Running Minimal Standalone [message #623984] |
Thu, 25 March 2010 19:31  |
I followed the instructions for running a minimal infocenter standalone.
Platform Plug-in Developer Guide > Programmer's Guide > User assistance support > Help > Configuration/setup > [Optional] Installing a minimal stand-alone help system
When I try to start the infocenter using the minimal plugins directory, I get the following exception:
java.lang.Exception: Plugins directory /home/ole/Documents/help/eclipse/plugins does not contain a valid startup jar. Pass a correct -eclipsehome option
at org.eclipse.help.internal.standalone.Eclipse.getStartupJar(E clipse.java:182)
at org.eclipse.help.internal.standalone.Eclipse.prepareJavaComm and(Eclipse.java:76)
at org.eclipse.help.internal.standalone.Eclipse.prepareCommand( Eclipse.java:48)
at org.eclipse.help.internal.standalone.Eclipse.run(Eclipse.jav a:87)
Is it possible to point the infocenter at a plugins directory that is different from the plugins directory contained in the eclipse folder? Something like -helpPluginDirectory /home/ole/help/onlyHelpPlugins
TIA,
- Ole
FUDForum. Page generated in 0.04128 seconds
