Home » Eclipse Projects » Plugin Development Environment (PDE) » Update Manager port?
Update Manager port? [message #61689] Wed, 13 May 2009 23:23 Go to next message
I'm trying to connect to an update site from within a firewall using
Eclipse 3.4.1. I can browse to the site from within Eclipse's Browser
view but my network guy says he's seen no requests from my IP when
attempting access thru the Update Manager which returns 'No update site
found'. What am I missing? Does Update Manager work on another port or
over HTTPS or something? Can I use the General>Network Connections page
to specify a proxy somehow? What exactly would that look like? Is there
something specific I can ask the network guy for?
Also, we're probably going to upgrade to 3.5 when it's released, will
this mechanism be the same?
Craig
Re: Update Manager port? [message #62077 is a reply to message #61689] Sat, 16 May 2009 17:58 Go to previous messageGo to next message
An update site is just a bunch of files sitting on a web server. So the
port is just 80 or whatever your webserver runs on. The update manager
uses regular HTTP mechanisms to access the site.
Are there any errors in your log when you try to access the site from
Update Manager?
Does it work if you put the contents of the update site in a local
folder and try to access it there?
-Ben
> Craig
Re: Update Manager port? [message #62125 is a reply to message #62077] Sat, 16 May 2009 23:55 Go to previous messageGo to next message
Thanks Ben. I'll try again and check the log and try accessing the update
site locally. Good tips.
Craig
> Update Manager?
> -Ben
>> Thanks,
>> Craig
Re: Update Manager port? [message #62390 is a reply to message #62125] Wed, 20 May 2009 19:01 Go to previous messageGo to next message
After discovering an Unknown Host Exception we determined the 3.4.1
Update Manager is not using the proxy settings set in the General >
Network Connections preference page. Is this a bug or by design? Will the
Update Manager in 3.5 negotiate through proxy servers?
Craig
> update site locally. Good tips.
> Craig
>> Update Manager?
>> -Ben
>>> site found'. What am I missing? Does Update Manager work on another
>>> port or over HTTPS or something? Can I use the General>Network
>>> Connections page to specify a proxy somehow? What exactly would that
>>> look like? Is there something specific I can ask the network guy for?
>>> Thanks,
>>> Craig
Re: Update Manager port? [message #62413 is a reply to message #62390] Wed, 20 May 2009 21:16 Go to previous messageGo to next message
I'm pretty sure p2 proxy support was in the 3.4.x streams but there may
have been bugs. Your best bet is to grab 3.5 RC1 and try it.
http://download.eclipse.org/eclipse/downloads/drops/S-3.5RC1 -200905151143/index.php
Ben
> Craig
>> Craig
>>> Update Manager?
>>> -Ben
>>>> Thanks,
>>>> Craig
Re: Update Manager port? [message #62488 is a reply to message #62413] Thu, 21 May 2009 18:35 Go to previous message
Thanks again Ben, I'll give 3.5RC1 a try.
Craig
S-3.5RC1-200905151143/index.php
> Regards
> Ben
>> the Update Manager in 3.5 negotiate through proxy servers?
>> Craig
>>> Craig
>>>> the port is just 80 or whatever your webserver runs on. The update
>>>> manager uses regular HTTP mechanisms to access the site.
>>>> Update Manager?
>>>> -Ben
>>>>> Browser view but my network guy says he's seen no requests from my
>>>>> IP when attempting access thru the Update Manager which returns 'No
>>>>> update site found'. What am I missing? Does Update Manager work on
>>>>> another port or over HTTPS or something? Can I use the
>>>>> General>Network Connections page to specify a proxy somehow? What
>>>>> exactly would that look like? Is there something specific I can ask
>>>>> will this mechanism be the same?
>>>>> Thanks,
>>>>> Craig
Re: Update Manager port? [message #597586 is a reply to message #61689] Sat, 16 May 2009 17:58 Go to previous message
Update Manager?
-Ben
> Craig
Re: Update Manager port? [message #597600 is a reply to message #62077] Sat, 16 May 2009 23:55 Go to previous message
Craig
> Update Manager?
> -Ben
>> Thanks,
>> Craig
Re: Update Manager port? [message #597689 is a reply to message #62125] Wed, 20 May 2009 19:01 Go to previous message
Craig
> Craig
>> Update Manager?
>> -Ben
>>> Thanks,
>>> Craig
Re: Update Manager port? [message #597695 is a reply to message #62390] Wed, 20 May 2009 21:16 Go to previous message
Ben
> Craig
>> Craig
>>> Update Manager?
>>> -Ben
>>>> Thanks,
>>>> Craig
Re: Update Manager port? [message #597716 is a reply to message #62413] Thu, 21 May 2009 18:35 Go to previous message
Craig
> Regards
> Ben
>> Craig
>>> Craig
>>>> Update Manager?
>>>> -Ben
>>>>> Thanks,
>>>>> Craig
Previous Topic:Bundle-ClassPath not processed in 3.5RC1
Next Topic:More control over Eclipse builders
Current Time: Wed Sep 03 13:55:23 EDT 2025
Powered by FUDForum. Page generated in 0.08751 seconds
