Distributed Event Admin Problems [message #624990] |
Tue, 12 January 2010 04:47  |
Hi all,
I'm doing some test using ECF distributed Event Admin as described here ( http://wiki.eclipse.org/Distributed_EventAdmin_Service ).
I'm trying to use the JMS ( ActiveMQ ) implementation. so i've done the following step:
1) I've downloaded and started active mq ( 5.3 )
2) Follow the instruction at eclipse wiki and installed the examples
3) Installed the jms provider from http://ecf1.osuosl.org/
4) try to run the examples.
The Problems i've are:
1) I've an initial exception when trying to run the Event Admin server ( activemq product ). This is not blocking, it seems this exception is raised but the code is working, i've see messages enqued and dequed from the AMQ console.
12-gen-2010 10.35.48 org.apache.activemq.transport.tcp.TcpTransportFactory createTransport
AVVERTENZA: path isn't a valid local location for TcpTransport to use
java.lang.NumberFormatException: For input string: "/exampleTopic"
at java.lang.NumberFormatException.forInputString(Unknown Source)
at java.lang.Integer.parseInt(Unknown Source)
at org.apache.activemq.transport.tcp.TcpTransportFactory.create Transport(TcpTransportFactory.java:125)
at org.apache.activemq.transport.TransportFactory.doConnect(Tra nsportFactory.java:141)
at org.apache.activemq.transport.TransportFactory.doConnect(Tra nsportFactory.java:51)
at org.apache.activemq.transport.TransportFactory.connect(Trans portFactory.java:80)
at org.apache.activemq.ActiveMQConnectionFactory.createTranspor t(ActiveMQConnectionFactory.java:237)
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQ Connection(ActiveMQConnectionFactory.java:252)
at org.apache.activemq.ActiveMQConnectionFactory.createActiveMQ Connection(ActiveMQConnectionFactory.java:224)
at org.apache.activemq.ActiveMQConnectionFactory.createConnecti on(ActiveMQConnectionFactory.java:172)
at org.eclipse.ecf.provider.jms.channel.AbstractJMSChannel.setu pJMS(AbstractJMSChannel.java:167)
at org.eclipse.ecf.provider.jms.channel.AbstractJMSServerChanne l. <init>(AbstractJMSServerChannel.java:33)
at org.eclipse.ecf.provider.jms.activemq.container.ActiveMQServ erChannel. <init>(ActiveMQServerChannel.java:24)
at org.eclipse.ecf.provider.jms.activemq.container.ActiveMQJMSS erverContainer.start(ActiveMQJMSServerContainer.java:38)
at org.eclipse.ecf.internal.provider.jms.activemq.ActiveMQJMSSe rverContainerInstantiator.createInstance(ActiveMQJMSServerCo ntainerInstantiator.java:57)
at org.eclipse.ecf.core.ContainerFactory.createContainer(Contai nerFactory.java:287)
at org.eclipse.ecf.core.ContainerFactory.createContainer(Contai nerFactory.java:306)
at org.eclipse.ecf.examples.internal.eventadmin.app.AbstractEve ntAdminApplication.createConfigureAndConnectContainer(Abstra ctEventAdminApplication.java:157)
at org.eclipse.ecf.examples.internal.eventadmin.app.AbstractEve ntAdminApplication.startup(AbstractEventAdminApplication.jav a:65)
at org.eclipse.ecf.examples.internal.eventadmin.app.AbstractEve ntAdminApplication.start(AbstractEventAdminApplication.java: 105)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
2) I've try to run two instance of the Event Admin server ( activemq product ), but this does not work because activemq is refusing my connection with this stacktrace:
WARN | Failed to add Connection
javax.jms.InvalidClientIDException: Broker: localhost - Client: tcp://localhost:
61616/exampleTopic already connected from /127.0.0.1:49513
at org.apache.activemq.broker.region.RegionBroker.addConnection (RegionBr
oker.java:216)
at org.apache.activemq.broker.BrokerFilter.addConnection(Broker Filter.ja
