Home » Modeling » UML2 » UML2 -> XML artifacts
UML2 -> XML artifacts [message #476253] |
Tue, 02 October 2007 12:10  |
Hi everybody.
I'm currently working on some UML to WSDL (which also implies UML to XML
Schema) generation.
In order to avoid re-inventing the wheel, I first tried searching around
for things already available. I found some interesting projects: M2T,
WTP, M2M. However, all of them focus on a piece of the picture, not the
whole of it, lets say.
Before embarking on the journey of developing something which is
probably already done, I figured I could ask around.
So here it is: is there anything already in eclipse (not commercial
plugins) that deal with the generation of xml schemas from UML datatypes
and/or WSDL descriptors from UML models?, is there something I should
read prior to the development?.
I wanna thank you all in advance for any help you may provide.
Juan Pedro Silva
Re: UML2 -> XML artifacts [message #476260 is a reply to message #476253] |
Wed, 03 October 2007 12:56   |
--------------060901040903050709010906
Juan,
You might be interested in the Ecore -> XSD support in EMF. Since
there is support for UML2 -> Ecore -> XSD, indirectly that does what you
want. You might also be interested in collaborating on the proposed
Servus EMFT component which will explore Ecore <-> WSDL mapping:
http://dev.eclipse.org/mhonarc/lists/emft-dev/msg00126.html
Juan Pedro Silva wrote:
> Hi everybody.
> XML Schema) generation.
> around for things already available. I found some interesting
> projects: M2T, WTP, M2M. However, all of them focus on a piece of the
> picture, not the whole of it, lets say.
> datatypes and/or WSDL descriptors from UML models?, is there something
> I should read prior to the development?.
> Regards,
> Juan Pedro Silva
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Juan,<br>
<br>
what you want. You might also be interested in collaborating on the
proposed Servus EMFT component which will explore Ecore <-> WSDL
mapping:<br>
<blockquote><a
href="http://dev.eclipse.org/mhonarc/lists/emft-dev/msg00126.html">http://dev.eclipse.org/mhonarc/lists/emft-dev/msg00126.html</a><br>
</blockquote>
<br>
<blockquote cite="mid:fdtqi4$m4q$1@build.eclipse.org" type="cite">Hi
everybody.
<br>
<br>
around for things already available. I found some interesting projects:
M2T, WTP, M2M. However, all of them focus on a piece of the picture,
<br>
<br>
<br>
<br>
<br>
Juan Pedro Silva
<br>
</blockquote>
<br>
</body>
</html>
--------------060901040903050709010906--
Re: UML2 -> XML artifacts [message #476262 is a reply to message #476260] |
Wed, 03 October 2007 13:45  |
Ed, thank you very much for your answer, I found it very interesting.
I will forward the Servus proposal to the people in charge of the
project, and see what they have to say.
Thank you again.
Ed Merks escribió:
> Juan,
>> Hi everybody.
>> Regards,
>> Juan Pedro Silva
Re: UML2 -> XML artifacts [message #625072 is a reply to message #476253] |
Juan,
> Hi everybody.
> Regards,
> Juan Pedro Silva
<html>
<head>
</head>
Juan,<br>
<br>
mapping:<br>
<blockquote><a
</blockquote>
<br>
everybody.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Juan Pedro Silva
<br>
</blockquote>
<br>
</body>
</html>
Re: UML2 -> XML artifacts [message #625074 is a reply to message #476260] |
Thank you again.
Ed Merks escribió:
> Juan,
>> Hi everybody.
>> Regards,
>> Juan Pedro Silva
Current Time: Sat Aug 30 06:21:25 EDT 2025
Powered by FUDForum. Page generated in 0.03493 seconds
