Re: Problem while trying to export graphic from diagram [message #624692] |
Mon, 10 August 2009 10:10  |
I think this is a UML2Tools issue.
The UML2 project doesn't depend on GMF.
- James.
"Eduard Bauer" <edebauer@mail.upb.de> wrote in message
news:h599tq$776$1@build.eclipse.org...
> Hey out there,
> I have just started to use the tools fro the uml2. But as soon as I try to
> export an arbitrary (right mouse click->File->Save As Image->PDF (or
> anything else), I get the following warning in the error view
> java.lang.NoClassDefFoundError:
> org/eclipse/gmf/runtime/draw2d/ui/render/awt/internal/svg/ex port/GraphicsSVG
> at
> org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.getDiagramGenerator(CopyToImageUtil.java:344)
> at
> org.eclipse.gmf.runtime.diagram.ui.render.util.CopyToImageUt il.copyToImage(CopyToImageUtil.java:303)
> at
> org.eclipse.gmf.runtime.diagram.ui.render.actions.CopyToImag eAction$1.run(CopyToImageAction.java:257)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:464)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:372)
> at
> org.eclipse.jface.dialogs.ProgressMonitorDialog.run(Progress MonitorDialog.java:507)
> at
> org.eclipse.gmf.runtime.diagram.ui.render.actions.CopyToImag eAction.runCopyToImageUI(CopyToImageAction.java:167)
> at
> org.eclipse.gmf.runtime.diagram.ui.render.actions.CopyToImag eAction.run(CopyToImageAction.java:136)
> at
> org.eclipse.gmf.runtime.diagram.ui.render.actions.CopyToImag eAction$2.run(CopyToImageAction.java:389)
> at
> org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:313)
> at
> org.eclipse.gmf.runtime.diagram.ui.render.actions.CopyToImag eAction.doRun(CopyToImageAction.java:385)
> at
> org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.run(AbstractActionHandler.java:359)
> at
> org.eclipse.gmf.runtime.common.ui.action.ActionManager$1.run (ActionManager.java:225)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
> at
> org.eclipse.gmf.runtime.common.ui.action.ActionManager.run(A ctionManager.java:223)
> at
> org.eclipse.gmf.runtime.common.ui.action.AbstractActionHandl er.runWithEvent(AbstractActionHandler.java:377)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1200)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1185)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 025)
> at
> org.eclipse.jface.action.ActionContributionItem$9.handleEven t(ActionContributionItem.java:1284)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> Caused by:
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
> An error occurred while automatically activating bundle
> org.eclipse.gmf.runtime.draw2d.ui.render.awt (386).
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
> at
> org.eclipse.osgi.internal.loader.SingleSourcePackage.loadCla ss(SingleSourcePackage.java:33)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:449)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
> ... 49 more
> Caused by: org.osgi.framework.BundleException: The activator
> org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.Draw2d RenderPlugin
> for bundle org.eclipse.gmf.runtime.draw2d.ui.render.awt is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:157)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:750)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:352)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:280)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
> ... 59 more
> Caused by: java.lang.InternalError: libXt loaded before libXm
> at java.lang.ClassLoader$NativeLibrary.load(Native Method)
> at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1778)
> at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1695)
> at java.lang.Runtime.loadLibrary0(Runtime.java:823)
> at java.lang.System.loadLibrary(System.java:1028)
> at sun.security.action.LoadLibraryAction.run(LoadLibraryAction. java:50)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.awt.Toolkit.loadLibraries(Toolkit.java:1592)
> at java.awt.Toolkit.<clinit>(Toolkit.java:1614)
> at java.awt.Color.<clinit>(Color.java:263)
> at
> org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.Draw2d RenderPlugin.initAWT(Draw2dRenderPlugin.java:56)
> at
> org.eclipse.gmf.runtime.draw2d.ui.render.awt.internal.Draw2d RenderPlugin. <init>(Draw2dRenderPlugin.java:52)
> at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
> at
> sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
> at
> sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
> at java.lang.reflect.Constructor.newInstance(Constructor.java:5 13)
> at java.lang.Class.newInstance0(Class.java:355)
> at java.lang.Class.newInstance(Class.java:308)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:152)
> ... 64 more
> I am using Eclipse Galileo, and have installed the UML2 tools today via
> the updater. Have I missed to install a particular package, or is this a
> known problem?
> Thanks for any help
> Kind regards
> Ede
FUDForum. Page generated in 0.05412 seconds
