Home » Modeling » UML2 Tools » Transition labels in state diagram not displayed
Transition labels in state diagram not displayed [message #476563] Fri, 26 June 2009 06:26 Go to next message
Hi all,
When I create a state diagram with transitions the labels of those transitions
aren't displayed in the graph (the transition arrows are displayed corectly).
I made sure that the transition have proper names using the Property View.
Am I missing a config property or something?
I am using:
Eclipse 3.5.0
UML2 Tools SDK (Incubation) 0.9.0.v200906031456
Jens
Re: Transition labels in state diagram not displayed [message #476570 is a reply to message #476563] Tue, 30 June 2009 07:38 Go to previous messageGo to next message
Hi Jens,
According UML specification: "Notation for a transition is defined by the
following BNF expression: <transition> ::= [<trigger> [',' <trigger>]* ['['
<guard-constraint>']'] ['/' <behavior-expression>]]"
So, the notation doesn't contain name of transition.
Sergey.
"Jens Rutschmann" <Jens.Rutschmann@gmx.info> wrote in message
news:h227o5$v4j$1@build.eclipse.org...
> Hi all,
> transitions aren't displayed in the graph (the transition arrows are
> I am using:
> Eclipse 3.5.0
> Best regards,
> Jens
Re: Transition labels in state diagram not displayed [message #491947 is a reply to message #476570] Fri, 16 October 2009 12:42 Go to previous messageGo to next message
Hi all,
I use :
Eclipse Modeling Tools 1.2.1.20090918-0703
Eclipse Platform 3.5.1.M20090917-0800
UML2 Tools SDK (Incubation) 0.9.0.v200906190654
and I Have exactly the same problem.
I don't understand Sergey answer. Is there a way to display something (name, guard, label or whatever...) on transitions arrows in state diagram ?
Is it a future functionnality ?
When I select an arrow, and type a text, it disappears at once when I click "Enter".
The way to solve it is to create a "Text" and position it next to the arrow, but it's not linked to the arrow.
[Updated on: Fri, 16 October 2009 13:02] by Moderator
Re: Transition labels in state diagram not displayed [message #495066 is a reply to message #491947] Tue, 03 November 2009 12:11 Go to previous messageGo to next message
I interpret Sergeys answer:
as the UML specification says that a transition can be defined as zero, one or many triggers, followed by an optional guard constraint, followed by an optional behaviour expression.
If this is correct, then this means that the UML specification does not allow the name to be visible on the transition arrow in the diagram.
But I don't know this as a fact, this but it is my understanding of Sergeys answer above.
/Johan
Re: Transition labels in state diagram not displayed [message #497010 is a reply to message #476570] Thu, 12 November 2009 04:12 Go to previous messageGo to next message
Sergey Gribovsky wrote on Tue, 30 June 2009 07:38
Hi Jens,
Sergey.
Nevertheless the very first UML tutorial, linked from OMG's own uml.org site shows transition labels:
http://edn.embarcadero.com/article/31863#statechart-diagrams
http://edn.embarcadero.com/article/images/31863/statediagno3d.gif
Obviously, so should eclipse.
Re: Transition labels in state diagram not displayed [message #516682 is a reply to message #476563] Wed, 24 February 2010 13:37 Go to previous messageGo to next message
Yes, this is annoying for people who just want to create those diagram for documentation purpose only.
Re: Transition labels in state diagram not displayed [message #520618 is a reply to message #516682] Sat, 13 March 2010 06:22 Go to previous messageGo to next message
The above discussion suggests it ought to be possible to use a trigger as a substitute for the name as it should display.
So, what I did was:
- Activate context menu for a state transition
- Select Show Properties View
- Click the Show Advanced Properties icon on the right
- Scroll down and select the Trigger entry
- Press the [...] button on the right
- A new Trigger - <Transition> dialog appears
However its Choices panel is empty, with no immediately obvious way to change that.
So, how can I (non-programmatically) create Triggers for this field?
Thanks for any input Smile
Re: Transition labels in state diagram not displayed [message #520657 is a reply to message #520618] Sat, 13 March 2010 14:41 Go to previous messageGo to next message
I haven't tried this in eclipse, but I think it used to work in ArgoUML...
Try typing the text right on the arrow as you normally would, and begin it with a forward slash. This might trick the editor as treating your label as a behavior expression.
Not sure if it will work (I don't have eclipse installed on the machine I'm posting from) but it might be worth a shot.
Re: Transition labels in state diagram not displayed [message #624508 is a reply to message #476563] Tue, 30 June 2009 07:38 Go to previous messageGo to next message
Hi Jens,
Sergey.
> Hi all,
> I am using:
> Eclipse 3.5.0
> Best regards,
> Jens
Re: Transition labels in state diagram not displayed [message #624909 is a reply to message #476570] Fri, 16 October 2009 12:42 Go to previous messageGo to next message
Hi all,
I use :
The way to do it is to create a "Text" and position it next to the arrow, but it's not linked to the arrow.
Re: Transition labels in state diagram not displayed [message #625131 is a reply to message #624909] Tue, 03 November 2009 12:11 Go to previous messageGo to next message
/Johan
Re: Transition labels in state diagram not displayed [message #625158 is a reply to message #476570] Thu, 12 November 2009 04:13 Go to previous messageGo to next message
> Hi Jens,
> Best regards,
> Sergey.
Re: Transition labels in state diagram not displayed [message #625500 is a reply to message #476563] Wed, 24 February 2010 13:37 Go to previous messageGo to next message
Re: Transition labels in state diagram not displayed [message #625584 is a reply to message #625500] Sat, 13 March 2010 06:22 Go to previous messageGo to next message
So, what I did was:
Thanks for any input :)
Re: Transition labels in state diagram not displayed [message #625585 is a reply to message #625584] Sat, 13 March 2010 14:41 Go to previous messageGo to next message
Re: Transition labels in state diagram not displayed [message #633830 is a reply to message #624508] Tue, 19 October 2010 10:36 Go to previous message
Nevertheless, if you context-click on a transition, and go Filters > Show/Hide connector labels, you can choose 'all connector labels' or 'no connector labels'. So it would seem this option is meant to be included. However, it doesn't seem to do anything at the moment and labels are not displayed.
I second that it would be very useful. I am trying to use UML to visualize a problem that I have, not to generate code.
This 'bug' is being worked on in Papyrus, at least:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=290237
Previous Topic:delete a tool
Next Topic:applyprofile
Current Time: Thu Nov 06 14:44:43 EST 2025
Powered by FUDForum. Page generated in 0.05501 seconds
