Home » Modeling » UML2 » Re: How do I model with UML 2 in eclipse?
Re: How do I model with UML 2 in eclipse? [message #476826] |
Fri, 04 January 2008 14:26  |
Warren,
The best I can do is direct you to the UML2 model and UML2 tools
newsgroups and suggest you look at the home pages for these two
components in the MDT project: http://www.eclipse.org/modeling/mdt/
Warren Tang wrote:
> Hi
> What do I need to install?
> What's the differences between UML 2 SDK and UML 2 Tools?
> Are there any tutorials or videos?
> I am a little confusing and need your help. Thanks!
Re: How do I model with UML 2 in eclipse? [message #476830 is a reply to message #476829] |
Sat, 05 January 2008 13:34   |
Hi, Warren,
Before you give up: you can find all of the UML2 component's dependencies
(using "Check Required") in the Ganymede coordinate release update site:
http://download.eclipse.org/releases/ganymede/staging/
This is one-stop shopping for everything you need.
HTH,
Christian
Warren Tang wrote:
> Thanks Ed and Lars
> I decide to give up the attempt after several hours' struggle. I have
> selected all those update candidates and click everyone of them and then
> clicked "Check Required". I have also tried to download the files myself
> and then unzipped them to the eclipse folder. However I was not lucky.
> It's just too HARD to install it.
> Life would be much easier if the tools could find its dependences and
> download them automatically for me, or I could download something and
> click it once then everything would be ready. For now I will just use
> the built-in support for UML 1.X in the netBeans IDE.
> Thanks again for your attention.
> Regards,
> Warren
> Lars Vogel wrote:
>> Hi Warren,
>> please look at this:
>> http://www.vogella.de/articles/UML/article.html
>> Best regards, Lars
>> "Warren Tang" <warren.s.tang@gmail.com> wrote in message
>> news:477F27AF.4010401@gmail.com...
>>> Hi, Ed
>>> Thanks for your reply. I am new to eclipse and I have trouble installing
>>> the UML2 Tools into the eclipse IDE which I have just downloaded.
>>> I used the [Help -> Software Updates -> Find and Replace] menu, and then
>>> selected the [New Features -> MDT Updates -> UML2 Tools]. However there
>>> are several dependences that I don't know where to find them.
>>> Is there a step-by-step tutorial for installing it? I really don't know
>>> how these eclipse project are related to each other.
>>> Could you guide me? Thanks.
>>> Regards,
>>> Warren
>>> Ed Merks wrote:
>>>> Warren,
>>>> Warren Tang wrote:
>>>>> Hi
Re: How do I model with UML 2 in eclipse? [message #476831 is a reply to message #476830] |
Mon, 07 January 2008 10:01   |
.... in addition, you should be able to find other dependency information and
get at the plugins through here:
http://www.eclipse.org/modeling/mdt/downloads/?project=uml2
Other information here: http://www.eclipse.org/modeling/mdt/updates/
The UML project simply has EMF as a dependency.
The UMLTools project is for visualizing UML models. That download will have
other dependencies.
- James.
"Christian W. Damus" <cdamus@ca.ibm.com> wrote in message
news:floijt$klt$1@build.eclipse.org...
> Hi, Warren,
> HTH,
> Christian
> Warren Tang wrote:
>> Thanks Ed and Lars
>> Regards,
>> Warren
>> Lars Vogel wrote:
>>> Hi Warren,
>>> Best regards, Lars
>>>> Hi, Ed
>>>> installing
>>>> then
>>>> Regards,
>>>> Warren
>>>> Ed Merks wrote:
>>>>> Warren,
>>>>> Warren Tang wrote:
>>>>>> Hi
Re: How do I model with UML 2 in eclipse? [message #476834 is a reply to message #476831] |
Tue, 08 January 2008 10:28   |
Hi, James. I had gone through those links several times and had a basic
view of these projects.
Hi, Christian. Form your words I finally know all these projects are
parts of Ganymede! It's the version 3.4 of Eclispe, isn't it? I
downloaded the build 20080108-0440 of the shy Ganymede form the
following link:
http://www.eclipse.org/epp/download.php
However I haven't found how to create a Class Diagram with it. I could
not find the "UML 2.1 Diagrams" entry in the "New -> Others" menu as
illustrated in the following link provided by Lars:
http://www.vogella.de/articles/UML/article.html#eclipseuml
Isn't the UML 2.1 Tools included in Ganymede? Or I have missed anything?
