile
>>>> Editor or similar.
>>>> it to the translator, it works just fine-- the profile can be loaded
>>>> from that URI and applied to the model. The problem occurs when I then
>>>> try to open the model in the UML Model Editor in Eclipse: when the
>>>> model is opened/expanded, I get an "Error" message. The problem is
>>>> that the "href" for the profile is getting saved incorrectly, as
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> request.
Re: Problems with profile "file:" URI in UML Model Editor [message #477091 is a reply to message #477089] Thu, 13 March 2008 09:35 Go to previous messageGo to next message
Well, I got it figured out-- to get a reliable file URI for my profile, I
first normalize the URI if I'm using a pathmap, then use
CommonPlugin.asLocalURI(normalizedURI) to get the file version, and it seems
to get saved in the model correctly...
Now that I've finally got the hang of URIs I've rewritten all the
unspeakable code I had in there previously, and it is a lot more
straightforward as a result!
Thanks for the information on the pathmaps; my code is a lot better as a
result.
- Ellen
news:frakog$jea$1@build.eclipse.org...
> James,
> since that is what the external tool requires. Having it as a pathmap
> won't help, will it? The pathmap URI is only meaningful within Eclipse.
> such that the model produces error messages when opened in the UML Model
> Editor. Hence, the profile URI passed in is something like this:
> Registries/Eclipse
> ../../../../..(etc.)/org.mitre.nas2uml2.profiles/profiles/NA S.profile.uml
> Ellen
>> Hi Ellen,
>> Cheers,
>> - James
>>> mistake. Oops!)
>>> - Ellen
>>>> Hi Ellen,
>>>> <extension
>>>> <mapping
>>>> </mapping>
>>>> </extension>
>>>> This might help?
>>>> Cheers
>>>> - James
>>>>> Greetings,
>>>>> appropriate), and finally saves the model to the designated folder in
>>>>> the workspace. The final model can then be viewed in Eclipse using the
>>>>> then try to open the model in the UML Model Editor in Eclipse: when
>>>>> the model is opened/expanded, I get an "Error" message. The problem
>>>>> is that the "href" for the profile is getting saved incorrectly, as
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> avoid it would be greatly appreciated. I am not that knowledgeable
>>>>> about URL/URI handling in Eclipse and I may well be doing something
>>>>> wrong. I'll be happy to provide further information or code snippets
>>>>> on request.
Re: Problems with profile "file:" URI in UML Model Editor [message #626180 is a reply to message #477057] Tue, 11 March 2008 13:52 Go to previous messageGo to next message
Hi Ellen,
<extension
<mapping
</mapping>
</extension>
This might help?
Cheers
- James
> Greetings,
> or similar.
> following:
> </eAnnotations>
> <appliedProfile
Re: Problems with profile "file:" URI in UML Model Editor [message #626185 is a reply to message #477060] Tue, 11 March 2008 14:37 Go to previous messageGo to next message
- Ellen
> Hi Ellen,
> <extension
> <mapping
> </mapping>
> </extension>
> This might help?
> Cheers
> - James
>> Greetings,
>> or similar.
>> following:
>> </eAnnotations>
>> <appliedProfile
Re: Problems with profile "file:" URI in UML Model Editor [message #626200 is a reply to message #477060] Wed, 12 March 2008 02:43 Go to previous messageGo to next message
Eclipse-specific...
mistake. Oops!)
- Ellen
> Hi Ellen,
> <extension
> <mapping
> </mapping>
> </extension>
> This might help?
> Cheers
> - James
>> Greetings,
>> or similar.
>> following:
>> </eAnnotations>
>> <appliedProfile
Re: Problems with profile "file:" URI in UML Model Editor [message #626206 is a reply to message #477073] Wed, 12 March 2008 10:05 Go to previous messageGo to next message
Hi Ellen,
- James
> mistake. Oops!)
> - Ellen
>> Hi Ellen,
>> <extension
>> <mapping
>> </mapping>
>> </extension>
>> This might help?
>> Cheers
>> - James
>>> Greetings,
>>> or similar.
>>> following:
>>> </eAnnotations>
>>> <appliedProfile
>>> request.
Re: Problems with profile "file:" URI in UML Model Editor [message #626218 is a reply to message #477079] Thu, 13 March 2008 03:22 Go to previous messageGo to next message
James,
Registries/Eclipse
Ellen
> Hi Ellen,
> Cheers,
> - James
>> mistake. Oops!)
