Home » Archived » Eclipse Communications Framework (ECF) » Container/Adapter creation problem
Container/Adapter creation problem [message #624205] Fri, 10 October 2008 11:26 Go to next message
Hello All,
I am working on a RCP application based on ECF. I case of the RCP app, for
calls made to the generic container(ecf.generic.client), I get null value
for the IChannelContainerAdapter. Unlike that, if I use the same code in a
plug-in, things work fine and I get proper values for the containers and
adapters.
I would like to know the following.
1. Do I need to add additional plug-in's(apart from the ones present -
*.ecf,*.ecf.datashare, *.ecf.provider) as part of the dependency in case
of an RCP application.
- One difference that I noticed - in case of a plug-in things work fine,
even if I don't introduce org.eclipse.ecf.provider plug-in as part of the
dependency list, unlike that I had to add *.provider dependency in case of
the RCP application.
2. Do I need to make any changes in the code to get things working.
I am using:
Eclipse Ganymede release
org.eclipse.ecf - 2.0
*.datashare - 1.3.0
*.provider - 1.3.0
I am a bit new to the ECF world, so I may have missed something. I would
be happy to know more about the things I should be careful about while
writing RCP applications based on ECF.
Thanks in advance.
Re: Container/Adapter creation problem [message #624206 is a reply to message #624205] Fri, 10 October 2008 14:52 Go to previous messageGo to next message
Hi Neeraj,
Neeraj wrote:
> Hello All,
> for calls made to the generic container(ecf.generic.client), I get null
> value for the IChannelContainerAdapter. Unlike that, if I use the same
> code in a plug-in, things work fine and I get proper values for the
> containers and adapters.
It's not so much that it's an RCP app, but rather that it's trying to
get the IChannelContainerAdapter.
For the ECF generic provider, this adapter (IChannelContainerAdapter) is
actually implemented by the org.eclipse.ecf.provider.datashare plugin.
The reason this is done this way...i.e. having the adapters implemented
in different plugins...is so that consumers don't have to include things
they don't need/want. The cost of this approach is that consumers that
*do* want these capabilities need to include them in the dependencies
list explicitly (since clients don't generally refer to the impls
directly in their code, but rather to the API).
> the dependency list, unlike that I had to add *.provider dependency in
> case of the RCP application.
I don't think to the code, but rather to the set of plugins that are
included in your application. I believe you should be able to add
org.eclipse.ecf.provider.datashare (and include its dependencies) and
then an IChannelContainerAdapter will be available for the ECF generic
client.
> I am using:
> *.datashare - 1.3.0
> *.provider - 1.3.0
Just so it's clear, this is a consequence of the design choice described
above...moving the generic client's datashare impl out of the
org.eclipse.ecf.provider bundle, and into a separate bundle. As
mentioned above, it's good when it means that you don't need to include
what you don't want, but it does result in some potential confusion when
you want to use the channel container adapter as you do. My apolologies
for that.
At some point it would be really nice to have for each provider
(starting with the ECF generic) a written description of where all of
its adapters are implemented (i.e. which plugins). This could be
presented as a table or something that people could refer to. If you
would like to open a doc enhancement request to this effect that would
be very helpful.
Scott
Re: Container/Adapter creation problem [message #624207 is a reply to message #624206] Mon, 13 October 2008 01:25 Go to previous messageGo to next message
Thanks Scott for the detailed reply. I am happy to know that I don't
really have to do things differently while writing an ECF base RCP
application, thanks for clearing out the confusion.
Secondly, I have created an example application - A RCP based browser with
real time capabilities. I don't know how helpful it could be to the ECF
community, but I would like to contribute it to the ECF examples section.
I would be happy if you could help me in the same.
As you had suggested, I have opened a doc enhancement request -
https://bugs.eclipse.org/bugs/show_bug.cgi?id=250597
Thanks again.
Neeraj
Scott Lewis wrote:
> Hi Neeraj,
> Neeraj wrote:
>> Hello All,
> client.
>> I am using:
>> *.datashare - 1.3.0
>> *.provider - 1.3.0
> for that.
> be very helpful.
> Scott
Re: Container/Adapter creation problem [message #624208 is a reply to message #624207] Mon, 13 October 2008 11:36 Go to previous messageGo to next message
Hi Neeraj,
> application, thanks for clearing out the confusion. Secondly, I have
> created an example application - A RCP based browser with real time
> capabilities. I don't know how helpful it could be to the ECF community,
> but I would like to contribute it to the ECF examples section. I would
Of course! Thanks for your contribution offer!
Probably the best way to go about this would be for you to post a short
note describing the work in a little more technical detail to the
ecf-dev mailing list (ecf-dev at eclipse.org). Then I will create an
appropriate enhancement request based upon your description, and you can
then attach the contribution as a patch (or zip, whichever is better for
you) to that enhancement request. That way we can both look at it/play
with it, as well as begin the process necessary for IP review.
How does this sound to you? If you wish to contact me directly please
do so at slewis at composent.com.
Thanks very much!
Scott
Re: Container/Adapter creation problem [message #624210 is a reply to message #624208] Tue, 14 October 2008 08:05 Go to previous message
Scott Lewis wrote:
Hello Scott,
> Hi Neeraj,
This sounds great. I'll drop an email to the ecf-dev mailing list with the
technical details about the application, ASAP.
> Thanks very much!
> Scott
Thanks again
Neeraj
Previous Topic:Reminder: ECF Conference Call Tues, Oct 7
Next Topic:ASM Dependency
Current Time: Sun Jul 27 14:08:10 EDT 2025
Powered by FUDForum. Page generated in 0.03628 seconds
