retrieving model info [message #474748] |
Tue, 31 July 2007 06:35  |
Originally posted by: nickkirtley.gmail.com
hi,
If I have a model. One with components , interfaces and ports. How could I
view this model textually (a very basic view). Lets say a list of
components, ports and interfaces. Not even who is linked to who.
example:
component a
b
port ab
interface z
something like that.
thx
Nick
Re: retrieving model info [message #474759 is a reply to message #474756] |
Wed, 01 August 2007 11:22   |
Nick,
1. Consider launching Eclipse with arguments to increase memory, e.g. I
always launch with -vmargs -Xmx1024M -Xms256M.
2. Open the 'CVS Repository Exploring' perspective, create a new repository
location with the following properties:
Connection type: pserver
User: anonymous (no password)
Host: dev.eclipse.org
Repository path: /cvsroot/modeling
3. Select HEAD/org.eclipse.mdt/org.eclipse.uml2.releng, right click, and
select 'Check Out' from the context menu. If you want the source from a
maintenance stream, select 'Check Out As...' and specify a branch, e.g.
R2_1_maintenance.
4. Go the to Package Explorer in the 'Java' perspective, expand to, and
highlight, org.eclipse.uml2.releng/uml2.psf, right click and select 'Import
Project Set...' from the context menu.
5. Go back to the 'CVS Repository Exploring' perspective, select all the
projects under HEAD/org.eclipse.mdt/org.eclipse.uml2tools/plugins/, right
click, and select 'Check Out'. If you want the source from a maintenance
stream, select 'Check Out As...' and specify a branch.
Kenn
"Nick Kirtey" <nickkirtley@gmail.com> wrote in message
news:9034e60ab3473197b4932121bff614c0$1@www.eclipse.org...
> Hi Kenn,
> There's another seperate question I have.
> I've been trying to build the UML2Tools project and I'd also like to build
> uml2 as well.
> I want to do this so I can change the code and study the effect.
> What I did was project->new. cvs project. I chose MDT. it downloaded MDT.
> Then I chose all the src files in the build path. Eclipse then built the
> workspace and I got an error - java heap error, lack of memory.
> Could you explain to me how I can have the MDT project (at least uml2tools
> and uml2) in my workspace and that I can change code and compile results?
> (step by step plz)
> thx a lot
> Nick
Re: retrieving model info [message #474872 is a reply to message #474868] |
Thu, 02 August 2007 11:56  |
Nick,
Sorry about that - just modify the uml2.psf file in your workspace by
replacing 'extssh' with 'pserver' and you should be good to go.
Alternatively, you can just check out all of the projects under the
org.eclipse.uml2/plugins folder as I've suggested you do for UML2 Tools...
Kenn
news:4888cc4b21dc9267cbf29c61d59dec95$1@www.eclipse.org...
> Hi Kenn
> I got to step 4. When I try that it asks for a username/password. I tried
> anonymous/blank and anonymous/anonymous but it doesn't accept the
> password.
> I think I might know why. In my cvs view I have a pserver connection to
> dev.eclipse.org. When I try to import project set it asks for user/pass
> and it fails. After that I have a new cvs connection using extssh to
> dev.eclipse.org. It won't use pserver conn. type. Maybe this isn't the
> reason but the fact remains that I cannot import project set due to
> password error.
> could you tell me how to solve this problem?
> thx
> nick
Re: retrieving model info [message #624146 is a reply to message #474748] |
Tue, 31 July 2007 09:45  |
Nick,
You could do this a number of different ways. One way would be to iterate
over the content tree of the model, e.g. using EObject#eAllContents() or
Element#allOwnedElements(), printing out the names (or labels, e.g.
NamedElement#getLabel()) of each element you encounter...
Kenn
news:7beae005a60e1c8c746dff975f366efc$1@www.eclipse.org...
> hi,
> example:
> component a
> b
> port ab
> interface z
> thx
> Nick
Re: retrieving model info [message #624152 is a reply to message #474750] |
Wed, 01 August 2007 10:16  |
Hi Kenn,
uml2 as well.
(step by step plz)
thx a lot
Nick
Re: retrieving model info [message #624155 is a reply to message #474756] |
Nick,
R2_1_maintenance.
Kenn
> Hi Kenn,
> uml2 as well.
> (step by step plz)
> thx a lot
> Nick
Re: retrieving model info [message #624244 is a reply to message #474759] |
Thu, 02 August 2007 08:40  |
Hi Kenn
anonymous/blank and anonymous/anonymous but it doesn't accept the password.
Maybe this isn't the reason but the fact remains that I cannot import
project set due to password error.
thx
nick
Re: retrieving model info [message #624248 is a reply to message #474868] |
Nick,
Kenn
> Hi Kenn
> password.
> password error.
> thx
> nick
FUDForum. Page generated in 0.32362 seconds
