Home » Archived » Eclipse Communications Framework (ECF) » XMPP
XMPP [message #625190] Mon, 29 March 2010 17:10 Go to next message
Hi guys,
I am trying to build IM client using;
-Eclipse IDE
-Smack API(with smack.jar files)
-Openfire(as the server)
I would like an advice on how to build this client using eclipse and am finding difficult on how to build a simple program that sends message from one client to another one using the server.
I would appriciate if anyone could help with this.
Thanks in advance,
Ireland
Re: XMPP [message #625191 is a reply to message #625190] Mon, 29 March 2010 20:44 Go to previous message
Hi Ireland,
Ireland wrote:
> Hi guys,
> -Eclipse IDE
ECF uses the smack API (v 3.1) to implement our abstract presence API.
There is example code for creating a basic chat client that uses the
presence API (and smack provider) here:
org.eclipse.ecf.example.clients.applications.ChatRobotApplic ation
This class is in this project: org.eclipse.ecf.example.clients
See also the class:
org.eclipse.ecf.example.clients.XMPPChatClient
in that same project (XMPPChatClient is used by the ChatRobotApplication):
See below for the info about CVS access to this example code.
If you have other questions about this example and/or the presence API I
would suggest posting these questions to the ecf-dev mailing list, as it
is monitored more closely than this newsgroup by ECF committers (myself
as well as others). There is information and archive for the ecf-dev
mailing list here: https://dev.eclipse.org/mailman/listinfo/ecf-dev
Scott
Anonymous CVS access
The org.eclipse.ecf.example.clients project/source code is located here
in anonymous CVS:
connection type: pserver (or extssh)
host: dev.eclipse.org
repo path: /cvsroot/rt
module: org.eclipse.ecf/examples/bundles/org.eclipse.ecf.example.cli ents
There's more info on getting anonymous CVS access to this (and all the
ECF) code on the ECF dev resources page:
http://www.eclipse.org/ecf/dev_resources.php
Previous Topic:Custom ECF provider development
Next Topic:XMPP
Current Time: Sat Jul 26 09:05:44 EDT 2025
Powered by FUDForum. Page generated in 0.07783 seconds
