Home » Archived » Eclipse Communications Framework (ECF) » Problems running ECF2.0.0 remote service examples
Problems running ECF2.0.0 remote service examples [message #624008] Fri, 01 August 2008 01:27 Go to next message
I'm quite new to ECF. I can't ran the remote service examples.
Following is the exception:
!ENTRY org.eclipse.osgi 4 0 2008-08-01 13:20:18.046
!MESSAGE Application error
!STACK 1
at
org.eclipse.ecf.internal.examples.remoteservices.server.Disc overableServer.start(DiscoverableServer.java:93)
at
org.eclipse.ecf.internal.examples.remoteservices.server.Disc overableServer.start(DiscoverableServer.java:108)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Re: Problems running ECF2.0.0 remote service examples [message #624009 is a reply to message #624008] Fri, 01 August 2008 01:52 Go to previous messageGo to next message
Hi xxlu,
This NPE looks to be because the discoveryService is null in the
following code:
[89]discoveryService = Activator.getDefault().getDiscoveryService(5000);
[90]
[91]final String serviceName = System.getProperty("user.name") +
[92]System.currentTimeMillis(); //$NON-NLS-1$
[93]final IServiceID serviceID =
ServiceIDFactory.getDefault().createServiceID(discoveryServi ce.getServicesNamespace(),
getCompleteServiceType(), serviceName);
It is possible that the discovery service is null because of either
a) the jmdns provider bundle is not included in the set of bundles
needed for this app (it must be included so that the discoveryService
can be started and found)
b) the 5000ms timeout can be too short. In all the local tests I've
done 5000ms (5 sec) is long enough, but it is possible that under heavy
load conditions it's not long enough...and the jmdns bundle does not
have sufficient time to start. I've already changed the timeout to
15000ms and committed to HEAD and Release_2_0 branch. If you get the
source to org.eclipse.ecf.examples.remoteservices.server plugin:
Repository path: /cvsroot/technology
Module:
org.eclipse.ecf/examples/plugins/org.eclipse.ecf.examples.re moteservices.server
And get these fixes.
Scott
xxlu wrote:
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
Re: Problems running ECF2.0.0 remote service examples [message #624031 is a reply to message #624009] Wed, 03 September 2008 04:59 Go to previous messageGo to next message
I am also new to ECF and I'm having problems running the example (even with
the 15 sec timeout).
Here are the steps I did:
1. I imported org.eclipse.ecf.examples.remoteservices.client,
org.eclipse.ecf.examples.remoteservices.common and
org.eclipse.ecf.examples.remoteservices.server from CVS into a new
workspace.
2. I modified the Generic Remote EnvironmentInvo Server.launch configuration
to only have the three above workspace_bundles.
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.pde.ui.EquinoxLauncher">
<booleanAttribute key="append.args" value="true"/>
<booleanAttribute key="automaticAdd" value="false"/>
<booleanAttribute key="automaticValidate" value="false"/>
<stringAttribute key="bootstrap" value=""/>
<stringAttribute key="checked" value="[NONE]"/>
<booleanAttribute key="clearConfig" value="false"/>
<stringAttribute key="configLocation"
value=" ${workspace_loc}/.metadata/.plugins/org.eclipse.pde.core/Gen eric
Remote EnvironmentInfo Server"/>
<booleanAttribute key="default_auto_start" value="false"/>
<intAttribute key="default_start_level" value="4"/>
<booleanAttribute key="includeOptional" value="true"/>
<booleanAttribute key="org.eclipse.debug.core.appendEnvironmentVariables"
value="true"/>
<stringAttribute key="org.eclipse.jdt.launching.PROGRAM_ARGUMENTS"
value="-console -consolelog -application
org.eclipse.ecf.examples.remoteservices.server.remoteService sServer -debug"/>
<stringAttribute key="org.eclipse.jdt.launching.SOURCE_PATH_PROVIDER"
value="org.eclipse.pde.ui.workbenchClasspathProvider"/>
<stringAttribute key="org.eclipse.jdt.launching.VM_ARGUMENTS"
value=" -Dnet.slp.port=10427&#10;-Dch.ethz.iks.slp.debug=false&a mp;#10;-Dnet.slp.traceDATraffic=false&#10;-Dnet.slp.trac eMsg=false&#10;-Dnet.slp.traceDrop=false&#10;-Dnet.s lp.traceReg=false&#10;-Dnet.slp.failercount=3&#13;&a mp;#10;-Dnet.slp.multicastTimeouts=10,25,50,100,250,500,1000 &#13;&#10;-Dnet.slp.multicastMaximumWait=2000 "/>
<stringAttribute key="pde.version" value="3.3"/>
<booleanAttribute key="show_selected_only" value="false"/>
<stringAttribute key="target_bundles"
value="org.eclipse.osgi@:,org.eclipse.equinox.app@default:default,org.apache.commons.logging*1.0.4.v20080605-1930@default:default,org.eclipse.core.jobs@default:default,org.eclipse.osgi.services@default:default,org.eclipse.osgi.util@default:default,org.eclipse.equinox.registry@default:default,org.apache.commons.logging*1.0.4.v200803061811@default:default,org.eclipse.equinox.preferences@default:default,org.eclipse.core.runtime.compatibility.registry@default:false,javax.servlet@default:default,org.eclipse.core.contenttype@default:default,org.eclipse.core.runtime@default:true,org.eclipse.equinox.common@default:true,org.eclipse.core.runtime.compatibility.auth@default:default,org.eclipse.ecf.provider.jslp@default:default,org.eclipse.ecf.remoteservice@default:default,org.eclipse.ecf.provider.remoteservice@default:default,org.eclipse.ecf.provider@default:default,org.eclipse.ecf.provider.jmdns@default:default,org.eclipse.ecf.sharedobject@default:default,org.eclipse.ecf@default:default,org.eclipse.ecf.identity@default:default,org.eclipse.ecf.provider.discovery@default:default,org.eclipse.ecf.discovery@default:default,ch.ethz.iks.slp@default:default"/>
<booleanAttribute key="tracing" value="false"/>
<booleanAttribute key="useDefaultConfigArea" value="true"/>
<stringAttribute key="workspace_bundles"
value="org.eclipse.ecf.examples.remoteservices.server@default:default,org.eclipse.ecf.examples.remoteservices.common@default:default"/>
