Home » Modeling » UML2 » xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ?
xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #476889] Tue, 29 January 2008 04:32 Go to next message
is it possible to use EMF / UML2 to downgrade an UML 2.0/2.1 model serialized as XMI 2.1 to a UML 1.3 model serialized as XMI 1.1 ?
The original model consists of an XMI, UML, and EMX file.
I can correctly load the XMI file and show the XMI version using getXMIVersion().
Unfortunately, setXMIVersion() only seems to change the XMI version field, it doens't instruct EMF/UML2 to write XMI 1.1 ...
I stumbled over http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 0_Migration_Guide/guide.html#_Migration
but that seems more appropriate for UML 2.0 -> UML 2.1.1 conversions?
An alternative would be to write an XSLT script which extracts/converts the part I need.
Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #476894 is a reply to message #476889] Tue, 29 January 2008 09:39 Go to previous messageGo to next message
Hi Rene,
Downgrading from UML 2.0 to UML 1.3 is not supported by this opensource
project so if you need this capability you will have to extract the
information yourself.
Keep in mind that the UML metamodel has changed quite dramatically between
those versions. If you intend to do this migration I would expect there to
be a loss of data.
Also have a look at
http://www.eclipse.org/modeling/mdt/uml2/docs/guides/UML2_2. 1_Migration_Guide/guide.html
in addition to the one you found
- James.
"Rene Ladan" <r.c.ladan@tue.nl> wrote in message
news:fnmrqq$qa$1@build.eclipse.org...
> getXMIVersion().
> I stumbled over
> the part I need.
> Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #476895 is a reply to message #476894] Tue, 29 January 2008 09:56 Go to previous message
James Bruck wrote:
> Hi Rene,
Ok ...
> be a loss of data.
I expect some data loss too, but not all data is important for the task at hand.
> Also have a look at
> Cheers,
> - James.
>> Hi,
>> getXMIVersion().
>> I stumbled over
>> the part I need.
>> Thanks,
>> Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #625950 is a reply to message #476889] Tue, 29 January 2008 09:39 Go to previous message
Hi Rene,
be a loss of data.
Also have a look at
- James.
> getXMIVersion().
> I stumbled over
> the part I need.
> Rene
Re: xmi 2.1 / uml 2.x to xmi 1.1 / uml 1.3 ? [message #625951 is a reply to message #476894] Tue, 29 January 2008 09:56 Go to previous message
James Bruck wrote:
> Hi Rene,
Ok ...
> be a loss of data.
> Also have a look at
> Cheers,
> - James.
>> Hi,
>> getXMIVersion().
>> I stumbled over
>> the part I need.
>> Thanks,
>> Rene
Previous Topic:Using emf and uml2 standalone parsing for a Magicdraw exported model
Next Topic:[Announce] MDT UML2 2.2.0 I200801292200 is available
Current Time: Sun Jul 27 15:52:13 EDT 2025
Powered by FUDForum. Page generated in 0.04102 seconds