I am new to eclipse and I love open source and free software. But
now I really need some guide to myself started.
I appreciate your enthusiasm and patience. Thanks for all of you!
Warren
> other dependencies.
> Cheers,
> - James.
>> Hi, Warren,
>> HTH,
>> Christian
>> Warren Tang wrote:
>>> Thanks Ed and Lars
>>> Regards,
>>> Warren
Re: How do I model with UML 2 in eclipse? [message #476835 is a reply to message #476834] |
Tue, 08 January 2008 11:57  |
Hi, Warren,
Since it's the UML2 Tools that you're looking for, specifically, I'm
replying to that newsgroup, also.
Yes, Ganymede is based on Eclipse 3.4. However, the link that you found is
for downloads of the "Eclipse Packages" which are a variety of subsets of
Ganymede targeted to different user roles. There is talk of a Modeling
Package being provided, also, which would include the UML2 Tools, but as
you can see, it isn't yet available.
Once you have installed your package of choice, point add a Remote Update
Site in your Update Manager that links to here:
That's where you should be able to find UML2 Tools and all of its
dependencies.
AFAIK, the UML2 Tools should be in the Ganymede update site as of M3 and,
very soon, in M4. Probably the folks in that newsgroup can be more
specific.
It's possible, also, that the UML diagrams have moved to a different,
UML-specific category in the New Wizard. That would make sense, as they
probably shouldn't be lumped into "Others."
Christian
> following link:
> Regards
> Warren
-----8<-----
Re: How do I model with UML 2 in eclipse? [message #625851 is a reply to message #476826] |
Sat, 05 January 2008 01:46  |
Hi, Ed
Warren
Ed Merks wrote:
> Warren,
> Warren Tang wrote:
>> Hi
Re: How do I model with UML 2 in eclipse? [message #625852 is a reply to message #476827] |
Sat, 05 January 2008 04:02  |
Hi Warren,
Best regards, Lars
> Hi, Ed
> Regards,
> Warren
> Ed Merks wrote:
>> Warren,
>> Warren Tang wrote:
>>> Hi
Re: How do I model with UML 2 in eclipse? [message #625853 is a reply to message #476828] |
Sat, 05 January 2008 11:45  |
Thanks Ed and Lars
Warren
Lars Vogel wrote:
> Hi Warren,
> Best regards, Lars
>> Hi, Ed
>> Regards,
>> Warren
>> Ed Merks wrote:
>>> Warren,
>>> Warren Tang wrote:
>>>> Hi
Re: How do I model with UML 2 in eclipse? [message #625854 is a reply to message #476829] |
Hi, Warren,
HTH,
Christian
Warren Tang wrote:
> Thanks Ed and Lars
> Regards,
> Warren
> Lars Vogel wrote:
>> Hi Warren,
>> Best regards, Lars
>>> Hi, Ed
>>> Regards,
>>> Warren
>>> Ed Merks wrote:
>>>> Warren,
>>>> Warren Tang wrote:
>>>>> Hi
Re: How do I model with UML 2 in eclipse? [message #625855 is a reply to message #476830] |
other dependencies.
- James.
> Hi, Warren,
> HTH,
> Christian
> Warren Tang wrote:
>> Thanks Ed and Lars
>> Regards,
>> Warren
>> Lars Vogel wrote:
>>> Hi Warren,
>>> Best regards, Lars
>>>> Hi, Ed
>>>> installing
>>>> then
>>>> Regards,
>>>> Warren
>>>> Ed Merks wrote:
>>>>> Warren,
>>>>> Warren Tang wrote:
>>>>>> Hi
Re: How do I model with UML 2 in eclipse? [message #625858 is a reply to message #476831] |
following link:
Warren
> other dependencies.
> Cheers,
> - James.
>> Hi, Warren,
>> HTH,
>> Christian
>> Warren Tang wrote:
>>> Thanks Ed and Lars
>>> Regards,
>>> Warren
Re: How do I model with UML 2 in eclipse? [message #625859 is a reply to message #476834] |
Hi, Warren,
dependencies.
specific.
Christian
> following link:
> Regards
> Warren
-----8<-----
Current Time: Mon Jul 28 23:06:04 EDT 2025
Powered by FUDForum. Page generated in 0.05937 seconds
