Home » Modeling » UML2 Tools » Adding operations to Class Diagram
Adding operations to Class Diagram [message #625590] Tue, 30 March 2010 05:06 Go to next message
I am trying to add operations to a class diagram. I am able to add simple operation like add(), but how can I set In parameters and return type of this operation,please suggest
thanks,
Re: Adding operations to Class Diagram [message #625593 is a reply to message #625590] Thu, 01 April 2010 05:36 Go to previous messageGo to next message
context menu (click right) -> manage parameters
properties sheet -> Type
GreetX,
Thorsten
Re: Adding operations to Class Diagram [message #625831 is a reply to message #625593] Wed, 14 July 2010 11:32 Go to previous messageGo to next message
I am having the same problem when it comes to specifying type that are not primatives. For example, I would like to greate an operation like so: +getSearchResults():List<SomeObject> or +getSearchResults():<Generalization Set> SomeObject>.
Any suggestion would be greatly appreciated.
Thanks!
Re: Adding operations to Class Diagram [message #625836 is a reply to message #625831] Sat, 24 July 2010 19:58 Go to previous message
For example for the operation +getSearchResults():List<>
1-click left on your class, and clik operation icon
2-In properties sheet set the name as getSearchResults
3-You can set the return type, in properties sheet -> Type.
To set List, you should have a Class named List, in your diagram(current resource package when you click in type properties), or in a other ecore file(load resources).
4-To set the parameters
Click left in your opeation class(in the diagram), and edit directly the name and types of parameters.For example, if your operation is op1(param1:String), write param1:String.
If you now go to context menu (click right) -> manage parameters, you can see your new parameter and type,(i can`t directly edit de type of a parameter in manage parameter)
I hope this help you.
Previous Topic:Adding operations to Class Diagram
Next Topic:MDT and Helios
Current Time: Wed Jul 23 12:14:42 EDT 2025
Powered by FUDForum. Page generated in 0.53025 seconds
