Home » Modeling » UML2 Tools » [TOPCASED] Opening a Profile and a Model applying it at the same time
[TOPCASED] Opening a Profile and a Model applying it at the same time [message #476497] Wed, 27 May 2009 04:22 Go to next message
Originally posted by: formatzeh.gmx.de
I don't know if this is the right place to ask a TOPCASED question but
maybe you can help me.
I created a profile in TOPCASED. Then I opened a class diagram, loaded
the profile and applied it. But if I close one of the editors (profile
or model) and try to re-open it I get the exception that another editor
is open handling the other file. Why is that? The point is that my
profile is evolving and my model as well and I need to have them open
both. I can't unapply the profile every time, to just open both and then
apply it again.
regards
Gilbert
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #476498 is a reply to message #476497] Wed, 27 May 2009 11:19 Go to previous messageGo to next message
Gilbert, you should use the dedicated Topcased users' mailing list for
questions related to the use of Topcased
:( http://lists.gforge.enseeiht.fr/mailman/listinfo/topcased-us ers).
This behavior is intentional. See Bug #1405 for more details
( http://gforge.enseeiht.fr/tracker/?group_id=52&atid=109& amp;func=detail&aid=1405).
As indicated in the documentation, you can disable that behavior by
creating a file named "allowConcurrentAcces" in the .metadata of the
workspace in the folder
/workspacePath/.metadata/.plugins/org.topcased.modeler
Jacques
> apply it again.
> regards
> Gilbert
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #476499 is a reply to message #476498] Wed, 27 May 2009 11:46 Go to previous messageGo to next message
Ok, thanks a lot.
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #476500 is a reply to message #476498] Wed, 27 May 2009 13:57 Go to previous messageGo to next message
Just another question. Is the mailing-list frequently used?
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #476513 is a reply to message #476500] Wed, 03 June 2009 08:48 Go to previous message
Yes it is. Just try and you will see ;-)
regards
raphaël
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #623905 is a reply to message #476497] Wed, 27 May 2009 11:19 Go to previous message
Jacques
> apply it again.
> regards
> Gilbert
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #623907 is a reply to message #476498] Wed, 27 May 2009 11:46 Go to previous message
Ok, thanks a lot.
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #623909 is a reply to message #476498] Wed, 27 May 2009 13:57 Go to previous message
Re: [TOPCASED] Opening a Profile and a Model applying it at the same time [message #623929 is a reply to message #476500] Wed, 03 June 2009 08:48 Go to previous message
regards
raphaël
Previous Topic:Programmatically generating Class Diagrams
Next Topic:Inline editing of a operations in the classdiagram
Current Time: Mon Jul 28 19:20:58 EDT 2025
Powered by FUDForum. Page generated in 0.05203 seconds
