Home » Archived » Eclipse Communications Framework (ECF) » Question about adding docshare to custom editor
Re: Question about adding docshare to custom editor [message #624677 is a reply to message #624676] |
Tue, 06 January 2009 16:14   |
Originally posted by: marc.esher.comcast.net
sweet, thanks a lot Scott.
One other question: have you ever seen or heard of a scenario where, once a
file is shared over DocShare, it becomes read-only?
I had a report of this today and haven't gotten any more information on it,
but was wondering if this is a known issue, or at least if there are known
causes.
thanks!
marc
"Scott Lewis" <slewis@composent.com> wrote in message
news:4963AACE.3050405@composent.com...
> Hi Marc,
> Marc Esher wrote:
>> Greetings all,
>> I've got a custom editor and I'd like to implement DocShare support.
>> I've added the appropriate xml to the plugin.xml file as described here:
>> http://wiki.eclipse.org/Extending_Real-Time_Shared_Editing_f or_Use_with_Other_Editors
>> My editor extends TextEditor but does not currently implement
>> IDocumentListener. however, when I tried sharing, it did in fact work
>> correctly.
>> So my question is: why do I need to implement IDocumentListener, and what
>> should I put into the two function overrides?
> No, this was an error in the documentation. I've fixed it...thanks!
> I tried looking at
>> the php example linked in that wiki page, but it returns a 404 error.
> This was also an error in the documentation caused by our moving from
> Technology to runtime project. I've removed this as well.
> Scott
Re: Question about adding docshare to custom editor [message #624679 is a reply to message #624677] |
Wed, 07 January 2009 11:15  |
Hi Marc,
> once a file is shared over DocShare, it becomes read-only?
No...I haven't heard of this happening that I can recall. Does this
happen on the initiator, receiver, or both? Please open a bug report if
you can reproduce.
> it, but was wondering if this is a known issue, or at least if there are
> known causes.
No, not from me.
Scott
> thanks!
> marc
>> Hi Marc,
>> Marc Esher wrote:
>>> Greetings all,
>>> here:
>>> correctly.
>>> what should I put into the two function overrides?
>> I tried looking at
>> Scott
Current Time: Wed Jul 23 05:46:38 EDT 2025
Powered by FUDForum. Page generated in 0.03471 seconds
