Home » Archived » Eclipse Communications Framework (ECF) » Question about adding docshare to custom editor
Question about adding docshare to custom editor [message #624674] Tue, 06 January 2009 12:42 Go to next message
Greetings all,
I've got a custom editor and I'd like to implement DocShare support.
I've added the appropriate xml to the plugin.xml file as described here:
http://wiki.eclipse.org/Extending_Real-Time_Shared_Editing_f or_Use_with_Other_Editors
My editor extends TextEditor but does not currently implement
IDocumentListener. however, when I tried sharing, it did in fact work
correctly.
So my question is: why do I need to implement IDocumentListener, and what
should I put into the two function overrides? I tried looking at the php
example linked in that wiki page, but it returns a 404 error.
Thanks.
marc
Re: Question about adding docshare to custom editor [message #624676 is a reply to message #624674] Tue, 06 January 2009 14:02 Go to previous messageGo to next message
Hi Marc,
Marc Esher wrote:
> Greetings all,
> correctly.
> what should I put into the two function overrides?
No, this was an error in the documentation. I've fixed it...thanks!
I tried looking at
> the php example linked in that wiki page, but it returns a 404 error.
This was also an error in the documentation caused by our moving from
Technology to runtime project. I've removed this as well.
Scott
Re: Question about adding docshare to custom editor [message #624677 is a reply to message #624676] Tue, 06 January 2009 16:14 Go to previous messageGo to next message
Originally posted by: marc.esher.comcast.net
sweet, thanks a lot Scott.
One other question: have you ever seen or heard of a scenario where, once a
file is shared over DocShare, it becomes read-only?
I had a report of this today and haven't gotten any more information on it,
but was wondering if this is a known issue, or at least if there are known
causes.
thanks!
marc
"Scott Lewis" <slewis@composent.com> wrote in message
news:4963AACE.3050405@composent.com...
> Hi Marc,
> Marc Esher wrote:
>> Greetings all,
>> correctly.
> I tried looking at
> Scott
Re: Question about adding docshare to custom editor [message #624679 is a reply to message #624677] Wed, 07 January 2009 11:15 Go to previous message
Hi Marc,
> once a file is shared over DocShare, it becomes read-only?
No...I haven't heard of this happening that I can recall. Does this
happen on the initiator, receiver, or both? Please open a bug report if
you can reproduce.
> it, but was wondering if this is a known issue, or at least if there are
> known causes.
No, not from me.
Scott
> thanks!
> marc
>> Hi Marc,
>> Marc Esher wrote:
>>> Greetings all,
>>> here:
>>> correctly.
>> I tried looking at
>> Scott
Previous Topic:file sharing in ECF
Next Topic:Activated APITooling for _all_ ECF
Current Time: Sat Jul 26 02:13:17 EDT 2025
Powered by FUDForum. Page generated in 0.07122 seconds
