Docshare slow? [message #623960] |
Tue, 08 July 2008 11:15  |
Hello everyone,
i was just playing around with the docshare plugin and made it work
after making myself a little familiar with ECF. However, it is kind of
slow. I am using a public jabber server (jabber.scha.de) in Germany and
i have a very speedy university connection. Currently, i am testing
collaborative editing with myself using a virtual machine and have to
wait roughly two seconds for each changed character. Having watched the
available screencast, this is obviously supposed to be quicker. Why
could it be this slow. Would it make a difference if i used Skype
instead of Jabber for example?
Thanks for any hints!
Benjamin
Re: Docshare slow? [message #623961 is a reply to message #623960] |
Tue, 08 July 2008 11:38   |
Hi Benjamin,
Benjamin Zeiss wrote:
> Hello everyone,
> slow.
I/We've not seen slowness in any of our tests with our own Openfire
server nor with Google talk's service. If you would like to try some
guest accounts on the ecf.eclipse.org openfire server please send an
email to me directly at slewis at composent.com and I'll give you access
to some accounts.
I would say that given that you have a low latency network, it is almost
certainly that the server has some latency (for whatever reason).
It might. I've noticed that Skype's app 2 app service (what ECF
uses/depends upon) can sometimes have a relatively high latency,
however. I suspect it depends upon the Skype load but haven't done any
careful examination yet.
FWIW, the logic implementing the shared editing does not take up
significant time on reasonably powered machines, so the latency you are
seeing is almost certainly due to the network (unlikely in your case)
and/or the server (seems fairly likely).
Scott
Re: Docshare slow? [message #623963 is a reply to message #623961] |
Tue, 08 July 2008 23:21   |
Scott,
I have seen slowness in IMing in Eclipse via ECF versus a client like
Pidgin. I have both open and the messages appear in Pidgin noticeably
before Eclipse.
Scott Lewis wrote:
> Hi Benjamin,
>> Hello everyone,
>> slow.
> to some accounts.
>> the available screencast, this is obviously supposed to be quicker.
>> Why could it be this slow.
>> Would it make a difference if i used Skype instead of Jabber for example?
> Scott
Re: Docshare slow? [message #623965 is a reply to message #623961] |
Wed, 09 July 2008 02:23   |
To anyone interested:
I have actually tested docshare with the guest accounts of the ECF
openfire server and it worked perfectly fine. I suspect that there is
either something wrong with those public servers that i tested or they
simply have too many users. I also made a quick setup of my own openfire
server and it worked fine as well. So Scotts point is true. Some free
public servers are doing something that prevents the shared editing from
working as expected.
Ben
Scott Lewis wrote:
> Hi Benjamin,
>> Hello everyone,
>> slow.
> to some accounts.
> Scott
Re: Docshare slow? [message #623979 is a reply to message #623966] |
Wed, 09 July 2008 20:07  |
No. I had Pidgin and Google Talk (the browser) and ECF opne on my
machine IMing someone else. I can see the others responding quicker. If
I don't have the others open it really isn't that much of an issue. Just
mentioning what i was observing.
> Hi Mark,
>> before Eclipse.
> Have you tried that by sending yourself messages using ECF and pidgin
> through two different accounts on different machines? I am asking,
> because i suspect it is easy to get the impression that ECF is somehow
> slower if you don't test the latency systematically. I had a similar
> impression yesterday, but i didn't test it systematically. It may be
> again just a problem with the jabber server.
> Ben
FUDForum. Page generated in 0.07160 seconds
