Problems with file transfer over XMPP [message #624450] |
Thu, 11 December 2008 07:01  |
I'm using Ganymede SR1 and ECF with XMPP (Open Fire) to send a file. Other
things, like sending a message, URL, screen shots and even shared editing works.
The idea is sending a file to sync before shared editing.
The error message states that the provided user id was not fully qualified.
Hallvard
Re: Problems with file transfer over XMPP [message #624634 is a reply to message #624633] |
Mon, 15 December 2008 19:18  |
Hi Hallvard,
Hallvard Trætteberg wrote:
> Scott,
>>> qualified.
>> Could you post the error message?
> There was a popup stating the provided user id for the XMPP provider was
> not fully qualified, or something very similar. There is no entry in the
> error log.
>> And what version of ECF are you using? There was some recent work on
>> the user identification for XMPP, and the problem you experienced may
>> have been a side effect.
> org.eclipse.ecf 2.0.0-v20080611-1715
> org.eclipse.ecf.provider.xmpp 2.0.100-v20080916-1301
OK, thanks.
I just tried out the file transfer on the current version of the ECF
source (i.e. HEAD/ECF 3.0) and it worked fine.
Would you be willing to get/build the source for
org.eclipse.ecf.provider.xmpp (and dependents) and running it in your
environment to attempt to reproduce? If you are unable to reproduce
then I suspect that the problem you were experiencing with 2.0.100 was
due to an issue with the resource part of the XMPPID, which I've
recently done a fair amount to as per this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246155
The ecf projects are available in CVS and instructions for accessing
them is available here
http://www.eclipse.org/ecf/dev_resources.php
Thanksinadvance.
Scott
> Hallvard
FUDForum. Page generated in 1.12970 seconds
