Loading XMI with profile and stereotypes failes [message #476403] |
Sat, 20 October 2007 06:48  |
I am trying to load XMIs with UML2 2.1. That works perfect until I tried
to add a profile to use stereotypes.
My little XMI (test file) with a profile is at the bottom of this message.
Its a class with stereotype <<SUT>>.
After loading it, I get the following exception:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'SUT' not found.
(<path_to_file>, 26, 80)
Is there something wrong with the XMI file or with the code (below the XMI
file)?
Thanks a lot for your help.
<?xml version="1.0" encoding="iso-8859-1"?>
<xmi:XMI xmlns:xmi="http://schema.omg.org/spec/XMI/2.1"
xmlns:uml="http://www.eclipse.org/uml2/2.1.0/UML" version="2.1">
<uml:Model xmi:type="uml:Model" name="EA_Model" visibility="public">
<packagedElement xmi:type="uml:Package"
xmi:id="EAPK_B8A6DE1E_4D59_45d1_8B7C_3E6287069B33" name="Model"
xmi:id="EAPK_435BFDBD_22EF_452c_BF09_ADE83276D12D" name="Class Model"
<packagedElement xmi:type="uml:Class"
xmi:id="EAID_5D161DA1_C258_471b_AC2C_E41C7B86F7F4" name="Device"
visibility="public" />
</packagedElement>
</packagedElement>
</uml:Model>
<uml:Profile xmlns:namespace-prefix="thecustomprofile" xmi:version="2.1"
xmi:id="thecustomprofile" name="thecustomprofile"
metamodelReference="mmref01">
<ownedComment xmi:type="uml:Comment" xmi:id="comment01"
annotatedElement="thecustomprofile">
<body>Version:1.0</body>
</ownedComment>
<packageImport xmi:id="mmref01">
<importedPackage href="http://www.eclipse.org/uml2/2.1.0/UML/uml.xml" />
</packageImport>
<packagedElement xmi:type="uml:Stereotype" xmi:id="SUT" name="SUT">
<ownedAttribute xmi:type="uml:Property" xmi:id="SUT-base_Class"
name="base_Class" association="Class_SUT">
<type xmi:type="uml:PrimitiveType"
href="http://www.eclipse.org/uml2/2.1.0/UML/uml.xml#Class" />
</ownedAttribute>
</packagedElement>
<packagedElement xmi:type="uml:Extension" xmi:id="Class_SUT"
name="A_Class_SUT" memberEnd="extension_SUT SUT-base_Class">
<ownedEnd xmi:type="uml:ExtensionEnd" xmi:id="extension_SUT"
name="extension_SUT" type="SUT" isComposite="true" lower="0" upper="1" />
</packagedElement>
</uml:Profile>
<thecustomprofile:SUT
base_Class="EAID_5D161DA1_C258_471b_AC2C_E41C7B86F7F4"/>
</xmi:XMI>
static public org.eclipse.uml2.uml.Package load(URI uri)
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "xmi",
new XMIResourceFactoryImpl());
UMLPackage.eINSTANCE.eClass();
org.eclipse.uml2.uml.Package p = null;
try
Resource resource = resourceSet.getResource(uri, true);
p = (org.eclipse.uml2.uml.Package)
EcoreUtil.getObjectByType(resource.getContents(),
UMLPackage.eINSTANCE.getPackage());
catch (Exception e)
e.printStackTrace();
return p;
Re: Loading XMI with profile and stereotypes failes [message #476418 is a reply to message #476403] |
Tue, 23 October 2007 16:52   |
Hi Reinhard,
I noticed that you did not "define" your profile. Select your profile from
the UML editor and select 'UML Editor > Profile > Define'.
Please have a look at
http://www.eclipse.org/modeling/mdt/uml2/docs/articles/Intro duction_to_UML2_Profiles/article.html.
I tried defining your profile and it worked much better but you are
importing a package called uml.xml (I'm not sure where that is coming from)
- James.
"Reinhard Jeschull" <rjeschu@fh-landshut.de> wrote in message
news:4b34a1e66d48175eb84ab3d567ccf30f$1@www.eclipse.org...
> to add a profile to use stereotypes. My little XMI (test file) with a
> profile is at the bottom of this message. Its a class with stereotype
> <<SUT>>.
> file)?
> </packagedElement>
> </packagedElement>
> </uml:Model>
> </ownedComment>
> </packageImport>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> </xmi:XMI>
> try
> Resource resource = resourceSet.getResource(uri, true); p =
> catch (Exception e)
> return p;
Re: Loading XMI with profile and stereotypes failes [message #476424 is a reply to message #476404] |
Wed, 24 October 2007 15:47  |
Reinhard,
At a glance, I can see a couple of things wrong with your profile.
<importedPackage
</packageImport>
First, the URI for the package import above (of, I presume, the UML
metamodel) references a resource that doesn't exist. You can work around
this by changing it to "pathmap://UML_METAMODELS/UML.metamodel.uml#_0" for
example, or by adding a URI mapping from
"http://www.eclipse.org/uml2/2.1.0/UML/uml.xml" to
"pathmap://UML_METAMODELS/UML.metamodel.uml#_0".
xmi:id="SUT-base_Class" name="base_Class" association="Class_SUT">
Second, the type of the base_Class property is PrimitiveType when I believe
it should be Class (since it references the base class for the stereotype).
Third, the URI for type of the base_Class references a resource that doesn't
exist. You can work around this using an approach simlar to the one
suggested for the package import above (but replacing with
"pathmap://UML_METAMODELS/UML.metamodel.uml#Class").
Kenn
news:cc09a5bcdbbf918c3fa86609b81a2232$1@www.eclipse.org...
> Here is the xmi with a better format (spaces instead of tabs):
> </packagedElement>
> </packagedElement>
> </uml:Model>
> xmi:version="2.1" xmi:id="thecustomprofile" name="thecustomprofile"
> </ownedComment>
> <importedPackage
> </packageImport>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> </xmi:XMI>
Re: Loading XMI with profile and stereotypes failes [message #625237 is a reply to message #476403] |
Sat, 20 October 2007 06:54  |
</packagedElement>
</packagedElement>
</uml:Model>
</ownedComment>
<importedPackage
</packageImport>
</ownedAttribute>
</packagedElement>
</packagedElement>
</uml:Profile>
</xmi:XMI>
Re: Loading XMI with profile and stereotypes failes [message #625297 is a reply to message #476403] |
Hi Reinhard,
- James.
> <<SUT>>.
> file)?
> </packagedElement>
> </packagedElement>
> </uml:Model>
> </ownedComment>
> </packageImport>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> </xmi:XMI>
> try
> catch (Exception e)
> return p;
Re: Loading XMI with profile and stereotypes failes [message #625302 is a reply to message #476404] |
Reinhard,
<importedPackage
</packageImport>
Kenn
> </packagedElement>
> </packagedElement>
> </uml:Model>
> </ownedComment>
> <importedPackage
> </packageImport>
> </ownedAttribute>
> </packagedElement>
> </packagedElement>
> </uml:Profile>
> </xmi:XMI>
FUDForum. Page generated in 0.04081 seconds
