Home » Archived » Eclipse Communications Framework (ECF) » Distributed Event Admin Problems
Distributed Event Admin Problems [message #624990] Tue, 12 January 2010 04:47 Go to next message
Hi all,
I'm doing some test using ECF distributed Event Admin as described here ( http://wiki.eclipse.org/Distributed_EventAdmin_Service ).
I'm trying to use the JMS ( ActiveMQ ) implementation. so i've done the following step:
1) I've downloaded and started active mq ( 5.3 )
2) Follow the instruction at eclipse wiki and installed the examples
3) Installed the jms provider from http://ecf1.osuosl.org/
4) try to run the examples.
The Problems i've are:
1) I've an initial exception when trying to run the Event Admin server ( activemq product ). This is not blocking, it seems this exception is raised but the code is working, i've see messages enqued and dequed from the AMQ console.
12-gen-2010 10.35.48 org.apache.activemq.transport.tcp.TcpTransportFactory createTransport
AVVERTENZA: path isn't a valid local location for TcpTransport to use
java.lang.NumberFormatException: For input string: "/exampleTopic"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at org.apache.activemq.transport.tcp.TcpTransportFactory.create Transport(TcpTransportFactory.java:125)
at org.apache.activemq.transport.TransportFactory.doConnect(Tra nsportFactory.java:141)
at org.apache.activemq.transport.TransportFactory.doConnect(Tra nsportFactory.java:51)
at org.apache.activemq.transport.TransportFactory.connect(Trans portFactory.java:80)
at org.apache.activemq.ActiveMQConnectionFactory.createTranspor t(ActiveMQConnectionFactory.java:237)
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQ Connection(ActiveMQConnectionFactory.java:252)
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQ Connection(ActiveMQConnectionFactory.java:224)
at org.apache.activemq.ActiveMQConnectionFactory.createConnecti on(ActiveMQConnectionFactory.java:172)
at org.eclipse.ecf.provider.jms.channel.AbstractJMSChannel.setu pJMS(AbstractJMSChannel.java:167)
at org.eclipse.ecf.provider.jms.channel.AbstractJMSServerChanne l. <init>(AbstractJMSServerChannel.java:33)
at org.eclipse.ecf.provider.jms.activemq.container.ActiveMQServ erChannel. <init>(ActiveMQServerChannel.java:24)
at org.eclipse.ecf.provider.jms.activemq.container.ActiveMQJMSS erverContainer.start(ActiveMQJMSServerContainer.java:38)
at org.eclipse.ecf.internal.provider.jms.activemq.ActiveMQJMSSe rverContainerInstantiator.createInstance(ActiveMQJMSServerCo ntainerInstantiator.java:57)
at org.eclipse.ecf.core.ContainerFactory.createContainer(Contai nerFactory.java:287)
at org.eclipse.ecf.core.ContainerFactory.createContainer(Contai nerFactory.java:306)
at org.eclipse.ecf.examples.internal.eventadmin.app.AbstractEve ntAdminApplication.createConfigureAndConnectContainer(Abstra ctEventAdminApplication.java:157)
at org.eclipse.ecf.examples.internal.eventadmin.app.AbstractEve ntAdminApplication.startup(AbstractEventAdminApplication.jav a:65)
at org.eclipse.ecf.examples.internal.eventadmin.app.AbstractEve ntAdminApplication.start(AbstractEventAdminApplication.java: 105)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
2) I've try to run two instance of the Event Admin server ( activemq product ), but this does not work because activemq is refusing my connection with this stacktrace:
WARN | Failed to add Connection
javax.jms.InvalidClientIDException: Broker: localhost - Client: tcp://localhost:
61616/exampleTopic already connected from /127.0.0.1:49513
at org.apache.activemq.broker.region.RegionBroker.addConnection (RegionBr
oker.java:216)
at org.apache.activemq.broker.BrokerFilter.addConnection(Broker Filter.ja
va:82)
va:82)
at org.apache.activemq.advisory.AdvisoryBroker.addConnection(Ad visoryBro