va:82)
va:82)
at org.apache.activemq.advisory.AdvisoryBroker.addConnection(Ad visoryBro
ker.java:77)
va:82)
at org.apache.activemq.broker.MutableBrokerFilter.addConnection (MutableB
rokerFilter.java:89)
at org.apache.activemq.broker.TransportConnection.processAddCon nection(T
ransportConnection.java:666)
at org.apache.activemq.broker.jmx.ManagedTransportConnection.pr ocessAddC
onnection(ManagedTransportConnection.java:83)
at org.apache.activemq.command.ConnectionInfo.visit(ConnectionI nfo.java:
134)
at org.apache.activemq.broker.TransportConnection.service(Trans portConne
ction.java:297)
at org.apache.activemq.broker.TransportConnection$1.onCommand(T ransportC
onnection.java:175)
at org.apache.activemq.transport.TransportFilter.onCommand(Tran sportFilt
er.java:68)
at org.apache.activemq.transport.WireFormatNegotiator.onCommand (WireForm
atNegotiator.java:113)
at org.apache.activemq.transport.InactivityMonitor.onCommand(In activityM
onitor.java:210)
at org.apache.activemq.transport.TransportSupport.doConsume(Tra nsportSup
port.java:84)
at org.apache.activemq.transport.tcp.TcpTransport.doRun(TcpTran sport.jav
a:203)
at org.apache.activemq.transport.tcp.TcpTransport.run(TcpTransp ort.java:
185)
at java.lang.Thread.run(Thread.java:619)
This seems to be an activemq problem, but i'd like to see if anyone know how to solve.
Any thougths???
Andrea
Re: Distributed Event Admin Problems [message #624991 is a reply to message #624990] |
Thu, 14 January 2010 13:39  |
Hi Andrea,
Andrea Zoppello wrote:
> Hi all,
> following step:
> the AMQ console.
Yes. This is a non-fatal bug in ActiveMQ 5.2. I've reported this bug
here: https://issues.apache.org/activemq/browse/AMQ-2256
It's possible this may be fixed in a more recent release, but I have not
yet tried out something newer than 5.2.
<stuff deleted>
> tcp://localhost:
> (RegionBr
> oker.java:216)
> Filter.ja
> va:82)
> Filter.ja
> va:82)
> visoryBro
> ker.java:77)
> Filter.ja
> va:82)
> (MutableB
> nection(T
> ocessAddC
> nfo.java:
> 134)
> portConne
> ction.java:297)
> ransportC
> onnection.java:175)
> sportFilt
> er.java:68)
> (WireForm
> activityM
> onitor.java:210)
> nsportSup
> port.java:84)
> sport.jav
> a:203)
> ort.java:
> 185)
> how to solve.
There can be only one manager/server process associated with a given JMS
topic (in this case, the server being started is using the default
uri/topic...which is tcp://localhost:61616/exampleTopic
So if you want to create/start/run more than one server, all you need to
do is create/specify/use another topic...e.g.:
tcp://localhost:61616/myTopic
In the example server (i.e. the one in
org.eclipse.ecf.examples.remoteservices.hello.host), their is a command
line argument...e.g.:
-containerId tcp://localhost:61616/myTopic
that allows the server containerId to be specified on the command line
along with the container *type*...i.e.
-containerType ecf.jms.activemq.tcp.manager
If you look in the product configuration file:
/org.eclipse.ecf.examples.remoteservices.hello.host/products /Hello
Service Host (activemq).product
You will see that these Program Arguments are listed (on the Launching
tab of the product configuration editor):
-containerId tcp://localhost:61616/exampleTopic
You can/could easily just create a new product file, copied from the
existing one, and change the command line arguments to be (e.g.)
Or, you can have a completely different/new application (i.e. not this
HelloHostApplication, and specify the containerType and containerId any
way you like (via properties file, as program arguments, hardcoded into
the app, etc).
Scott
FUDForum. Page generated in 0.02732 seconds