</launchConfiguration>
3. Then I right-click the modified launch configuration and run Debug.
=> I get the following failure:
Configuration location:
file:/C:/Users/anders/Documents/Eclipse-Workspaces/ECFTest/. metadata/.plugins/org.eclipse.pde.core/Generic
Remote EnvironmentInfo Server/
Configuration file:
Remote EnvironmentInfo Server/config.ini loaded
Install location:
file:/C:/eclipse-rcp-ganymede-win32/eclipse/
Framework located:
file:/C:/eclipse-rcp-ganymede-win32/eclipse/plugins/org.ecli pse.osgi_3.4.0.v20080605-1900.jar
Framework classpath:
Debug options:
file:/C:/eclipse-rcp-ganymede-win32/eclipse/.options not found
osgi> Time to load bundles: 24
Starting application: 606
DEBUG OUTPUT: false
Registered remote service
org.eclipse.ecf.examples.remoteservices.common.IRemoteEnviro nmentInfo with
org.eclipse.ecf.provider.generic.TCPServerSOContainer@e1eae7,ID=StringID[ecftcp://localhost:3285/server]
!SESSION 2008-09-03
10:42:19.618 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_10-ea
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=sv_SE
Framework arguments: -application
Command-line arguments: -dev
file:C:/Users/anders/Documents/Eclipse-Workspaces/ECFTest/.m etadata/.plugins/org.eclipse.pde.core/Generic
Server/dev.properties -console -consolelog -application
!ENTRY org.eclipse.osgi 4 0 2008-09-03 10:42:42.038
!STACK 1
org.eclipse.core.runtime.AssertionFailedException: null argument:
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:86)
at org.eclipse.core.runtime.Assert.isNotNull(Assert.java:74)
at
org.eclipse.ecf.internal.examples.remoteservices.server.Disc overableServer.start(DiscoverableServer.java:92)
at
org.eclipse.ecf.internal.examples.remoteservices.server.Disc overableServer.start(DiscoverableServer.java:110)
at
at
at
at
at
What am I missing?
Anders
"Scott Lewis" <slewis@composent.com> skrev i meddelandet
news:4892A4B6.4000900@composent.com...
> Hi xxlu,
> This NPE looks to be because the discoveryService is null in the following
> code:
> [90]
> a) the jmdns provider bundle is not included in the set of bundles needed
> for this app (it must be included so that the discoveryService can be
> started and found)
> b) the 5000ms timeout can be too short. In all the local tests I've done
> 5000ms (5 sec) is long enough, but it is possible that under heavy load
> conditions it's not long enough...and the jmdns bundle does not have
> sufficient time to start. I've already changed the timeout to 15000ms and
> committed to HEAD and Release_2_0 branch. If you get the source to
> Module:
> Scott
> xxlu wrote:
>> Hi,
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Problems running ECF2.0.0 remote service examples [message #624063 is a reply to message #624031] Sun, 14 September 2008 17:12 Go to previous message
Hi Anders,
Sorry about the slow reply.
You are not missing anything. At first glance, this seems to be some
problem with interaction between the jslp and the jmdns-based discovery
providers that is preventing this discoveryService lookup from
succeeding (and resulting in a NPE). I've created bug for this here:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=247238
Please join that bug and we'll track progress there.
Scott
> with the 15 sec timeout).
> workspace.
> configuration to only have the three above workspace_bundles.
> <booleanAttribute
> key="org.eclipse.debug.core.appendEnvironmentVariables" value="true"/>
> -debug"/>
> Configuration file:
> Install location:
> Framework located:
> Debug options:
> DEBUG OUTPUT: false
> with
> !SESSION 2008-09-03 10:42:19.618
> Remote EnvironmentInfo Server/dev.properties -console -consolelog
> -application
> !STACK 1
> at
> at
> at
> at
> at
> at
> at
> What am I missing?
> Anders
>> Hi xxlu,
>> following code:
>> [90]
>> heavy load conditions it's not long enough...and the jmdns bundle does
>> not have sufficient time to start. I've already changed the timeout
>> to 15000ms and committed to HEAD and Release_2_0 branch. If you get
>> the source to org.eclipse.ecf.examples.remoteservices.server plugin:
>> Module:
>> Scott
>> xxlu wrote:
>>> Hi,
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Previous Topic:How to publish remote services (r-osgi) automatically / discover peers ?
Next Topic:ECF service threads
Current Time: Fri Jul 25 09:50:14 EDT 2025
Powered by FUDForum. Page generated in 0.26220 seconds
