Home » Modeling » UML2 » create package in a eclipse plugin
create package in a eclipse plugin [message #476646] Mon, 19 November 2007 11:09 Go to next message
I'm writing a eclipse plugin,which will create some uml models by using
UML2.
I wrote following code in the plugin and call it
public void run(IAction action)
// create uml package
org.eclipse.uml2.uml.Package
paket=org.eclipse.uml2.uml.UMLFactory.eINSTANCE.createPackag e();
paket.setName("package");
// export uml model
The plugin returned without giving any answers or error message to me. So
I set one breakpoints on each line and step into. On the first line, in
which the package should be created, it went to the EventTable and sent
some event to Workbench. Then it went to an exception in the runEventLoop
: "java.lang.NoClassDefFoundError: org/eclipse/uml2/uml/UMLFactory". I
step out and resumed. It stopped on the first line and returned.
The code works very well when I put them in a single main method.
Is there something I've missed? I am new to Plugin.
Re: create package in a eclipse plugin [message #476654 is a reply to message #476646] Wed, 21 November 2007 06:31 Go to previous messageGo to next message
Originally posted by: Elena.Alekseeva.borland.com
a stupid question: have you added org.eclipse.uml2.uml plugin you your
plugin dependencies?
"Zengyu Lu" <sizeluuu@gmail.com> wrote in message
news:f8844a45166073120450513bd1cd10b2$1@www.eclipse.org...
> UML2.
> // export uml model
Re: create package in an eclipse plugin [message #476656 is a reply to message #476654] Wed, 21 November 2007 12:59 Go to previous messageGo to next message
Yes, I did. The plugin kann be compiled and started.
>> Hi,
>> I'm writing an eclipse plugin,which will create some uml models by using
>> UML2.
>> // export uml model
Re: create package in an eclipse plugin [message #476664 is a reply to message #476656] Thu, 22 November 2007 09:12 Go to previous message
The problem has been solved. I used the old path of referenced packages
>>> Hi,
>>> using UML2.
>>> // export uml model
>>> me. So I set one breakpoints on each line and step into. On the first
>>> line, in which the package should be created, it went to the
>>> EventTable and sent some event to Workbench. Then it went to an
>>> exception in the runEventLoop : "java.lang.NoClassDefFoundError:
>>> org/eclipse/uml2/uml/UMLFactory". I step out and resumed. It stopped
Re: create package in a eclipse plugin [message #625554 is a reply to message #476646] Wed, 21 November 2007 06:31 Go to previous message
> UML2.
> // export uml model
Re: create package in an eclipse plugin [message #625556 is a reply to message #476654] Wed, 21 November 2007 12:59 Go to previous message
>> Hi,
>> UML2.
>> // export uml model
Re: create package in an eclipse plugin [message #625564 is a reply to message #476656] Thu, 22 November 2007 09:12 Go to previous message
>>> Hi,
>>> using UML2.
>>> // export uml model
Previous Topic:Re: Ecore2UMLProfile
Next Topic:Stereotype property typed with other stereotype
Current Time: Sun Aug 31 03:37:37 EDT 2025
Powered by FUDForum. Page generated in 0.10587 seconds
