Home » Eclipse Projects » Platform - User Assistance (UA) » Re: Testing Help Runtime
Re: Testing Help Runtime [message #624187] Fri, 18 June 2010 14:46 Go to next message
Chris Goldthorpe wrote on Fri, 18 June 2010 14:27
> I can't see from the log why it is failing - the infocenter started with no problem for me using 3.6RC4. Maybe the port is in use.
Yeah, I just tried it again and this time I got some kind of bundle issue. Looks like I've left something out, but rather than spend time on it I just ran with all plugins. That doesn't actually take that long since there is no UI. For the record, here's the error log:
!ENTRY org.eclipse.help.base 4 0 2010-06-16 17:59:39.215!MESSAGE Help cannot be displayed. The embedded application server could not ru
n help web application.!STACK 0
java.lang.NullPointerException at org.eclipse.help.internal.server.JettyHelpServer.checkBundle (JettyHel
pServer.java:112)
at org.eclipse.help.internal.server.JettyHelpServer.start(Jetty HelpServer.java:103)
at org.eclipse.help.internal.server.WebappManager.start(WebappM anager.java:38)
at org.eclipse.help.internal.base.BaseHelpSystem.ensureWebappRu nning(Bas
eHelpSystem.java:182)
Re: Testing Help Runtime [message #624192 is a reply to message #624187] Wed, 23 June 2010 13:23 Go to previous message
It looks as though "org.eclipse.equinox.http.registry" is not getting loaded.
Previous Topic:Change the order of plug-ins in table of content
Next Topic:Turn OFF DEBUG org.mortbay.log???
Current Time: Fri Jul 25 21:38:01 EDT 2025
Powered by FUDForum. Page generated in 0.17819 seconds
