Home » Archived » Eclipse Communications Framework (ECF) » syndicated feeds
syndicated feeds [message #624024] Sat, 23 August 2008 15:27 Go to next message
Hello all,
I'm a new user (and hopefully future developer) of the ecf and I was
wondering if there already are syndicated feed API's, tutorials or plug-ins.
Sincerely,
Michael Wiwchar
Re: syndicated feeds [message #624025 is a reply to message #624024] Sat, 23 August 2008 17:45 Go to previous messageGo to next message
Hi Michael,
Michael Wiwchar wrote:
> Hello all,
> plug-ins.
We have some work (but not enough) on feeds.
First, here's the root of the appropriate CVS tree for the materials
referred to below: :pserver:anonymous@dev.eclipse.org:/cvsroot/technology
We have an RSS-SSE provider implemented here
provider/org.eclipse.ecf.provider.rss
This provider implements the an RSS-SSE client. The provider name is
ecf.provider.rss.client and the implementation class is
org.eclipse.ecf.internal.provider.rss.container.RssClientSOC ontainer.
See the 'main' method in that class for some test code. (This should be
generalized and moved into a new test plugin, which I will create if
desired).
This rss-sse feed class implements the datashare 'mergeable' api i.e.
org.eclipse.ecf.datashare.mergeable.IMergeableChannelContain erAdapter
which is in the org.eclipse.ecf.datashare plugin (datashare API).
We have not been able to do much with either the datashare mergeable api
or the rss-sse provider implementation recently...which is a shame. It
might also be good to have another (new) API. Hopefully you can help us
fix the current limitations, as I would like to use/distribute this code
much more.
Scott
Re: syndicated feeds [message #624026 is a reply to message #624025] Sat, 23 August 2008 20:37 Go to previous messageGo to next message
Scott Lewis wrote:
> Hi Michael,
>> Hello all,
>> plug-ins.
> desired).
> much more.
> Scott
Scott,
I'm willing to give it a shot as long as people are willing to answer
the (hopefully occasional) questions I'll have.
Sincerely,
Michael Wiwchar
Re: syndicated feeds [message #624027 is a reply to message #624026] Mon, 25 August 2008 17:18 Go to previous message
<stuff deleted>
> Scott,
Absolutely. You might want to join the ecf-dev mailing list:
https://dev.eclipse.org/mailman/listinfo/ecf-dev
as that's typically the way that the ECF committers interact more
closely with contributors (also filing bugs/enhancement requests at
bugs.eclipse.org and the wiki at http://wiki.eclipse.org/ECF...a
bugzilla account will get you write access to the wiki).
Thanks!
Scott
> Sincerely,
> Michael Wiwchar
Previous Topic:REMINDER: ECF conference call TODAY (8/21) at 1100 pacific/1800 UTC
Next Topic:JmDNS ClassCastException and more
Current Time: Sat Jul 26 23:31:04 EDT 2025
Powered by FUDForum. Page generated in 0.06036 seconds