ker.java:77)
va:82)
at org.apache.activemq.broker.MutableBrokerFilter.addConnection (MutableB
rokerFilter.java:89)
at org.apache.activemq.broker.TransportConnection.processAddCon nection(T
ransportConnection.java:666)
at org.apache.activemq.broker.jmx.ManagedTransportConnection.pr ocessAddC
onnection(ManagedTransportConnection.java:83)
at org.apache.activemq.command.ConnectionInfo.visit(ConnectionI nfo.java:
134)
at org.apache.activemq.broker.TransportConnection.service(Trans portConne
ction.java:297)
at org.apache.activemq.broker.TransportConnection$1.onCommand(T ransportC
onnection.java:175)
at org.apache.activemq.transport.TransportFilter.onCommand(Tran sportFilt
er.java:68)
at org.apache.activemq.transport.WireFormatNegotiator.onCommand (WireForm
atNegotiator.java:113)
at org.apache.activemq.transport.InactivityMonitor.onCommand(In activityM
onitor.java:210)
at org.apache.activemq.transport.TransportSupport.doConsume(Tra nsportSup
port.java:84)
at org.apache.activemq.transport.tcp.TcpTransport.doRun(TcpTran sport.jav
a:203)
at org.apache.activemq.transport.tcp.TcpTransport.run(TcpTransp ort.java:
185)
at java.lang.Thread.run(Thread.java:619)
This seems to be an activemq problem, but i'd like to see if anyone know how to solve.
Any thougths???
Andrea
Re: Distributed Event Admin Problems [message #624991 is a reply to message #624990] Thu, 14 January 2010 13:39 Go to previous message
Hi Andrea,
Andrea Zoppello wrote:
> Hi all,
> following step:
> the AMQ console.
Yes. This is a non-fatal bug in ActiveMQ 5.2. I've reported this bug
here: https://issues.apache.org/activemq/browse/AMQ-2256
It's possible this may be fixed in a more recent release, but I have not
yet tried out something newer than 5.2.
<stuff deleted>
> tcp://localhost:
> (RegionBr
> oker.java:216)
> Filter.ja
> va:82)
> Filter.ja
> va:82)
> visoryBro
> ker.java:77)
> Filter.ja
> va:82)
> (MutableB
> nection(T
> ocessAddC
> nfo.java:
> 134)
> portConne
> ction.java:297)
> ransportC
> onnection.java:175)
> sportFilt
> er.java:68)
> (WireForm
> activityM
> onitor.java:210)
> nsportSup
> port.java:84)
> sport.jav
> a:203)
> ort.java:
> 185)
> how to solve.
There can be only one manager/server process associated with a given JMS
topic (in this case, the server being started is using the default
uri/topic...which is tcp://localhost:61616/exampleTopic
So if you want to create/start/run more than one server, all you need to
do is create/specify/use another topic...e.g.:
tcp://localhost:61616/myTopic
In the example server (i.e. the one in
org.eclipse.ecf.examples.remoteservices.hello.host), their is a command
line argument...e.g.:
-containerId tcp://localhost:61616/myTopic
that allows the server containerId to be specified on the command line
along with the container *type*...i.e.
-containerType ecf.jms.activemq.tcp.manager
If you look in the product configuration file:
/org.eclipse.ecf.examples.remoteservices.hello.host/products /Hello
Service Host (activemq).product
You will see that these Program Arguments are listed (on the Launching
tab of the product configuration editor):
-containerId tcp://localhost:61616/exampleTopic
You can/could easily just create a new product file, copied from the
existing one, and change the command line arguments to be (e.g.)
Or, you can have a completely different/new application (i.e. not this
HelloHostApplication, and specify the containerType and containerId any
way you like (via properties file, as program arguments, hardcoded into
the app, etc).
Scott
Previous Topic:Datashare not available with ecf.generic.server
Next Topic:Distributed Event Admin Problems
Current Time: Wed Jul 23 11:22:50 EDT 2025
Powered by FUDForum. Page generated in 0.04922 seconds