>> - Ellen
>>> Hi Ellen,
>>> <extension
>>> <mapping
>>> </mapping>
>>> </extension>
>>> This might help?
>>> Cheers
>>> - James
>>>> Greetings,
>>>> Editor or similar.
>>>> </eAnnotations>
>>>> <appliedProfile
>>>> request.
Re: Problems with profile "file:" URI in UML Model Editor [message #626220 is a reply to message #477089] Thu, 13 March 2008 09:35 Go to previous messageGo to next message
result.
- Ellen
> James,
> Registries/Eclipse
> Ellen
>> Hi Ellen,
>> Cheers,
>> - James
>>> mistake. Oops!)
>>> - Ellen
>>>> Hi Ellen,
>>>> <extension
>>>> <mapping
>>>> </mapping>
>>>> </extension>
>>>> This might help?
>>>> Cheers
>>>> - James
>>>>> Greetings,
>>>>> </eAnnotations>
>>>>> <appliedProfile
>>>>> on request.
Re: Problems with profile "file:" URI in UML Model Editor [message #1409350 is a reply to message #626220] Sun, 17 August 2014 18:37 Go to previous message
I am facing this same issue but even with Ellen's response I am still stuck. She mentioned something about normalizeing URIs and pathmaps to resolve that but I still don't know how to do it (researched a lot through the forum but got nothing yet). If someone could help me out a little bit, I am feeling that I'm getting closer to the answer. Here it is:
I am failing to put my profile absolute path in "schemaLocation" at my UML model file, using a stand alone application. It is printing "../"instead of the full file path "file:/C:/Users/John/...". My profile's name is "Custom". See below how it is incorrectly printing the schemaLocation.
xsi:schemaLocation="[url]http:///schemas/Custom/_tBawQCTmEeKfN4O_IciSig/1[/url] ../SVNs/.../profile/Custom.uml#_tBawQSTmEeKfN4O_IciSig">
So, I load my profile with a absolute path as its URI, as it follows:
profileRSet = new ResourceSetImpl();
UMLResourcesUtil.init(profileRSet);
profileRSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
profileRSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
myProfileUri = URI.createFileURI("file:/C:/Users/John/.../Custom.uml");
profileResource = profileRSet.createResource(myProfileUri );
profileResource.load(null);
final Map<URI,URI> uriMap = profileRSet.getURIConverter().getURIMap();
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uml2baseURI.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uml2baseURI.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uml2baseURI.appendSegment("profiles").appendSegment(""));
Then I create a UML resource for my model and put in its URI mapping, the pathmap "pathmap//CUSTOM_PROFILE/" and the respective absolute file folder location.
URI uri = URI.createFileURI(umlPath);
modelRSet = new ResourceSetImpl();
UMLResourcesUtil.init(modelRSet);
modelRSet.getPackageRegistry().put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
modelRSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
modelResource = modelRSet.createResource(uri);
modelResource.getContents().add(umlRoot);
try {
   modelResource.load(null);
} catch (IOException e) {
   e.printStackTrace();
final Map<URI,URI> uriModelMap = modelRSet.getURIConverter().getURIMap();
uriModelMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uml2baseURI.appendSegment("libraries").appendSegment(""));
uriModelMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uml2baseURI.appendSegment("metamodels").appendSegment(""));
uriModelMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uml2baseURI.appendSegment("profiles").appendSegment(""));
uriModelMap.put(URI,createURI("[url]pathmap://CUSTOM_PROFILE/[/url]"), URI.createURI("file:/C:/Users/John/.../profile/")));
Then I apply my profile to the UML model, apply some stereotypes in the elements and then save the UML model.
uprofile = (Profile)EcoreUtil.getObjectByType(profileResource.getContents(), UMLPackage.Literals.PROFILE);
umlRoot.applyProfile(custom_profile);
// applying some stereotypes....
modelResource.save(Collections.emptyMap());
That's basically all I am doing, I am missing something very important. Perhaps to register my Custom profile to that pathmap.
Thanks a lot,
John
[Updated on: Sun, 17 August 2014 18:39] by Moderator
Previous Topic:Java code on how to copy UML package to another UML Package
Next Topic:ExportAllDiagrams/Model Validation very slow on Luna
Current Time: Wed Jul 23 17:04:58 EDT 2025
Powered by FUDForum. Page generated in 0.06848 seconds
